My Techwood (43AO4USB) TV flickers with static and alternates between black, red, green and blue.
This happens for about 30 seconds and then the tv goes back to normal and then it may happen in another 10 minutes?
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Posted on Sep 14, 2008
  • 12 Answers
SOURCE: My TV Screen turns green or blue after 10 minutes of the tv on
You have a chip that is overheating due to heatsink coumpound being dried up. You need to find that chip and heatsink and apply new compound to both parts.
Posted on Apr 06, 2009
  • 41 Answers
SOURCE: Tv picture freezes then goes black 10seconds later HL-R5067W
Sounds like the digital board needs replaced.
Posted on Jul 11, 2009
toolkits
  • 1099 Answers
SOURCE: LG 32" Plasma TV power-on problem
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
hope this helps...
Posted on Jul 02, 2010
  • 115 Answers
SOURCE: model hln617w. the picture on the screen freezes
Most likely your problem is on the DMD Assy Board P/N BP96-00249A . More presicely there is a few bad electronic components on that board that are bad. That board can be repaired by replacing the bad components (and the other few compoonents that are probly going bad and will soon cause your tv to lockup and lose remote and button functions when it fails so you will need to unplug it to get it on again).
Or the DMD board can be replaced .But it is not a cheap board.
For removal and Installation of the DMD board I would reccomend a tv service person because it is in the heart of the television and there are some adjustements to be made when the new board is installed.
To get the new board you could probably find it by just gooogling the part number.
Component level repair would require some experience in desoldering and soldering SMT,SMD , and or surface mount components.The actual components are about $15.00 total so just repairing your board should cost about $125.00 by a qualified servicer (if you were to remove and install it yourself). This DMD board is used in many models and can a few common problems.
HLM437W HLM4365W HLM5065W HLM507W HLM617W HLN437W HLN4365W HLN467W HLN507W HLN50665W HLN567W HLN617W ( L2 and L5 chassis )
SYMPTOMS:
-Intermittant picture freezing with a negative looking B/W frozen picture.
-Intermittant loss of pic with/without shutdown,abnormal color wheel noise if attempted to start after shutdown.
-lockup of tv control functions . Remote and front keypad do nothing , TV must be unplugged to reset .
-horizantal tearing, distortion , flippnig , solarization , red picture, leading to blank screen and lockup.(tv menu would be affected by all picture defects).
Hope this helps someone..
Posted on Jul 21, 2010
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
Why does my tv have one blue, one red and one green line at the top of the screen but no picture?
The CRT inside the TV has gone bad. You can either find the make and model of the CRT and replace it, or get rid of the tv and buy another one.
Jun 08, 2012 | Televison & Video
Techwood tv flashing colours
Check to see if test pattern is on, in the main menu.
Nov 27, 2011 | Televison & Video
JVC AV48WP30 Projection TV..Half picture distorted and flickering
Ur convergence is dead.Must replaced the 2 convergence ICS and all it resistors.The shop will cost U $300 for parts and parts.
Feb 10, 2010 | JVC AV-48WP30 48" Rear Projection...
TV lost some of the colors
quick simple solution that might fix it. Completely unplug the tv from the electricity for about 30 seconds. Some times especially during brown outs or black outs, the processor gets scrambled and needs to be reset. This 30 seconds of no electricity usually allows the system to reset it self correctly.
hth
Feb 14, 2009 | Samsung DLP HL-P5663W 56" TV
Sound problem
Go into your TV settings and change the Automatic Volume Control Sound Mode. It's probably at Dynamic and the TV is trying to adjust the volume. The popping sound may be caused by static electricity building up on the circuits of your TV or cable.
Does this also happen when you are watching a video/DVD?
Nov 27, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Phillips plasma 42 in tv thin
malfunction of the vertical output integrated circuit
Dec 22, 2007 | Philips E-Box FTR9965 DTV Receiver
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
