Question about Plumbing
Same problem has timdatoolman. My faucet is leaking heavily from bottom of handle? Nothing about repairing this problem in the booklet INS10136-7/12 CHERYL
arealplumber
  • 33 Answers
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Posted on Dec 05, 2008
  • 14 Answers
SOURCE: water leaking from tap when turned off
In order to remove the Danze handle from this particular model grasp the handle of the valve and then the body of the valve and turn the body counter clockwise in order to remove.
Hope this helps.
If you don't have a supply house near you that carries parts for the Danze products you can go to danze.com and order them there.
sanray
Posted on Jan 03, 2009
  • 148 Answers
SOURCE: Kohler Forte Single Handle Faucet Leaks
you will have to replace the ball assembly with a repair kit
1 turn the water off under the sink (hot and cold)
remove the handle ( you may need an allen head wrench to remove a hex screw or you may have to take a channel lock pliar and unscrew achrome
nut over the ball mechanism
after the handle comes off there is usually some type of lock nut that you must remove to remove the ball mechanism
remove the ball (usually chrome or brass(ther are usually little springs and rubber washers under ball
take ball and washer to ACe or lowes and match the pieces (usually sold as a kit
follow directions and installl
turn water on and pat yo!ur self on the back !
Posted on Jan 05, 2009
  • 659 Answers
SOURCE: trying to remove handles on grohe 31054000
I couldn't find the number you have on the Grohe website so I have included a link to their website. Just find your model and it will give you many different options for manuals. Hopefully this will give you the information you are needing.
http://www.grohecatalog.com/category/1/
Posted on Apr 12, 2009
  • 4 Answers
SOURCE: Leaking Delta kitchen faucet dual handle
Pry the hot/cold button off the top of the handle. Make sure the water is turned off below the sink.
Under the button should be screws. Remove the screws. Pry the handle off. Remove the stems by lifting then out.
That should give you access to the washers you need to change.
Posted on Jun 13, 2009
Faucet is leaking
Hi Cindy you don't say where it leaking from so:
If you have a dripping that won't completely turn off then the stem washer needs replacing. If it is leaking at the handle then the "O" ring is bad.
I suggest you just replace both.
Under your sink turn off the two water supply knobs
remove the handle. Either a screw on top or and allen screw under and on the side then pry up. this maybe hard so wiggle it.
now take a crescent wrench and unscrew the stem
you see a washer screwed to the bottom. Most likely a "OO" size and a rubber "O" ring around the stem.
Take it the stem to your hardware store and have the give you a repair kit. very cheap
replace both and reinstall.
I it has 2 handles do both sides
Its easy.
Hope this helps Mike
Jan 17, 2016 | Moen 87530 Touch Control Single Handle...
Tip
How to repair disc-type faucets
DISC-TYPE FAUCETS
  • Disc faucets may have one or two handles. The water is controlled by openings in the two discs. When the discs are rotated to align, the water flows; when the discs are misaligned, the water shuts off. If the discs wear, the worn discs cause the faucet to leak. Simply turning the handles harder will not stop the leak.
  • To repair a leak in a two-handle disc faucet, turn off the water and remove the handle on the side that's leaking.
  • Use pliers to pull the disc assembly out of the faucet.
  • Beneath the disc unit is the seat assembly, or seal. Replacing this special O-ring may stop the leak.
  • You may need to install a whole new disc assembly for faucets that have been used over a long period of time. In this case, all moving parts of the faucet will have been replaced and should last as long as the original discs did. The parts of some disc units snap apart into a separate bonnet assembly and bottom cap.
  • To repair a leaking single-handle disc, turn off both the hot and cold water and remove the handle to expose the disc assembly. Take out the screws to lift the assembly out of the faucet.
  • You'll notice that beneath the disc unit are three O-ring seals. Though unlikely, water could be leaking between the unit and one of these seals. In this case, you may be able to stop the leak by cleaning the disc assembly and faucet body and installing a new set of seals. If that doesn't work, the entire disc unit must be replaced. This will renew all moving parts.
  • Replacing the unit is fairly simple. Place the three O-rings into their recesses in the bottom of the disc unit. Then install the unit and tighten the screws. Finally, replace the handle–and you're done!
on Jan 16, 2010 | Plumbing
How to repair a Single handle faucet leaking at the spout end of flex hose.
Who is the faucet manufacturer? What is the model of the faucet?
Nov 29, 2014 | Plumbing
My bathroom faucet drips. How do I repair?
there is a seal in the valve assembly that is warn they usually dell kits for it from a hardware or home depot store
Sep 11, 2014 | Plumbing
How do you repair a leaky centerset Kohler forte fauset
That faucet has a lifetime warranty. Call Kohler (1-800-4-Kohler) and tell them you need a new cartridge for a K-10270 faucet.
May 01, 2014 | Kohler Forte Two Handle Centerset Lavatory...
Leaking faucet
Secure your water
Determine the cause of the leak
Change the Seal on that side (Double Handle)
Change Cartridge on Single Handle
Nov 20, 2012 | Delta Faucet 2100LF Classic - Double...
Leaky eurostream kitchen faucet
if its leaking under the handle, all you need to do is remove the blue and red cap on the handle under you will find a 1/8 allen screw, loosen screw and remove handle and tighten the brass nut a little which will seat the packing underneath.
Jun 19, 2010 | Plumbing
Water leaking from the faucet onto the countertop.
http://docs.homeclick.com/PE-Links/Rohl/Rohl-A3608-specs.pdf
Check out this web site and it looks like it should be a o ring at the base, anyway I hope this will be helpful.
It has a breakdown of faucet internal parts.
Jun 04, 2010 | Rohl A3608LMPN Single Lever Country...
Apr 25, 2009 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Repair leaky handle
Try removing cap of knob and tighten screw it could be loose. If that is not it it may need a new seal ring.
Apr 21, 2009 | Plumbing
Plumbing Logo
93 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
