Question about Drive Health & Beauty
I have a power chair and when i turn it on it say set drive config but wont let me move it set drive or anything
5 Suggested Answers
mas Didiet
  • 17 Answers
SOURCE: power problem
Please check the connections on motor.May be they have bad connection.
Posted on Nov 28, 2008
dromtonpa
  • 40 Answers
SOURCE: lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
Posted on Mar 30, 2009
wcdoc1953
  • 280 Answers
SOURCE: i have a quantum 600
Sounds like you need new batteries. Assuming that the chair is programmed for a faster speed and has gone faster in the past the most likely culprit is old or discharged batteries. The charger or plug may be at fault also. Also check that the charger is plugged in and the indicator lights of the charger are on.
Posted on Oct 24, 2010
HoverTech
  • 232 Answers
SOURCE: Battery fully charged chair levers engaged to
Has your scooter been sitting idle for several weeks, or has it been connected to the charger 24 hours a days for a long time? If so, the batteries may have become damaged and will give you enough power to turn the controller on but not enough to make the motors run.
If the lights come on and are steady, the manual brake levers are in the drive position and the chair still will not move, I recommend replacing the batteries. If anything else were wrong, either the lights would flash or not come on at all.
I hope this information is helpful to you, good luck!
Posted on Dec 27, 2010
What does my tss300 power indicater keep flashing left to right but won't move. batteries are fully charged and reset is set?
The chair is more than likely in free wheel. There are two levers under front of the seat (yellow). Pulling them forward should place the chair in freewheel and pushing the levers back should place the chair in drive. Once in drive mode, turn power on to reset joystick.
Apr 27, 2014 | Pride Mobility Pride TSS300 Power Chair -...
Lights turn on cant move
Be sure the free-wheel \ brake release handles are set to drive\lock position prior to turning on. After that, if chair still does not move, you will need to count the flashes on the joystick to determine the error or issue with the chair.
A user manual can be purchased on ebay.
Nov 11, 2013 | NRS Hoveround MPV 5 - Used Power...
My power chair runs but wont move.
re-engage the motors look for two levers one on each motor and move them to locked position
Oct 21, 2012 | Golden Technologies Alante' Power Chair
Jet 3 ultra power chair won't move
Move the freewheel levers back and forth so the chair does not move drive position
May 25, 2012 | Jet 3 Ultra Power Chair
Battery fully charged chair levers engaged to drive position chair still will not move.. Jazzy 600.... Tried unlock/lock tried putting it in neutral back in drive with levers still wont move please...
Dec 20, 2010 | Pride New Jazzy 600 Power Wheelchair by...
Wheelchair lights are blinking and I cannot move the chair. It did it the other night, and my husband held something down for a little while and it fixed it. He cannot find the resoution n the manual now....
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. Try to reset your system by turning off the power chair, moving the manual brakes from drive to push and then back to drive and turn the power chair back on to see if that clears the problem. If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
Nov 29, 2010 | Invacare Pronto M51 Power Wheelchair
Chair will move forward and backwards OK but either will not turn or will go around in a circle very sharply
one of the motors is bad or has bad connection. try raising the chair so the drive wheels are off the ground (free-wheel) turn power on, push joystick forward and watch for drive wheels to turn. the one that wont indicates a bad motor or connection.
Jul 01, 2009 | NRS Hoveround MPV 5 - Used Power...
Lights just flash on controller and wont move jet 3 wheel chair
Mar 27, 2009 | Pride Mobility Products New Pride Mobility...
Led lights flash and Pride Go chair won't move.
Firstly disengage the drive levers and then "flick "them in fash.
Second pull out the large plug that is between them.
Check for damaged or bent or loose pins. press it home firmly .
I did this on my wifes chair and she zooms around.
All switched etc should be off during charge.
Lastly i fully discharged then recharged the battery to ensure no "battery charge memory".
To fully dicharge i shoved a small box between back wheels so to lift of ground and then a elastic band to hond controler on.
Jan 11, 2009 | Pride Go Chair Travel Power Chair
Health & Beauty Logo
26 people viewed this question
Top Drive Health & Beauty Experts
Colin Taylor
ray gallant
Are you a Drive Health and Beauty Expert? Answer questions, earn points and help others
