Question about Garmin GPS
There used to be a little red square with an X in it. I could cancel. Now it is gone. How do I fix it.
X in bottom left corner of Garmin Nuvi 1450
  • 37 Answers
SOURCE: 1 RED LIGHT BOTTOM LEFT CORNER
This usually means something is wrong with the graphics scaler. You'll eventually have to send your xbox in to have it fixed, and I believe it is covered under a one year warrenty.
Posted on Feb 26, 2008
SOURCE: NUVI 250w Show Black Screen with ICON of Computer and NUVI
I had this problem. I discovered that I was using the wrong lead in the car. The problem resolved itself when I used the lead that came with it.
Posted on Jun 10, 2008
riceski
  • 1851 Answers
SOURCE: nuviĀ® 255W Car GPS Receiver: The screen of my Garmin nuvi 255w GPS is white and...
Press and hold the lower right corner - then see second picture
Posted on May 21, 2010
  • 1043 Answers
SOURCE: garmin nuvi 1450 will not
You should be able to resolve the issue by resetting your unit. The 1450 is reset by pressing and holding the Power button for about 20 seconds. Your unit should then start up like it normally would.
If the reset does not resolve the issue then you may either have a dead battery or an electronic issue. You can check if the issue is the battery by plugging your unit into your computer using the USB cable that was supplied with your unit. The Garmin is programmed to automatically draw power and recharge it's battery when it is plugged into a unit with the USB cord. You can try the reset option again while you are attached to the computer. If you are still unable to get the unit to come on then you will have to take the unit into a Garmin authorized repair center. They will be able to test your battery and let you know if it needs to be replaced. Then can also tell you if the issue is internal to the unit, and what it will cost you to repair the unit.
Posted on May 15, 2011
  • 343 Answers
SOURCE: my garmin nuvi 1450 cannot
Make sure the Garmin is fully charged and try driving with it on and it should find the satellites. If it does not work try this.
Then go to the Garmin site and register your product. Then download Garmin Updater and connect your unit with a usb cable directly to your computer and not thru a USB hub. Let the update go directly to the GPS and not a folder. It will take a few hours even with a fast internet connection. I have attached a link to the Garmin site. Thanks for using FixYa
https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
Posted on May 20, 2011
My Gamin Nuvi can't unlock maps
Use a Garmin 1450
The Garmin Nuvi 1450 can be used while driving or walking.
While driving, use the Nuvi 1450 to create a route to your destination and get step-by-step directions, to hear the names of upcoming streets, to tell you when to change lanes and to find out the speed limits on unfamiliar streets.
As a pedestrian, you can have the Nuvi 1450 create a route for you that uses a mixture of walking and public transportation, such as the subway or bus system, if you have purchased cityXplorer maps for that area.
Tap "Where to?" to set up a route. The "Where to?" icon is a large magnifying glass.
Tap "Addresses." The available categories are address, points of interest, go home, recently found, favorites and intersections.
Input the name of the state or county, if it is out of town.
Then tap "Spell city." Spell out the name of the city using the pop up keyboard.
Press "Done."
Enter the address number and press "Done."
Then enter the street name and press "Done."
The "Go" screen opens automatically.
Tap the green "Go" button. The Nuvi 1450 will now calculate a route to the address.
Follow the voice prompts and map highlight to your destination.
Navigate Using Coordinates
Tap "Where to?" and then tap "Coordinates."
Tap the coordinate you want to adjust/input a new coordinate.
Tap "Format" to choose the right coordinate format for the map you are using.
Enter the coordinates. Tap "Next."
Tap the green "Go" button to calculate a route.
Use the Map Page
Navigate to your destination by following the voice prompts, highlighted route on the map and directions located at the top of the map screen.
Tap the "turn" icon located in the upper left corner of the screen to see the next turn. It may have a turning or straight arrow and the number of miles until the turn. Tap the bar across the top with the next direction listed on it to see a list of all directions.
Tap the plus or minus signs on the right side of the screen to zoom in or out.
Press the spinning arrow in the lower left corner of the screen to return to the main menu.
Tap the "car" icon traveling along the highlighted route to enter the "Where Am I?" screen and get your exact location, coordinates and nearby emergency services.
Hope this helps
Oct 29, 2012 | Garmin Nuvi 1450 GPS Standard Red LED Wall...
Tip
Garmin Nuvi 1450 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1450 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1450 series GPS unit.
I hope that helps.
__________________________________________
Garmin Nuvi 1450 Manual Download
Garmin Nuvi 1450 QuickStart Download
Garmin Nuvi 1450 Webupdate
Garmin Nuvi 1450 Favorites Backup
on May 27, 2010 | GPS
Tip
Garmin Nuvi 1450 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1450 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Tip
Download Garmin Nuvi 1450 Quickstart Manual
Have you lost your Owner's Quickstart Manual for your Garmin Nuvi 1450 GPS?
Would you like a digital copy of the Garmin Nuvi 1450 Quickstart Users Guide for easy searching of terms and quick reference?
The Nuvi 1450 Quickstart manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
Tip
Download Garmin Nuvi 1450 Manual
Have you lost your Owner's Manual for your Garmin Nuvi 1450 GPS?
Would you like a digital copy of the Garmin Nuvi 1450 Users Guide for easy searching of terms and quick reference?
The Nuvi 1450 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
Tip
Garmin Nuvi 1450 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
on May 27, 2010 | Garmin nuvi 1450 GPS Receiver
Tip
Garmin Nuvi 1450 Favorites Backup and Restoration Procedure Models: Nuvi 1200,...
Would you like to back up a copy of your Garmin Nuvi 1450 Favorites and Waypoints?
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
I hope that helps.
Tip
Garmin Nuvi 1450 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
Tip
I hope that helps.
Tip
I hope that helps.
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
