Question about Moen Plumbing
Forgot the faucet I have is the moen motionsense. How do I fix the leak and make sure handle stay up. Nothing but problems! Thanks anyone Cheryl
jj505
  • 195 Answers
SOURCE: Loose handle on my Moen single handle kitchen faucet
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Posted on Apr 06, 2009
frcs68
  • 1605 Answers
SOURCE: hot and cold backwards on a moen shower faucet
tun off the water.
unscrew teh allen screw under neath the handle. pull out hteh handle. undo the wall plate and gain access to the cartridge in the handle body. turn the artridge around 180 degree and reisntall all parts.
1stBSP
  • 52 Answers
SOURCE: I have a Moen Single Handle kitchen faucet, it's
Replace the "O" rings that are behind the spout portion. You will have to remove the top of the faucet and pull up on the spout section. There will be a couple of "O" rings there. It is best to have Moen send the parts to you as locating the proper size "O" rings can be difficult.
Posted on Apr 06, 2010
SOURCE: handle won't stay up
I did the same thing recently, that is replaced the cartridge on my moen kitchen faucet to stop and leak, and I also have the same problem. I called moen back and they sent me another cartridge that was supposed to fit tighter, I suppose. I just put the new one in and it still wont stay up. I'm going to call moen one more time and then I guess I'll have to buy another faucet, but NOT moen!!! Good luck with yours.
Posted on Jul 22, 2010
  • 1015 Answers
SOURCE: How do I repair a dripping Moen M4600 (1978)
First shut off water supply and remove cover on top of handle.They generally just snap in place so you can remove with screwdriver or knife point. Remove screw in center of handle and pull handle off. There is a copper retaining clip that holds cartridge in place. It has a small hole in the center on top that you can insert scratch awl or other pointed tool in and pull straight up to remove.You can try to grasp center stem of cartridge with pliers and pull up to remove. If the cartridge has not been changed for a long time it may be very hard to remove.
You are going to have to replace the entire cartridge so you should have one on hand and you can purchase a tool made especially to remove moen cartridges.Just follow direction that come with cartridge or tool and remove cartridge. I would use the brass cartridge as I have not had good results with the plastic ones. When you get old cartridge out I would use a small amount of faucet grease or petroleum jelly to lube o-rings and then reinstall new cartridge and clip,handle,screw,and cover. Good luck and thank you.
Posted on Dec 28, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Motionsense stopped working on faucet. Replaced batteries and reset. Still not working. It was installed in Feb of 2014. Any suggestions????
    Contact the person that installed it, it should be under warranty. A quick check would to be sure the batteries are good and installed properly.
    Jun 16, 2014 | Moen 7594ESRS Single Handle Kitchen Faucet...
    Handle dome keeps coming off
    Sounds like the setscrew that holds it on has either worked lose and is missing or is striped and no longer tightens properly. Replace set screw if missing and or replace set screw if the set screw is striped. If the threads are stripped in the faucet body the faucet itself will need to be replaced. This usually does not fall under Moen's warranty guidlines.
    Mar 29, 2014 | Moen 7594EC Arbor Single Handle/Hole...
    No water
    No water, there is a host of problems that can cause this.
    1. no water to the faucet
    2. Sensor is not working
    3. clogged water port
    4. Dead battery for sensor
    Does the faucet work on manual mode?
    If not remove cartridge and check for debris. Flush out faucet before replacing cartridge to make sure water is getting to faucet. Replace cartridge. Check debris screens on pull out handle. There are a number of other things that could be wrong but first try the simple and report back on your findings.
    Mar 20, 2014 | Moen 7594ESRS Arbor Single Handle/Hole...
    How do remove the faucet cover of a moen 7594EC
    MOEN Motionsense Faucet Leaking????
    Turn off the water valves beneath the sink. Cover the openings to both the drain and the garbage disposal. Use an allen wrench to remove the tiny screw holding the handle in place. Once the handle is removed, the leaking is most likely from the seams around the large plastic nut behind the metal-like plastic cover. You might be able to see water dripping from around the big nut. Remove the nut and wrap nylon plumber's tape (Costs probably around a buck at any hardware supply store) around the threads for a much better seal. Wrap the tape tight at least a couple of times around the threads.
    Screw the nut back into place with your hand, then tighten with a wrench.
    Place the cover back over the assembly, install the handle. You can apply clear nail polish on the threads of the tiny allen screw that holds the handle in place to minimize the risk of it coming loose and falling into your garbage disposal.
    Jan 19, 2014 | Moen 7594EC Arbor Single Handle/Hole...
    Handle won't stay up
    Jun 05, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
    Kitchen faucet handle won't keep consistent flow
    Is this a Moen???
    Apr 07, 2009 | Moen Monticello Single-Handle Kitchen...
    Single handle pull out Franke faucet stopped working
    Apr 05, 2009 | Franke Plumbing
    Own a Moen 87888 kitchen faucet. The handle has gotten wobbly. How do I fix this?
    Mar 10, 2009 | Plumbing
    Plumbing Logo
    35 people viewed this question
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
