Question about Frigidaire Dehumidifiers
I have a frigidaire dehumidifier model# LAD704TDL ser # KN02503201 DTD 06/10 is it recalled?
5 Suggested Answers
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Frigidaire dehumidifier model # FDL50S1 clicking very loudly.
    If the unit is not running fully, but you have this noise, sounds like the internal fan might be the culprit. Contact your manufacturer for further options.
    Posted on Aug 27, 2012
    • 15557 Answers
    SOURCE: Is there recall on model fad504dwd19 dehumidifier frigidaire
    fad504dwd19 not shown as a recall
    Posted on Nov 11, 2016
    • 34102 Answers
    SOURCE: Is my Frigidaire Dehumidifier on the recall list. Model: FAD704DWD Serial: KN54805467
    Google FrigidaireDehumidifierrecall to find out
    Posted on Dec 01, 2016
    emissionwiz
    • 75797 Answers
    SOURCE: Is my dehumidifier being recalled?
    You need to contact the manufacturer on this.
    Posted on Feb 19, 2017
    Frigidaire Dehumidifier LAD704TDL Trips breaker upon plugging in ---does not light up display and does not come on.
    Hi Walter, thank you for your inquiry. I understand that your Frigidaire Dehumidifier is tripping the breaker. I would recommend checking to make sure that the bucket is installed properly. If everything checks out I would possibly changing the fuse in your home circuit breaker and never use an extension cord. Hope this helps! -JK
    Oct 12, 2015 | Frigidaire Dehumidifiers
    How do I change the filter on my dehumidifier lad704tdl
    The filter on the Frigidaire LAD704TDL is behind the louvered section of the housing above the water bucket. Remove the water bucket by pressing the sides gently to release the bucket from the dehumidifier. Then pull the bucket towards you and use the handle to move it away. Then reach up and pull the filter down. You can wash the filter or replace it with a new one.
    For pictures, see the manual: manuals.frigidaire.com/prodinfo_pdf/Edison/66166042enaen.pdf . The filter maintenance is shown on page 8.
    I hope this helps.
    Mar 09, 2015 | Dehumidifiers
    Dehumidifier does not reduce humidity.
    Good Afternoon Miguel,
    I understand that your Frigidaire dehumidifier, model# LAD704TDL, is not reducing the humidity, due to the coils constantly freezing up. I also see that it is located in good temperatures and in a good position. I suggest contacting the manufacturer directly. They should be able to point you in the right direction to having your appliance fixed. Hope this is helpful.
    -Best Regards-
    WP
    Jul 01, 2014 | Frigidaire Dehumidifier LAD704TDL
    Is there a call back on unit lad704tdl dehumidifier
    Good Morning Friend,
    I understand you are wondering if there is a recall on your Frigidaire dehumidifier, model# LAD704TDL. I see that the bucket is not filling with water when your appliance is running. I don't believe there are any recalls. I suggest contacting the manufacturer for further assistance. They should be able to point you in the right direction. Hope this is helpful.
    -Best regards-
    WP
    Jun 30, 2014 | Frigidaire Dehumidifier LAD704TDL
    My frigidaire dehumidifier isn't not dehumidifying .is the warranty still good
    I understand your Frigidaire dehumidifier, model# LAD704TDL, is not dehumidifying. I also see that it is blowing hot air, no water is coming out of the hose, and the humidity stays at 80%. I suggest contacting the manufacturer directly, to see if your appliance is in warranty, and they should be able to point you in the right direction. Hope this is helpful.
    -Best Regards-
    WP
    Jun 29, 2014 | Frigidaire Dehumidifier LAD704TDL
    The unit runs but will not collect water.
    I understand you Frigidaire dehumidifier, model# LAD704TDL, is running but not collecting water. I suggest contacting the manufacturer directly for further assistance. They should be able to better assist and point you in the right direction to fixing your dehumidifier. Hope this is helpful.
    -Best Regards-
    WP
    Jun 28, 2014 | Frigidaire Dehumidifiers
    Dehumidifier freezes up
    I understand your Frigidaire dehumidifier, model# LAD704TDL, is freezing up. If you have turned on your dehumidifier recently, this is normal due to refrigerant rushing through the coil. Frost will usually disappear within 60 minutes. Try starting your dehumidifier on a slower fan setting. Another possibility is that the room temperature is too low or too high. Your appliance is designed to operate between 41 degrees F (5 degrees C), and 96 degrees F (35 degrees C). I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
    Jun 13, 2014 | Frigidaire Dehumidifier LAD704TDL
    Fridigaire dehumidifier compressor gets very hot and no water in bucket
    I understand that the compressor is getting very hot and there is no water in the bucket of your Frigidaire dehumidifier, model# LAD704TDL. I would check to make sure that your dehumidifier has enough ventilation. There should be a minimum of 12 inches clearance around your dehumidifier. Also, make sure that it is neither too hot, nor too cold where you have placed your dehumidifier. Your appliance is designed to operate between 41 degrees Fahrenheit and 96 degrees Fahrenheit. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dehumidifier status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
    May 28, 2014 | Frigidaire Dehumidifier LAD704TDL
    Condensation on frigidaire dehumidifier turn to ice
    I understand that the condensation is turning to ice on your Frigidaire dehumidifier, model# LAD704TDL. This can be a possible cause of your dehumidifier being turned on recently. This is normal, due to refrigerant rushing through the coil. Frost will usually disappear within 60 minutes. Another possibility is the room temperature is too low. All dehumidifiers will operate satisfactorily at temperatures greater than 41 degrees Fahrenheit. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dehumidifier status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
    May 27, 2014 | Frigidaire Dehumidifier LAD704TDL
    Why will frigidaire dehumidifier model lad704tdl not collect water
    Good Afternoon Friend,
    I see that you are having trouble with your Frigidaire dehumidifier, model# FDF50S, collecting water. First, make sure that there is 12 inches clearance around your dehumidifier. Secondly, the dehumidifier could have been installed recently or restarted recently or possibly there was a power surge. Lastly, check the room temperature. Your appliance will not operate satisfactorily if the room temperature is below 41F (5C) or above 96 F (35 C) degrees. If you are still having trouble, try unplugging your dehumidifier for 3-5 minutes. After plugging it back in, if your dehumidifier is still not collecting water, I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
    -Best Regards-
    WP
    May 13, 2014 | Frigidaire FDF50S Dehumidifier
    Dehumidifiers Logo
    50 people viewed this question
    Top Frigidaire Dehumidifiers Experts
    Lawrence Oravetz
    mike cooper
    Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
