Where can I order an adaptor for swing product number GCP P3806 A1?
IS THERE A PERCENTAGE FORMULA TO USE IN EXCEL
There isn't a function for this, but the formula should be something like this:
A1: Number to increase / decrease
B1: % change
C1: 'INC' or 'DEC'
D1: =IF(C1='INC', A1+(A1*B1), A1-(A1-B1))
Nov 17, 2011 | Microsoft Excel for PC
Program that will accepts 2 numbers and will display the sum,difference,product and quotient by the use of flow chart?
You can do this pretty easily in a spreadsheet program such as excel, open office or numbers on a mac. Simply use two cells for the numbers you would like as an input and then input formulas for the sum, difference, product and quotient in 4 other cells. Examples:
(This assumes you use A1 and B1 to hold your input numbers)
For sum you would input the formula: =A1+B1
For difference: =A1-B1
For product: =A1*B1
For quotient: =A1/B1
To get this into a flowchart simply go into "Insert > Chart" and select the chart you want to use with the correct options.
I hope this helps, if it does, please give a thumbs up!
Jun 28, 2011 | Computers & Internet
I have a protron LCD TV where can i find the product code?
It should be on a sticker on the back of the TV or on the user manual. The product code (model number) will be something along the lines of LU32A1A3.
LU is the range
32 is the screen size
A1 & A1 are model and version numbers.
Hope this helps.
Regards,
BElectric
Dec 20, 2010 | Televison & Video
How to number a column. I can't remember the short formula, something like a1+1= which would make the number two pop up in the cell underneath.
You can number rows in a column by entering a number in cell A1 (usually the number 1 but youcan start with any number) and the formula (=A1+1) in the next row. The result there will be 2. Copy that formula down the rows you want to number and they will be numbered 3, 4, 5, etc. Each row adds 1 to the previous row so if you do anything that disrupts the sequence (like inserting a row between two others) you will have to copy the formulas down again to restore the sequence. You can also use the Edit-Fill-... menu command to put a series of numbers into rows. Put the starting number in th efirst row. Highlight it and the rows that you want to number and select Edit-Fill-Series... Those numbers will not change if you insert columns or move the formulas.
Or you can use the formula =ROW(A1) in any cell to return the number of that row. (The result of =ROW(A1) is the number 1 in cell A1, the result of =ROW(A2) is the number 2 in cell B2, etc. In this case inserting rows will not affect the numbering (i.e. row A5 will always be numbered 5 even if the data in it is moved down.)
Sep 18, 2009 | Microsoft Excel for PC
Need a new window kit adaptor for 9000ah
you should be able to find that through a heating and air condition company they should with all the model and searial numbers be able to order it for you
Aug 23, 2009 | Soleus KY-34 Portable Air Conditioner
Multiply a value by a minimum amount
You need a cell to put these numbers first. Lets say A1 is your reference cell where the numbers are going to be input. B1 is the cell that you are going to see the calculation. Type the following formula in B1
=IF(A1<4,4*60,A1*60)
after doing this you can put any number in A1 and it will give you the calculation in B1 as the way you wanted.
Feb 24, 2009 | Microsoft Excel for PC
Swing along castle broken parts need to order My
Go to littletikes.com. They have a seciton to choose outdoor products and you can drill down to the swing and slide castle. All the replacement parts are available there.
Feb 19, 2009 | Little Tikes Swing Along Castle
Excel formulas
hello
yes it is.
example
sheet1
A1 (50)
A2 (50)
sheet2
(A1)=
"=Sheet1!A2+Sheet1!A1" <-this is the actually code in sheet2 column A1
ok let me explain
in A1 and A2 in sheet1 you got 50 and 50 like numbers.
in A1 on Sheet2 you have = sheet1 a1 + sheet1 a2.
did you get it?
dont know else how I should explain it...
good luck
Oct 09, 2008 | Microsoft Excel for PC
Excel formula
CHOSE THE PERTICULAR CELL WHERE THE SUM IS GOING TO BE DISPLAYED AND HYPERLINK IT IT WITH SHEET 2
Apr 12, 2008 | Microsoft Excel for PC
Excel and the AVERAGE function
Here is one way:
In this example, my numbers are in cells a1 through a4. My average is computed with the formula:
=SUM(A1:A4)/COUNTIF(A1:A4,"<>0")
I'm summing the range of numbers and dividing that by the count of nonzero numbers. With this formula, you'll get an error if there are no nonzero numbers.
Dec 30, 2007 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
