Hi, My new WD40FW1610 TV internal speakers not working ... volume is at maximum and is not muted. I use a HDMI cable from my lap top. This is the second cable and the problem persists.
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Posted on May 12, 2017
My t v has no volume
Do you see the volume indicator moving when you press the vol up/down?
Could the internal TV speakers have been turned off? This is done when using a sound bar or a AVR (Audio Video Receiver) aka Home theater
Mar 03, 2015 | Televison & Video
I am getting no sound out of my Panasonic Viera TH-50PX80U Plasma TV
Are the speakers' cables connected correctly? (p. 37) Is "Sound Mute" active? (p. 13) Is the volume set to the minimum? Is "Speaker output" set to "Off"? (p. 22) Change "SAP" settings. (p. 16) Check "HDMI 1 in", "HDMI 2 in" or "HDMI 3 in" settings. (p. 22)
Hope this helps, page# refer to your manual.
Feb 14, 2015 | Panasonic Viera TH-50PX80U Plasma TV
How do you un-mute tv settings
Try pressing the mute (speaker symbol with diagnol line) or just press up/down volume button
Sep 08, 2014 | Televison & Video
Volume problem--laptop to tv
I'm confused, are you trying to use a VGA cable for both video and audio? VGA cables don't have sound built into them, nor do DVI. If you had an HDMI plug on your laptop it would be best to go with that since HDMI contains video and audio.
You could just use an Aux cable from laptop to TV. Pretty much it would be a aux to analog type. It's like a speaker plugin, that side is for your computer. Then the other side coming out would be an analog red/white or left/right cable.
Another one, if your TV supports pure aux cable (it's a 3.5MM jack that speakers plug into) Like, my tv has a built in aux port for audio for my computer. So I just use pretty much a standard cable to cable setup.
Feb 24, 2013 | Toshiba Satellite Computers & Internet
When I connect my laptop to my tv with an HDMI cable the video works but the sound comes out the laptops speakers. How do I get sound to the tv?
What operating system are you using? If you are using Windows 7, right click on the Volume icon on the system tray and select "Playback Devices". A window would pop up showing you speaker and HDMI. Select HDMI and then choose the "Set Default" Button on top of the OK button. Thats it! If you want the sound to come out of the laptop again when you disconnect the HDMI from your TV, you have to do this again, then choose the speakers.
Cheers!
Mar 01, 2011 | Vizio 42 in. LCD TV
If hdmi cable sends audio and video info from my laptop to my tv why can't I hear anything? I have video but no audio. the Audio all say hdmi/high def audio and are working properly
Have you "muted" the sound on your computer?
Have you "muted" any of the outputs (MIDI, speaker) on your computer?
Have you "muted" the sound on the TV's built-in speakers?
Have you "muted" the sound on any external speakers that are connected to your TV?
Does your TV have _more_ than one HDMI port? Have you tried them all?
Got a friend with a TV with a HDMI port?
If so, connect your laptop via THEIR HDMI-cable to their TV.
Also, connedct your laptop via YOUR HDMI-cable to their TV.
Jan 09, 2010 | HP Pavilion dv5-1002us Laptop PC
No volume control
Thank you for bringing up your concern. Here are few tips you can apply to solve the volume problem on your TV.
You may try checking the volume setting on the TV. Then, check for a speaker on/off in the menu or on the back of the TV set (it also might be labeled internal/external, since some TV set manufacturers meant their TVs for home theater).
Also, if you're using a cable or satellite set-top box, DVR, or other device, check the audio connection. If you're using HDMI, make sure that HDMI audio out is enabled on you set-top box
Best Regards,
Jazerblue
Aug 24, 2009 | Emerson LC320EM9 32 in. LCD HDTV
TV blanks out..."pcm" light flashes on receiver
You need to Bypass the Receivers HDMI port and use HDMI directly to the TV. Your receiver has HDMI version 1.2a and is not 100% effective. Use the optical out from your Xbox to the receiver and all will be well. 1.2a has issues in every receiver on the market. Supposedly 1.3b on the "new" receivers has fixed this issue. Hope this helps
Aug 12, 2009 | Yamaha RX-V663 Receiver
Compaq wf 1907 monitor speakers--no sound
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start c01292216.gif , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
Jan 03, 2008 | HP Compaq WF1907 Monitor
Televison & Video Logo
Top Televison & Video Experts
