Question about Fagor Washing Machines
Hi my Fagor washing machine comes up with fault code F08, but this is not in the book
  • 3 Answers
SOURCE: Samsung Washing machine fault
Had the same problem - I posted full description in another 4E post - But my problem was a crack.split in the pipe to the sensor
Posted on Jul 11, 2008
ginko
  • 19396 Answers
SOURCE: hi, on my WAE8987 Washing machine, the fault code
Bauknecht are built by Whirlpool.
F7 on Whirlpool means flow meter failure.
Check water inlet, check the pressure switch, and check the sump filter at the bottom of the dishwasher.
To reset try turning on the power and holding the start button and the + and - buttons at the same time.
Posted on Dec 02, 2009
SOURCE: error F08 on a fagor washing machine FU-6146
F08 on my FAGOR means a new motor is required we've had 3 failed motors in the past 2 years , total rubbish machine , would never buy FAGOR again . Mr M Freeman.
Posted on Mar 06, 2010
blueextc3221
  • 15935 Answers
SOURCE: My Fagor washing machine wont empty
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
sodeep
  • 3267 Answers
SOURCE: reset error code F08 in
Error code F08 is indicating that the heater relay is not being activated.
You need to check all the connections on the module, the pressure switch, and the heater element.
Posted on May 28, 2011
Washing machine.. Whirlpool red service light has come on and fault flashing is f08. Any one experienced this or knows what I'm in for?
You need to give your Model number to get the exact codes for your machine. Google the machine name with the model number and "washing machine codes" at the end and look at the resulting websites.
Jan 02, 2013 | Washing Machines
F-05 MESSAGE HAS COME UP ON MACHINE WHAT DOES THIS MEAN?
hi have a look below hope this helps, then goggle how to fix it!
Sep 06, 2011 | Hotpoint Aquarius WD640 Front Load...
Showing F01 error code on readout? what does that mean?
Hi.
It depends on the model. On Whirlpool built machines F01 is EEPROM error, pump drive error, or main relays error.
With Hotpoint F01 means defective triac or defective motor.
Aug 18, 2011 | Washing Machines
Hi I have a hotpoint wf630 washing machine and it keeps flashing error codes f08. Could you tell me what this codes means. many thanks, Stuart
Most Hotpoint, Ariston and Indesit (who make the other two) use similar fault codes. Although I cannot confirm it on your particular machine, f08 means there is a problem with the heater/its relay/its control. Often a cure is to re-seat the cables/wiring to and from these items.
REMOVE POWER BEFORE ATTEMPTING ANYTHING OF COURSE.
Good luck,
John C
Mar 09, 2011 | Washing Machines
What does "f08" mean on
The error F08 indicates that the heater relay is stuck. This could be a fault with either the pressure switch, heater or the module connections.
Think you need to book a service call from engineer.
Feb 06, 2011 | Hotpoint Ultima WF860 Front Load Washer
Fault code '' F08'' what does this mean
The fault code F08 means that the heater relay cannot be activated. I would you check heater, and the thermostat for a fault. Replace them if required.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 05, 2009 | Kenmore Elite 45986 Front Load Washer
Hi our washing machine keeps displaying error code f12 and will not go on does anyone no what this means carolyn
F01 - Short circuit motor triac - Book a washing machine repair. F02 - Motor jammed tacho detached - Book a washing machine repair. F03 - Wash thermistor open/short circuit - Book a washing machine repair. F04 - Pressure switch jammed on empty - Book a washing machine repair. F05 - Pressure switch jammed on full - Book a washing machine repair. F06 - Program selector error - Book a washing machine repair. F07 - Heater relay stuck - Book a washing machine repair.  F08 - Heater relay cannot be activated - Book a washing machine repair.  F09 - Incompatible eeprom - Book a washing machine repair.  F10 - Pressure switch not sensing correctly - Book a washing machine repair.  F11 - Pump cannot be activated - Book a washing machine repair.  F12 - Communication error - Book a washing machine repair.  F13 - Dryer fan or dryer thermisotor faulty - Book a washing machine repair.  F14 - Dryer element faulty - Book a washing machine repair. F15 - Dryer element relay faulty - Book a washing machine repair.  H20 - Not fillings. Check tap, hose and inlet valves LOCKED - Check interlock - Book a washing machine repair.  Here is a list of fault codes. I hope this helps !
Nov 21, 2009 | Hotpoint Aquarius WD640 Front Load...
Fagor Integrated Washing Machine FWM714IT error message F08 how can this be reset?
After inspecting and cleaning the pump filter, unplug unit for 20 minutes
Nov 07, 2009 | Washing Machines
Error F08 on a fagor washing machine FU-6146
Jul 14, 2009 | Washing Machines
Washing Machines Logo
79 people viewed this question
Top Fagor Washing Machines Experts
Vernon Taylor
roeb
Are you a Fagor Washing Machine Expert? Answer questions, earn points and help others
