Question about Laser Video Game Consoles & Games
Laser wont spin - Laser Video Game Consoles & Games
Sony cdp-c215 wont read disc removed cover disc doesn't spin
The pladder motor that spins the disc is open, or the laser pickup is defective, the whole laser assembly would need to be replaced, not cost effective to repair cheaper to buy.
Apr 16, 2012 | Sony 5-Disc CD Changer with SA-CD Playback
Wont play
If its not a power problem, notice that the servo motor is spinning or trying to spin with a disc in the tray.
-listen carefully for a high pitch or whinning sound of the motor.
-do you have a reading on the screen? No disc or reading disc?
One of the above can be:
1- a defective laser (it wont illuminate)
2- a broken flat cable to the laser (you wont hear clicking sound when reading)
3- a bad servo motor that can not reach its speed to read the disc (has to spin at a very high speed)
Hope you can solve the problem, succes
Aug 27, 2010 | Apex Digital Televison & Video
My disc wont spin. It has all of a sudden just stopped. When I turn it on all the lights come on but the disc just wont spin.
The laser has to detect a game before it will spin the disc so you probbably need a new laser lense.
Feb 06, 2010 | Sony PlayStation 2 Slimline Console
PS2 Slim Disc Wont Spin
Sounds like the laser has gone out. The unit will not try to spin unless the laser can see the disc. A new laser can be picked up on ebay for less than $10
Nov 27, 2009 | Sony PlayStation 2 Slimline Console
My ps3 wont play my games
Hi my name is Juan and I have the best answer you need the problem with your ps3 is the internal bluray laser lens it have stop reading the games some laser they do still play regular dvd's but some nothing they control the spin motor and some lasers they do make the disk to spin but they don't read the disk some lasers don't make the disk to spin at all but the solution for all of this problems is the same all you need to do is replace the laser lens thrust me I am a ebay power seller and I do sell use ps3s and I do fix playstations as well also I do have lens and install them for you if you want me to
Mar 12, 2009 | Sony Playstation 3 (PS3) Console
Ps2 slim line
if the laser is moved to the middle of the area and when you first turn it on it doesn't go back to starting possession's then some thing is wrong with the motor drive more than not it's likely you have a crack in the board.
Jan 03, 2008 | Sony PlayStation 2 Slimline Console
Disks wont spin on new laser
Did you remove the anti static solder blob (point) on your new laser with a soldering iron and solder wick prior to installing it? The symptons your explaining indicate that point is still intact, If so you will need to carefully remove it first then reinstall the laser and try again.
Sep 13, 2007 | Sony PlayStation 2 Slimline Console
Disk wont spin
First of all the new laser lens will not allow your Slim to read NTSC UC games if you have a PAL european Console.
There is no reason the New laser should have not read the disc unless it Came to you damaged. It sounds like you know how to replace a laser.
Ps2 disc wont spin
try loosening the screw to the left of the laser i believe its a torx bit.( i just used a very small flathead). on my broken scph 30001 i used to have to manuallly spin the disk for it to read games so i loosened that screw and lubricated all the tracks with wheel bearing grease(white lithium would be better but i work on cars so it's what i had.
Jul 05, 2007 | Sony PlayStation 2 (PS2) Console
Video Game Consoles & Games Logo
29 people viewed this question
Top Laser Video Game Consoles & Games Experts
James Wishart
Are you a Laser Video Game Console and Game Expert? Answer questions, earn points and help others
