Question about Food Mixers
Is there any way to stop the slight oil leak from the bottom of the mixer head near where the paddle attaches?
    Top Expert:
  • Food Mixers Master
  • 80,270 Answers
Yes by replacing the shaft seal.
Posted on May 11, 2017
Kitchenaid mixer leaking oil from head.how to fix it.
It's not oil, it's grease. Here is a very detailed article on how to add grease to the mixer. After you have added some new grease and tightened the screws it will stop leaking. The temporary fix is to simply remove the chrome ring as is done in the picture on the attached link, clean out the oil and stick it back on till it fills up again. It is called a drip ring for the reason that it catches the oil component of the grease which drips from the gasket when the screws loosen:
http://www.artisanbreadbaking.com/discussions/kitchen-aid.htm
Jan 09, 2011 | KitchenAid K45SS Classic Stand Mixer
Mixer blade is chipping
If it is a tilt head mixer then adjust the screw which can be seen by tipping the head back and looking into the pivot point. Turn the screw CCW to raise the head and prevent the paddle from hitting the bottom of the bowl.
If it is a lift bowl mixer there is an adjusting screw on the frame of the stand behind the bowl holder mechanism. It rurns a cam which adjusts the height of the mixer.
See pg. 13 of the owners manual for bowl height adjustment procedure:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209707917.pdf
clockwise to lower the head and counterclockwise to raise the head for more clearance for the beaters.
Apr 17, 2010 | KitchenAid KSM150PS Artisan Series Stand...
MY MIXER IS LEAKING GREASE OR OIL FROM THE HEAD THAT TURNS THE MIXER. WHAT IS THE FIX? IS THIS A FIXABLE PROBLEM? CAN I FIX THIS MYSELF?
I'm assuming yours is an older model with the tilt-head feature.
Apr 13, 2010 | KitchenAid 32685 Mixer
Grease is driping from the motor down the paddle attachement. Is there some way to fix it?
Carefully pry the chrome ring from the gearhead of the mixer. Item 28 on this page :
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
You will find 5 screws under the chrome ring. Tighten them and the oil (grease) will stop leaking from the gasket which seals the gearcase halves.
Mar 30, 2010 | KitchenAid KT2651X Epicurean Stand Mixer
I have an almost 12 year old mixer, and in the last year it seems the head (for lack of a more technical term), is a little lower so that the paddle attachment grinds on the bottom of the bowl. The...
Tegan, sorry to hear you tilt mixer head is drooping and causing rubbing problems with the mixing bowl. This should be pretty easy to fix, if you?ve got a small blade screw driver and a small hex driver (or jewelers screw driver). First, do you still have the K45SS Parts List? If not, you can download a PDF version from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number (in your case, use KSM90P) and select one of the files that appear under Parts List. Turn to page 4 - Case, Gearing and Planetary unit, which shows the exploded view diagram and locate Illus. Nos. 29 & 30. Page 5 lists the parts as Adjusting Screw and Set Screw respectively. What?s probably happened is that over 12 years of operation, the vibrations from your mixer has caused the set screw to loosen and drop, hence the lower mixer head. Both screws will need to be ?adjusted? to move the head back to its original position. Now the problem is removing the head from its pedestal. Turn to page 8 and gently remove Illus. No. 7, Hinge Pin, with a hammer and pin driver. With the hinge pin removed the mixer head and pedestal can be separated and you should have access to adjusting and set screws. I would inspect them for wear and tear, and replace them, if you deem appropriate. It may take a few trial reassemblies to get the mixer head back to the original factory position, but once there, everything should be OK. I hope this helps! Howard, Burke, VA
Nov 02, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Dough mixing paddle will not stay in my wife's Viking mixer
pour a little wesson oil into the attachment holes and work the release while inserting and removing the attachment. Make sure the unit is unpluged. The oil will lubricate the lock mechanism.
Oct 28, 2009 | Viking VSM700 Stand Mixer
KitchenAid 250 Watts; Classic: Leaking Oil
Found this,may be helpful.
Why do I see oil leaking from the beater shaft of my stand mixer?
Some KitchenAid® stand mixers that are not used very often or have been tipped may experience slight oil leakage from the shaft or hub attachment. To avoid the oil leakage, KitchenAid suggests that you run the mixer weekly for short periods of time. Generally, the mixer may lose approximately X cup of oil before repair is necessary. The oil used is FDA approved and is not harmful to consume, should any get into the food that you are preparing.
Dec 15, 2008 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid Mixer head wobbles bad
The solution provided by luannej is useful only if your mixing attachment is striking the surface of the bowl. By adjusting the screw located at the junction of the head and base, you are actually controlling how far the head is allowed to tilt forward and, thus, the height of the attachment above the bottom of the bowl. Although the attachment striking the bottom of the bowl will lead to wobble (and noise!), it isn't usually the root cause of the wobble. In fact, the wobble may be causing the bowl strikes and adjusting the head height only hides the problem.
The head of the mixer is secured to the base by a large steel pin. Any play between the head and base comes from this hinge and its resulting tolerances. To "tighten" the sloppy tolerances causing your wobble, follow these steps: 1) Lock the mixer's head down and turn the entire mixer upside down. 2) Looking deep into the hollow base, find the small slotted set screw. This screw actually presses against the pin and takes up the slop between the head and pin. Note that this screw is not the large slotted screw I mentioned earlier visible when you tilt the head back. 3)Tighten the small set screw as much as you can. Your wobble should be greatly reduced or eliminated now. 4) Lastly, you may want to readjust the large screw controlling the head's tilt to optimize the distance between attachment and bowl. Hope this helps.
Oct 24, 2008 | KitchenAid Artisan Series Tilt-Head Stand...
Motor runs paddle does not move, oil from attachment port
I think this link will help you understand what is needed to fix your mixer.
You will need to purchase a gear. Here is link MarBeck should have it.
You may need to replace some grease. Make sure to use a non-toxic food grade grease.
Dec 14, 2007 | KitchenAid K5SS Heavy Duty Commercial...
Food Mixers Logo
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
