Question about Velbon VideoMate Deluxe Heavy-Duty Photographic/Video Tripod 607 w/ FREE UPS
Telescoping handle on my Impuls
Handl eis stuck in the up position; nothing seems bent or broken
    Problem Solver:
  • 5 Answers
Soak with wd40 or spray with dry graphite i
Posted on Jul 18, 2010
2006 VW New Beetle passenger seat
Check the spring which puts tension on the lever to hold it in the lock position this may have dislodged itself or be broken or possibly bent.
Jun 06, 2013 | Cars & Trucks
Removing telescopic handle of Quinny Buzz?
Pull the handle up almost all the way, the plastic pieces that hold the handle in place come out by pusining in the little black plastic dot but the handle has to be in the correct position. Move the handle up and down till you can easily push in the dot. The handle should then come off easily enough
Jul 17, 2010 | Quinny Buzz Three Wheel Stroller
Handle release does not work, seems to be stuck in the downward position and does not keep handle in operating mode
I had the same thing happen to mine and I disassembled the handle area. It was not broken and only needed to be put back in place and has worked since then although I'm very careful when I use the trigger now. Hope this helps.
Mar 14, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Telescopic handle problem in swissgear lap top roller suitcase.
The problem area is inside the riveted fabric. You may have to destroy your Swiss Gear case in order to salvage it.
Nov 22, 2017 | Swiss Gear by Wenger Wenger Gear Granada...
The sliding door on our 1996 Toyota Sienna is broken shut (it cannot be opened). The door button on the inside nor the handle on the outside can mechanically effect the door. We do not have automatic door...
It sounds like the cable/bar in the door is broken or stuck
1. you will need to remove the door lining to get at the problem
2. could also be the door lock stuck in the lock position (does the door feel like it locks or unlocks when you use the lock)
3. could be the handle cable/ bar
NOTE some vehicles have cables while others have bars play with everything while you have the guts exposed this should help to locate the problem if nothing is moving while you play with the lock or handle this could be the problem
NOTE If nothing seems to be missing or out of place it could simply need to be lubed at the point where the door locks to the frame
Aug 21, 2009 | 1998 Toyota Sienna
Handle wont go to upright position
The red pedal has slipped out of position. On both ends of the red pedal you'll see metal rods (the axel of the pedal). On one side you'll see the metal rod sits into a long groove, on the other side you'll see the metal rod sits into a round hole. They both have to be in the long grooves so you have to reposition the rod that's into the round hole by pulling it out and sliding it back into the long groove above the round hole. You'll now be able to bring the handle up and lock the machine back into the upright position.
Jun 17, 2009 | Dyson DC25 All Floors Bagless Upright...
Need instructios to repair 1997 Toyota Camry Broken Exterior Door Handle
Two 10mm bolts, or nuts, hold the handle on from inside the door. dont forget to remove actuating rod from old handle. probably clip is broke also.
May 30, 2009 | 1997 Toyota Camry
Doors won't close
Manually UNLOCK the door button or slide. HOLDING the OUTSIDE DOOR HANDLE in the OPEN position, with your other hands finger, LIFT OPEN the latch, and close your door. Hope this helps.
May 24, 2009 | 1994 GMC Sierra
Can't open the back door of my LR3
If its a problem that the rear door handle is stuck in the upper position, then you need to use a screwdriver to pull the handle down , then use wd40 and spray up into the handle mechanism. Its common that handles stick, due to road dirt wafting up there as you drive along.
If this is not the case , and its due to the lock mechanism itself, then you will have to get into the rear compartment and remove the door trim pad, then pull the plastic protection away and get access to the lock mechanism. Check that a lock rod has not broken or fallen off, try to lift the unlock rod and see if the door opens, in which case you can adjust the rod and that should do the trick, it maybe that you need a new mechanism, they can fail.
Hope this helps
Feb 14, 2009 | 2005 Land Rover LR3
Dishwasher latch
hi there,
check the door latch and door handle to make sure that there is nothing broken or bent. otherwise, you have to replace the door locking mechanism.
Apr 22, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Photography Logo
85 people viewed this question
Top Velbon Photography Experts
JP Services
JP Services
Bill Eager
Are you a Velbon Photography Expert? Answer questions, earn points and help others
