Question about Garden
Solution to the mower engine using oil
Have about 1and 1/2 acres to mow, my 18ohv uses about a quart per each mow, no leak observed, any thoughts?
    An user who is expert in 3 categories / brands.
  • Garden Master
  • 924 Answers
Is it smoking? if its not leaking it, it must be burning it. could be the valves or rings
Posted on May 12, 2017
I have a 2006 Cub Cadet Push mower with a 5.5 160cc Honda Engine. I have never had any problems till last week. The engine started racing while mowing. I stoped the engine and checked the oil and air...
Replace engine, only 1 yr. warrenty. Engine about $119 at Harbor Freight. Easy to change out. all Harbor Freight engines are Hondas. Bolt pattern same. 160cc or 190cc will work. Remove blade, remove mounting screws, replace engine. Carb may be the same for throttle connections. Reinstall blade. 10 pulls required to start engine 1st time. 1 pull after that. Pull 1/2 way 4 times 1st to prime even if you use the primer bulb. Ensure oil is full, 30w oil. Excellent engines good for 7-8 yrs with proper maintenance. Observe cable connections before old engine removal. Take pics.
Sep 14, 2012 | Troy Bilt 5.5hp Self Propelled Mower
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
I have had my Poulan Lawn Mower for 4 years. The model number is 961320020. As I was mowing the lawn today, I thought that it might be running a bit sluggish and it dawned on me that I had not ever added...
Four years without adding or changing the oil?!
I think that was the problem right there.
Mowers need oil changes to protect the cylinder walls and valve guides every 25 hours of operation. Thats usually about one season if your yard is under an 1/3 of an acre.
Your mower ran on almost no oil for the last two years. The normal lawn mower only holds 20 ounces of oil. You topped off with 16 ounces! The four ounces still in the motor were probably so full of dirt and metal particles that it was grease! Which is no help to an engine that gets its lubrication by splash oiling.
Your mower should be oiled with 30 weight non detergent oil. Multi Vis oils are for engines with tighter machined tolerances. Your oil choice is going to go right past the piston rings and valve guides creating gobs of smoke! Go get some 30W ND oil at your parts store and put it in....but run the mower first so you can clean out all the gunk in the oil sump. Run it long enough for the oil to flow easily.
Once you put in the right oil you can run it and try to clear out the remaining multi vis oil.
If it keeps smoking...I would say you have permanent damage to the cylinder wall or valve guides.
Good luck and be careful!
Jun 24, 2010 | Poulan Pro " Pro" Self Propelled Mower
Uses approx 1 quart oil to mow roughly 2 acres, not high grass, no hills, loses compression
sounds like the rings are bad on your piston. you can inspect the cylinder and see if it has any grooves in it by removing the spark plug and the plate it screws into. If you do this you will at leas have to buy a new gasket if you pull off the plate.
when my toro did this it burned through a quart in the time it took me to mow my 1/4 acre city lot. I didthe above and my cylinder had a groove dug into the cylinder. The cylinder was going to cost me $267 and a new motor was $250. Doesnt make much sense does it?
Oct 14, 2009 | Toro Lawn Mower With Toro Power Tools
1997 Yamaha YZF Thunderace uses 1/2 quart of oil every 200 miles
Replace standard rings with GTS1000 rings . I had Fzr1000 with same problem , at 187000 kms I pulled the barrels off and found no hone left , it was a smooth bore . Also replaced valve guide seals at this time also . Oil consumption dropped from 1 litre per 1000kms to 1 litre per 8000kms. Bike has now done 308000kms and still uses oil at the rate of 1 litre per 4000kms .
Aug 11, 2009 | 1997 Yamaha YZF Thunder ace 1000 R
Oil leaking way to much
It is a leaking valve cover gasket (easy fix) or the gasket between the head and crankcase ( most likely but much harder to replace). Check the valve cover gasket first.
Mar 16, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Cutting size question
* f your yard is up to an acre in size, the ideal cutting width is 30-42" (76-106cm). To avoid being underpowered, or putting too much strain on the engine, make sure your mower or tractor offers a minimum 14 horsepower. Riding mowers are the most commonly purchased for lawns this size. * For a yard that is between one and three acres, you’ll reduce your mowing time with a cutting width of 42-46" (106-116cm) and a strong engine up to 16 HP. Typically people purchase lawn tractors for yards of this size. * If you’re mowing more than three acres, you’ll need to look at the garden tractors, with cutting widths up to 54" (137cm) and at least an 18 HP engine, preferably bigger.
Aug 27, 2008 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
