When it fills with water it starts beeping instead of washing
yalmer
  • 552 Answers
SOURCE: Filling With Water
This is probably a control board failure, which should be replaced by someone familiar with them.
If you are handy, you can do it yourself.
If you need assistance, let me know.
Posted on Mar 04, 2008
AlmostBob
  • 550 Answers
If the water continues when electricity is discontinued the soleoid valve is jammed open, a fleck of rust or something, not designed to be repaired, it is easier and cheaper to replace. they are a standard part that fits 99% of all washers ~$10-20 at the local parts guy.
Usually only the cold solenoid has failed. it gets used more often.
If you are like me and only use cold water, swap the hoses on the taps, and swap the wire connectors on the solenoid valves, so the former hot is now cold, and you will get about the same number of years before you have to replace anything
Posted on Jul 29, 2008
  • 115 Answers
SOURCE: not filling properly with water
the screens where the water hose hooks up on the back of your washer needs to be cleaned
Posted on Dec 30, 2008
  • 91 Answers
SOURCE: washer won't run , push start button just beeps
in order to determine what is the cause of your problem , please provide the error codes an model number so we can figure out what is wrong with it, has anyone set anything heavy on top of the machine if is a top load machine, first guess if you have power to the machine would be look into the lid swtich an go from there....
Posted on May 28, 2009
SOURCE: Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Posted on Jul 20, 2009
Pre-Wash and Crease Care lights flashing?
WHILE IT IS LOADING WATER, TRY TO ADVANCE THE WASH PROGRAM; INSTEAD OF LARGE CAPACITY GO TO MEDIUM.
Jun 20, 2015 | Washing Machines
Wa75t65gw1
After 2 minutes does the machine throw up an error code. Starts beeping and shows a weird pattern of lights?
If so that error code can help us diagnose what your problem is.
If it does give you an error code take a photo and post it back on here so I can see what it is.
Jul 04, 2017 | Fisher and Paykel Washing Machines
Beginning of wash cycle starts agitating instead of filling w/water.
the water pressure/level switch contacts are welded together,usually the load selector switch for the amount of water lets it fill to a determined water level and the water level creates pressure in a tube from the tub to this switch and stops water fill and starts the wash agitation cycle,replace this switch inside the control panel
Mar 19, 2011 | Whirlpool Washing Machines
I have a Simpson Eziset 550 washing machine and it does not fill with water at the start of a wash - instead it will start to fill then stop and all three lights on the water temp gauge light up and start...
When mine had all 3 water temp lights blinking, it was a blocked pump, I emptied the washer, tilted it back, disconnected the hose from the pump (you will need towels) and clear out the pump, then put the hose back on.
Nov 01, 2010 | Washing Machines
LG WF T6517TC Washing Machine does not fill water
sir
my washing machine WF-T6517TC
when it start to wash get Alarm "dE" beep and stop machine.
what need to do.
call me 91080843
Apr 10, 2010 | LG Washing Machines
I was given a 2nd hand Fisher & Paykel SmartDrive051 washing machine a few months ago but now it is not filling with water or agitating in order to wash the clothes.
if some sort of control and lights on but just doesnt start then lid switch. if beeping instead of start then its found a fault. its well over 10 years old , may not be worth repair
Jun 19, 2008 | Fisher and Paykel Washing Machines
GLW10US won't do anything but beep
well i don't have any experience with this brand but i would say you need to change the fill switch it senses how much water is in the tub shuts the water off then starts the washer its also called the pressure switch
Feb 16, 2008 | Washing Machines
Rank: Apprentice
Jan 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
