Question about Plumbing
My Utilitech submersible pump is clogged. I can't get the impeller to release from the shaft. ??
  • 11 Answers
SOURCE: pump seals
The impeller is threaded on to the shaft. The trick is to hold the shaft in order to untread the impeller. The surest method is to disassemble the back of the motor, exposing the opposite end of the shaft. There should be a spot to put a wrench in order to hold the shaft immobile. Then, it's simply a matter of unthreading the shaft. A strap wrench does a great job of holding the impeller without damaging it.
Posted on Jan 03, 2009
PartsCenter
  • 125 Answers
SOURCE: Jacuzzi magnum pool pump impeller broke
The impeller on the Magnum pump unthreads counter clockwise as do other impellers. There is a shaft of the motor that runs the length of the motor, on the back of the motor when you take the bell housing off you will see a small silver spot with a **** in it for a standard screwdriver. Put the biggest one in there you can and then grab the impeller and turn it counter clock wise and it should unthread. Sometimes they won't if it has been on there a number of years. You will need to break it off if it doesn't unthread. Then just purchase a new Impeller for the Jacuzzi Magnum Pump.
Rod
US Parts Center
Posted on Feb 24, 2009
  • 990 Answers
SOURCE: I want to replace an impeller for a Little Giant submersible pump
This is a plastic impeller on a brass hub. If the impeller is loose it is probally cracked or overheated and melted, ether way you will have to break the impeller off of the hub then you will need to break hub loose from shaft. You can do this by putting pump in a vise and putting a pair of vice grips on hub and giveing them a sharp hit in a counter clockwise direction. you will need to replace the seal and impeller and should check to be sure than you can get these parts before you start.
Posted on Aug 24, 2009
  • 990 Answers
SOURCE: shaft seal leaks on sta rite pump?
You need to get to the shaft at the back of the motor to hold it while you use water pump pliers or the like to turn it off. It will unscrew in the regular direction but if it has a set screw to hold it in (You will find this at the center of the impeller) this will be a left hand screw so you will go clockwise to loosen it. This should get the impeller off. If not you will need to put a screwdriver in the side of the impeller and give it a hit to lossen the impeller. Good luck.
Posted on Aug 25, 2009
  • 409 Answers
SOURCE: REMOVE IMPELLER FROM SHAFT A O SMITH PUMP MOTOR HIFLO
The impeller is threaded onto the motor shaft, take the back cover off and use a wrench to hold the motor shaft, then turn the impeller counter clockwise to remove.
Posted on Mar 17, 2010
Where can I buy an adaptor for a Utilitech 1/3 HP Submersible Pump #0435062, PPSU33? I called Utilitech and they were no help.
the best place to get help here is from a pump and irrigation supply shop
they will have everything needed to operate the pump
Feb 08, 2017 | HP Plumbing
Impeller runs, no water comes out. Removed output hose, air is blowing out when removed from sump.
Remove bottom cover, check for clogged intake holes, and make sure the impeller is solidly attached to the shaft. Can you see the water in the sump? Is the sump full of sand at the bottom?
Jun 28, 2015 | Utilitech 1/2-HP Cast-Iron 83 GPM...
Looking for a new motor for a utilitech pro 0313836 submersible pump
Most submersible pump motors are interchangeable.
A 230 V motor will run cheaper. Be sure to get the correct HP motor.
Oct 05, 2014 | Utilitech 1-1/2-HP 18-GPM 3-Wire 230-Volt...
Why won't my Utilitech dusk to dawn light work
If you know the bulb is good, try changing the photocell. Why is it half of the problems on this site are Utilitech? I think I see a pattern.
May 28, 2014 | Utilitech 0.33-HP Thermoplastic...
How to replace plastic impeller with brass(metal) impeller
I called Lowes then Utilitech and they sent me a new impeller. There were no instructions about how far to thread the impeller onto the post. I am going back in to thread it all the way to the top. I wish I had requested a brass impeller.
May 21, 2014 | Utilitech 1-1/2 HP Irrigation Pump UTP15P1
Utilitech pro submersible pump has good electrical connection but pump won't start
There is a starting capacitor on the motor pump, check this out if faulty then replace it.
Dec 28, 2013 | Utilitech Plumbing
How do you know if the enpeller is on the wrong way, ya I know no water coming through, but there is air and the motor is in the water.
I presume you're referring to a submersible pump. the impellers are either centrifugal or screw type. Check the direction of rotation by turning the pump on without the impeller installed. Then install the impeller so that the blades can draw water into the pump body and expel it at the discharge discharge outlet.
Oct 06, 2013 | 172550003P Spare Impeller And Shaft
Aug 24, 2009 | Little Giant Submersible Fountain Pump
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
