The tab broke off that if tipped will stop the heater from working. Is there a way to fix this? Model # NH400BE
My door to my Samsung microwave stopped latching. Model number Smh1611s. It still works if you hold the door closed. What parts do I need.
Where the tab broke off drill a small hole about 1/8 in hook spring back close back frame. no new part needed
Apr 12, 2015 | Samsung Microwave Ovens
Tip
Ready Heater Model R40
Recently my ignitor broke on my keorsene ready heater. No one in town
had the part. I stopped at a local wholsale heating and cooling supply company.
I looked at there ignitors and came across a white rodgers universal
igniter. Took it home and installed it with no motification. Unit works great.
on Jan 19, 2010 | Heating & Cooling
Manual for maxiheat nh400be
Maxi heat is a product of Allmand Brothers.
Allmand.com
(308)995-4495
(800)562-1373
Explore the above and you will probably get your
manual. Good luck.
Regards,
Dennis
Sep 28, 2014 | Heating & Cooling
Heater got tipped over now wont heat. It lights up when I power it on the display works, no HEAT. I have 5 small grandsons that live with me and this heater was quite expensive I need it to work and...
I do believe that there should be a tip switch under the feet and if it is broke off then you need to by pass the switch. You could use a small piece of dowel rod up inside to trip the switch and have heat.
Dec 13, 2010 | Honeywell HZ519 Baseboard Heater
Broke little piece coming from itnitor, still has half of tip
Hello. If you still have the piece you may be able to permanently reattach it with some clear epoxy adhesive. I like the one minute clear epoxy which does not require clamping.
IF your piece is not glueable then I recommend that you order a new part. One good source is http://www.lewiscontractorsales.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=keroseneheaterparts
Regards, Joe
PS please rate my answer. thank you.
Jan 06, 2010 | All-Pro Forced Air Kerosene Space Heater...
Antifreeze leak from back of engine compartment leaking
Sorry, but you are going to have to crawl under the car with a flashlight to find out where the leak is. It could be a freeze plug on the rear cylinder bank, a bad head gasket, or a leaking heater hose. Look for white marks where the anti-freeze has been leaking. In any case, it is going to be a royal P.I.T.A. to fix. Don't forget that patience is a virtue.
Aug 29, 2009 | 1999 Ford Taurus
Konica Minolta Magiccolor 2350 Laser Printer
When the front door is open, it locks the 4 cartridges so they can not move. The tab is flimsy & I broke mine on the second or third change. It pushes on a mechanical switch just above the toner port. If you broke the tip of the tab off, you can use a drywall screw inserted into the Mechanical switch. when the door closes the bigger part of the tab will push the screw against the switch,
Jul 16, 2008 | Konica Minolta magicolor 2400 Laser...
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
