Need to cancel paper. Leaving for 5 months - Office Equipment & Supplies
  • Office Equip... Master
  • 1,830 Answers
Call your paper company that supplies your paper and tell them you wish to cancel.
Posted on May 11, 2017
Green light flashes 7 times
LED Blinking in Orange/Green:
2 times: No paper. (ASF) [1000]; Set the paper in the ASF, and press the Resume/Cancel button.No CD-R tray. [1001]*1; Set the CD-R tray, and press the Resume/Cancel button.
No paper in the cassette. [1003]; Set the paper in the cassette, and press the Resume/Cancel button.
3 times: Paper jam. [1300]; Remove the jammed paper, and press the Resume/Cancel button.
Paper jam in the under guide. [1304]
Paper jam in the rear guide.[1303]
Front door closed. [1250]; Open the paper output tray.
4 times: No ink.[1601 / 1611 / 1612 / 1613]; Replace the empty ink tank(s), or press the Resume/Cancel button. Pressing the Resume/Cancelbutton will exit the error without ink tank replacement, however, ink may run out during printing.
5 times: The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 /1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on.
6 times: Inner cover open. [1841]*2; Close the inner cover, and press the Resume/Cancel button.
Inner cover open (during printing on paper). [1846]*2; Close the inner cover, and press the Resume/Cancel button.
CD-R tray guide closed (during CD-R printing).[1850 / 1855]*1; Open the CD-R tray guide, set the
CD-R tray properly, and press the Resume/Cancel button.
CD-R tray guide open (during printing to paper). [1851 /1856]*1; Close the CD-R tray guide, and press the Resume/Cancel button.
7 times:No CD-R or DVD-R. [1002] After setting a CD-R or DVD-R in the tray, set the tray in the tray guide, and press the Resume/Cancel button.
8 times: Warning: The waste ink absorber becomes almost full (approx. 95% of the maximum capacity). [1700]; Pressing the Resume/Cancel button will exit the error, and enable printing. The service call error, indicating the waste ink absorber is full, is likely to occur soon.
In repair servicing, replace the bottom case unit (QM2-1249), or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864).
9 times: The connected digital camera or digital video camera does not support Camera Direct Printing. [2001]; After removing the cable between the camera and the printer, press the Resume/Cancel button, and
re-connect the cable.
10 times: Automatic duplex printing cannot be performed (paper size not supported). [1310]; Press the Resume/Cancel button to eject the paper being used at error occurrence. Printing will resume from on the front side of the next page.
11 times: Failed in automatic print head alignment. [2500]; Press the Resume/Cancel button, and after confirming the following, perform print head alignment again: - Set an appropriate type and size of paper (plain paper, A4 or letter). - Check that the nozzle check pattern is properly printed (all ink ejected, no faint printing). - Protect the paper output slot from exposure to excessive light.
Access cover open. [1200]; Close the access cover.
LED Blinking in Orange and Green Alternately, or Lit in Orange:
2 times: Carriage error [5100]
3 times: Paper feed error [6000]
4 times: Purge unit error [5C00]
5 times: ASF (cam) sensor error [5700]
6 times: Internal temperature error [5400]
7 times: Waste ink absorber full [5B00]
8 times: Print head temperature rise error [5200]
9 times: EEPROM error [6800]
11 times: Carriage lift mechanism error [5110]
12 times: AP position error [6A00]
13 times: Paper feed position error [6B00]
14 times: Paper feed cam sensor error [6B10]
15 times: USB Host VBUS overcurrent [9000]
16 times: Valve sensor error [6C00]
17 times: Motor driver error [6D00]
20 times: Other hardware error [6500]
Continuous alternate blinking: rom error
Aug 31, 2014 | Canon PIXMA iP2000
My canon pixma ip2000 lights flashing 7 times
LED Blinking in Orange:
Lexmark x5650 paper jam
Basically, you need to check along the paper's pathway through the machine. Paper may well be stuck inside the printer. If you pulled paper out, leaving behind a torn corner, that could be enough to set off a sensor. If there is NO paper inside anywhere, then cancel any remaining print jobs, close all necessary printer drawers, and turn OFF your printer entirely and let it sit for about five minutes. Then try turning it on -- that usually resets it.
Feb 01, 2014 | Office Equipment & Supplies
Login in to my account
you wont get any refund from here. thats for sure.
Jun 24, 2017 | Miscellaneous
I have an epson dx4050 printer, not used it for about 6 months, came to use it and noticed its pulling paper through on right hand side faster than the left leaving the print on the paper uneven and paper...
power the printer down... take the paper tray out.. clean the paper roller.. open and close the printer .. then align the paper tray back.. will work fine.. or else u might need t change the printer.. there's nothing more we can do because inkjet printers are single units no parts are replaceable..
Dec 20, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Need help with an assignment for a college paper. need to specify why hypothetical students made the mistakes in division and what the mistakes are and what feedback could be given. the ex. are 2388...
It would seem to me that the answer was found at a grade 3 or 4 level
If you divide 288 by 4 you get 97. Then the 1 is carried to the 2 leaving 12. 12 divided be 4 is 3 leaving a result of 397.
Second one....
217 divided by 5 is 43.4 or 43 with a remainder of 2.
Leaving 5 divided by 5 equaling 1.
Combining the 1 with the 43 with a remainder of 2 bringing you a total of 143 r2
This as mentioned would be at a grade 3 or 4 calculation with no understanding of how to properly divide.
I hope this helps and gives you the "A" you're looking for.
All the best.
Sep 16, 2009 | Computers & Internet
Have canon mf5700 says check paper size and only prints one page of several page job
go to control panel> printers> and make sure in preferences its set to LTR (letter)
Hope this helps
Dec 21, 2007 | Office Equipment & Supplies
29 people viewed this question
k24674
jasbo
jasbo
