How do I adjust from stretch mode on my tv - Televison & Video
Why does it seem locked in stretch mode?
find the on screen menu, move around until you find the aspect ration section and adjust to fit the screen
save and exit.
May 25, 2015 | Televison & Video
Zenith TV B27A24Z, Vert Size Adjust
To do this adjustment, you should enter the service mode option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Service mode entry, adjust and exit procedure to many popular brand TVs are given.
Feb 27, 2014 | Zenith Televison & Video
Picture is stretched on wide screen a circle looks egg shape
Hello
This is an issue because most television programming is produced in a 4:3 aspect ratio. The minority of programming is high definition, which is produced in a 16:9 aspect ratio. Because televisions are made in either a standard (4:3) or widescreen (16:9) format, there is always a conflict with an image being stretched vertically or horizontally. In the case of widescreen televisions, the stretching is horizontal.
Picture Modes
Luckily, most if not all widescreen televisions have a picture mode that allows the user to toggle between a wide (16:9) and standard (4:3) mode. This means that a person can watch non-HD programming in the 4:3 picture mode, and then go to widescreen when watching HD programming. Some TVs have a picture mode that will automatically adjust to the correct aspect ratio. Other people will watch all programming in the wide picture mode, and learn to adjust to watching a stretched picture.
A stretched picture is when a 4:3 image is pulled on the sides to fill the entire screen. People and images end up looking fatter/wider and shorter.
So, what's the big deal?
Some people don't like a 4:3 picture stretched or distorted because it does reduce the overall visual and picture quality. Some people don't like the bars on the side of the screen when a widescreen is in a standard (4:3) picture mode because it looks different.
Solution
There is no fix-all solution for this issue, unless you own a TV that will automatically adjust to the intended aspect ratio. The stretching of the picture is a side-effect, the price we are paying for the better resolution that is digital and high definition. This is definitely something to consider when buying a television, but keep in mind that there is no right or wrong within this issue. It is just the way it is, and there is no way around it unless you buy a 4:3 aspect ratio television.
Hope these lines will clear the issue, if so do rate the solution
Jan 04, 2011 | Televison & Video
I have a 52 in LCD tv. the picture is too big. i cannot see scores from basketball games becuase the print is outside the picture. i have adjusted the vertical but it is outside the frame on all 4 sides.
Use ur remote push view mode.U get four modes.The best two modes.Side Bars or S.stretch pick etheir of these modes will make it small picture and fit the screen.
Mar 24, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My tv shows 480 i all of a sudden and i cannot find where to set it to 1080, i've changed view mode to s stretch, zoom, stretch and the display still shows 480
The TV will show the resolution of the video source is the TV is being fed with, you do not adjust the resolution at the TV. Check your video source. It works the same way as the PC monitor, you set the display resolution at the PC not at the monitor.
Dec 05, 2009 | Televison & Video
I have a ViewSonic N2635w LCD TV and the picture looks so stretched out width wise. I don't see anyway to fix the picture with the remote. How can I change the picture to look normal?
there should be something in the menu where you adjust things. seems as your in wide mode or zoom mode. should be something there to adjust the picture.
Jun 10, 2009 | ViewSonic N3735W 37 in. LCD TV
TV will not stay in Stretch Mode
I know of no solution for this, it is the normal operating mode of the system.
Jun 28, 2017 | Philips Magnavox 51MP392H Rear Projection...
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
The picture on my Daewoo DTQ-25S3FC is stretched
bad electrolytic capacitors vertical circuit. need tech.  not worth repair. guess100.00   not easy repair.
Dec 03, 2008 | Daewoo DTQ-25S3FC 25" TV
Vertical Stretch
You need to adjust "vertical height" in the service program. You need to put the set in "service mode" to do this adjustment. If you google "enter service mode RCA F32665" you should find the procedure. It will be listed in abbreviated letters such as VERT SIZE or VERT HT. Follow the instructions for entering service mode and saving the data closely!! The data you change will be listed as a number between 1 and 63. The number will only need to reduced by a small amount and you can still see the picture behind the data and watch it shrink as you adjust the number down.Always burn the new number to memory (if required) before exiting service mode. Good luck
barneyluc
Dec 01, 2008 | RCA F32665 32" TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
