Can not get remote to turn tv on Changed batteries no Luck Model E320-AO
    Top Expert:
  • Televison & ... Master
  • 75,077 Answers
If you can manually turn on the TV then the remote is likely defective. Do other functions on the remote work? There is also the possibility the TV is the problem.
Posted on May 11, 2017
    Top Expert:
  • 73,647 Answers
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
My vizeo e320-ao has sound but no picture. is it the backlight
T'Con board fault. Check and replace it if you can. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 10, 2017 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
How do I make my remote work? It was working then it stopped. I thought it was the batteries, so I bought new ones but it still wont do anything.
Check the remote control for its infra-red emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Oct 10, 2014 | Vizio XRT010 Remote for E320-A0 E241-A1...
Suddenly won't come on
Main power supply regulator board fault.
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Jul 27, 2014 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
Vizio E320-A0 ... no signal
It would appear your signal board was damaged so it will require replacement. . If you purchased s extended warranty on the set it may be covered under the accident provision. If not you can go to Vizios site with the model no and locate the replacement board . If your capable you can order it and change it your self or contact a local servicer to assist or replace the set which may be more economical
Mar 06, 2014 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
Do you have to have a HD cable to hook up a PS3?
There are two ways you can connect your PS3 to your VIzio. First, you can do it with HDMI cable. Here the HDMI output from PS3 goes to HDMI input of the TV. Second, you can do it with the AV multi out cable.Here the multi output from the PS goes to AV input of the TV. After doing this please select the source accordingly. Good luck.
Dec 30, 2013 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
Samsung LE32C450E1W TV remote control stopped working, changed batteries no luck, turned off at power source for 30 min which fixed prob temp but has happened again and now turn off doesn't help....
Check the remote control for its infrared emission. Check it with fresh batteries. Clean the battery contacts inside its battery compartment. If these do not help you, you remote control need cleaning. If you wish to know more about how to clean and repair a remote control check this site. Pull up older posts. One among it has details.
Mar 24, 2013 | Samsung TV Remote Control
Can't get in trunk of e320 remote not working, nor is the key blade. Is the an alternative
is it because the cars battery is flat,or have you changed the battery in the remote,some times the tiny terminal in the remote gets squashed when you replace the battery, try checking terminals are all good. if all is well and the car battery is flat try removeing a registration plate light,and get a 12 volt feed to the bulb terminal at the same time push boot /trunk rellease button. good luck.
Mar 21, 2013 | Cars & Trucks
My remote control will not work on my TV. I have changed the batteries and tried a couple of universal remotes also with no luck. Any suggestions as to what the problem may be?
You can test your remote using a digital camera. Your phone camera will do.
Turn on the camera, point the remote at the camera and look at the screen. Press a button on the remote. You should see the LED light up. It this happens, the remote is working.
Your TV has a sensor that can see the LED's flashes. It may be defective.
Try unplugging the TV for a minute to reset the processor, that may clear the problem.
Turn off any flourescent lights or any recently added lighting to me sure that is not affecting the remotes operation.
Remove the batteries from any other remotes present (in case one is transmitting some information)
Hope these tips help.
Good luck.
Jan 02, 2011 | JVC AV-32D302 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
