Question about Cell Phones
My Nextbook (Nxa8Q...) Is soooo slow, performed fine in beginning, but even after factory reset now hardly performs at all n when it doesn't time out, takes forever to process a button press
JustAskMe
  • 29 Answers
SOURCE: no response to sylus taps
Hi Try This Squeezing the Axim gently in normal holding position Placing the Axim in the sync cradle (I have no clue why this works) Doing a soft reset Shutting it off and leaving it alone. Then Re-Starting it. The Axim, despite its size and weight, is not as rigid as it should be. If the case flexes far (or often?) enough, you'll get the "not responding to taps" issue. If you have the problem now,call Support, and get an exchange. Don't worry about getting a refurb. I use lots of refurb equipment, and they are no more or less likely to fail than new equipment. Note that if you continue to flex the refurb's case like your original (I carried mine around in my pants pocket), it will eventually develop the same problem.
Posted on May 04, 2007
SOURCE: rx1950 freeze on soft reset
You can do a hard reset by doing the following...
01) Press and hold down the "Calendar" and "iPAQ Wireless" buttons.
02) While holding down these buttons, use the stylus to lightly press the "Reset" button/hole on the back of the iPAQ until the screen goes blank.
03) Release the "Calendar" and "iPAQ Wireless" buttons.
04) Press the "Reset" button/hole again (so that it resets/powers on.)
Posted on Nov 18, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: Need to perform factory reset
When I worked for Philips, I solved one of these. First, try unplugging the unit from the wall outlet for one full minute and see if that alone will reset the unit/restore it to defaults. If not, make sure you have a yellow video connector running from the Bose to your TV rather than another type of video cable - change the tv to the appropriate source channel - now see if the menu will appear. If not, you will have to fly blind (don't mess up): Press the System button, then the right arrow by the Enter key twice, then the down arrow by the Enter key five times, then press Enter. Defaults (including NTSC) will now be restored.
-Tha Mp3 Doctor
Posted on Dec 30, 2008
  • 8 Answers
SOURCE: HP iPAQ 2490B can not be hard reset
If all else fails, remove battery from unit & let completely run down
(usually 12-24 hours), possibly longer.
Pop on charger, & unit should turn on as if hard reset
Posted on Jul 11, 2009
SOURCE: how do i perform a hard reset on my tomtom xxl 540
For the TOMTOM XXL540 while connected to your PC hold the poer button down for about 15 or 20 seconds the device will shutdown then restart when reset
Posted on Jul 19, 2010
Why does my nextbook keep asking me if I want to put it in safe mode?
The device went into safe mode because the app that you downloaded was not a safe application. The device does this so that the application cannot cause more problems to your device. Even though the app was downloaded from the app store it was not deemed safe by your device. Here are some tips that will help you to get your device out of safe mode: -Ensure that if you have a case on your device that you take it off being that the case may be holding the volume button causing you to boot into safe mode -Try turning the device off then back on to get out of safe mode -Power off your device, then reboot by holding the power button + volume up key, then in the boot menu select reboot device -This is sometimes caused by the users accidentally tapping safe mode when cutting the device on so simply restart your device Most users have success by simply restarting the device in order to be able to get out of safe mode. Do your best to restart or reboot your device before you have to perform a hard reset to get the app off of your device to no longer go into safe mode In order to hard reset -Power off device -Hold down volume up + power -Release at the boot menu -Use the volume keys to highlight factory reset -Press the power button to select factory reset -After this the device will begin to reset itself -After it resets itself use the volume keys to highlight reboot device -press the power button to have your device rebooted in its factory settings
Apr 20, 2016 | Nextbook Tablets & eReaders
How do I get my nextbook tablet out of safe mode?
Nov 04, 2015 | Nextbook Tablets & eReaders
My nabi dreamtab wont reset why?
There are two types of resets that you can perform on nabi - forced reboot and factory reset. In the unlikely event that your nabi becomes unresponsive, you can easily perform a forced reboot. A factory reset is recommended when slow performance persists or if you want to wipe out all of your personal data and settings from nabi. Forced Reboot: To perform a forced reboot, hold the Power Button down until nabi turns off. When nabi is off, press the Power Button to turn on nabi again. Factory Reset: Caution! A factory reset is a very serious process because it will SYSTEMATICALLY WIPE ALL USER DATA from nabi. A factory reset will return nabi to its original factory settings.To perform a factory reset from Mommy/Daddy Mode, tap All Apps > Settings > Backup & reset > Factory data reset > Reset tablet > Erase everything. Please note: We highly recommend backing up your nabi prior to performing a factory reset. You can back up your music, videos, photos and apps with nabiā„¢ Sync.
Dec 20, 2014 | Tablets & eReaders
My Samsung intercept won't load past the flashing Samsung so I was trying to factory hard reset it and it won't even do that I attached a photo of what it says
Hi Latonya,
When a Samsung cell phone becomes unresponsive or when the device slows to a crawl, a reset may be in order. There are two primary methods used to reset the phone. Users should always start with the soft reset when the phone locks up or programs slow down due to memory or software response issues. A soft reset is akin to a reboot of the machine and usually solves most problems without any loss of user data. A hard, or master, reset is required when the phone completely locks up and becomes unresponsive to any cellular signals. This second and more drastic reset deletes all personal data, preferences and settings so that the device is restored to the original factory configuration.
Perform a Soft Reset
Step 1 Press and hold the power button for 10 to 20 seconds.
Step 2 Release the power button and tap the "Power Off" option under the "Device Options" menu that appears. Tap "OK" to initiate the shutdown.
Step 3 Press the power button again to restart the device.
Perform a Hard (Master) Reset
Step 1 Tap the "Menu" key from the home screen and then tap "Settings."
Step 2 Go to "Privacy" and tap "Factory Data Reset" to review the Factory Data Reset information.
Step 3 Review the Factory Reset options. Place a check next to "Format USB Storage" to clear your device of user data, such as music, pictures and other account settings.
Step 4 Review the disclaimer and verify your changes before tapping "Reset phone."
Step 5 Tap the "Erase Everything" or "Yes" buttons to confirm the reset the phone to factory settings. The device initiates the restoration process to the original factory configuration.
Perform an Alternative Soft Reset
Step 1 Power off the phone. If the phone does not turn off, remove the back cover of the phone and take out the battery. Wait between 10 and 30 seconds and then replace both the battery and the cover to restart the device.
Step 2 Simultaneously hold down the power/lock keys.
Step 3 Release the keys when the Android screen appears.
Apr 28, 2014 | Cell Phones
How to do a factory reset on my motorola blur cause I bought it but the lady did not erase her accounts so the phone is all lock
if the phone is locked you can perform two things one is factory reset for that you have to go to settings and then privacy settings and the factory reset..that will factory reset your phone. and if your phone is completely locked and you cant even get to properties then..you have to perform the hard reset.switch the phone off....then press the power button along with volume up button and press both the buttons for some time. phone will start hard reset again..then in some time it will ask you to press power botton and volume up botton again..and you phone will start hard reset.but it can take some time. :)
Apr 16, 2012 | Android Apps
Whenever I print my document, it doesn't exist the document I want to print but many strange symbols appear on the printed paper, how can I solve this problem?
Cold reset
A cold reset changes most system parameters in NVRAM to the factory defaults. However, unlike NVRAM inititialization, a cold reset does not reset the page count, the paper tray sizes, language, or formatter number.
Note If an HP Jetdirect card is installed, remove it before performing a cold reset. Otherwise, the procedure will also reset all the HP Jetdirect settings as well as the printer settings.
To perform a cold reset
1 Turn the printer off.
2 Press and hold down the GO button.
3 Turn the printer on, and continue to hold the GO button for at least 5 seconds, but not longer than 15 seconds. During this process, the Attention LED will turn on.
4 Release the GO button.
Note If both the Attention and the Ready LEDs turn on before you release the GO button, you must start the procedure again with step 1.
5 The printer's LEDs will begin cycling. The cold-reset process will
run until completion, and the printer will return to the ready state.
If not work, tris this
NVRAM initialization
CAUTION Only perform the following procedure if absolutely necessary.
Performing an NVRAM initialization resets some parameters that cannot be restored later.
NVRAM initialization sets all default variables stored in NVRAM back to factory default values or to a default ROM value, depending on the variable. It also performs a system reset.
NVRAM initialization resets the following:
  • all menu settings to factory default values
  • factory settings such as formatter number, page counts, and factory paper settings
To perform NVRAM initialization
3 Turn the printer on, and continue to hold the GO button for at least 20 seconds. During this process, the GO button, Attention, and Ready LEDs will each turn on.
5 The printer LEDs will begin cycling. The NVRAM-unit process will run until the printer is in the ready state.
Jul 30, 2011 | HP LaserJet 1300 Printer
My phone has had to many pattern attempts and i cant rember the google password or username how can i reset my phone ?
Performing a Normal (Soft) Reset on a LG Optimus GT540 A normal reset is sometimes referred to as a soft reset. A normal reset stops all running applications but does not erase any programs or saved data.
Caution be sure to save any unsaved data before performing a normal reset since a normal reset erases all unsaved data.
To perform a soft reset:
  1. Press lg_optimus_hard_reset1.jpg > lg_optimus_soft_reset.jpg > Settings > Privacy > Factory data reset.
  2. If you are certain that you would like to restore all factory settings, tap Reset phone.
Performing a Hard Reset on a LG Optimus GT540 A full reset is sometimes referred to as a hard reset. Perform a full reset when you want to clear all settings, programs and data from RAM.
Caution if you perform a full reset, your LG Smartphone returns to its default settings and looses all information that is not recorded in ROM.
(CAUTION! If you perform a factory (full) reset, all user applications and user data will be deleted. Please remember to back up any important data before performing a factory reset.)
To perform a factory (hard) reset:
  1. Turn the power off.
  2. Press and hold the following keys for over 5 seconds: Down volume key + lg_optimus_hard_reset1.jpg + lg_optimus_hard_reset2.jpg .
  3. When the power turns on, release these keys.
May 13, 2011 | LG GT540 Cell Phone
Facory reset for palm pixie
If you want to clear all data off your Palm Pixi and begin again with factory defaults, you can perform a hard reset on the smartphone.
1. Open Device Info.
2. Tap Reset Options.
3. Tap Full Erase two times.
Jul 11, 2010 | Palm Pixi Cell Phone
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
