Question about Edge Computers & Internet
I have a smsungs7 edge which the battery had blown and mother board has fried and no one will help
    Top Expert:
  • Edge Master
  • 77,960 Answers
The best thing to do here is replace the computer.
Posted on May 11, 2017
Broken Sega Game Gear.No Power,Picture or anything.Battery Acid in the Battery slot(s)Help?
You have to clean the contacts with some rubbing alcohol. Ware safety glasse and use a old tooth brush. If that dose not work then the mother board is fried.
Oct 14, 2014 | Sega Game Gear Console
Replace all blown or bulge or leaked capacitors with same value. That will fix your power supply problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
After replacing blown should work again.
Things you will need.
1. A plastic flat end screw or any object with flat fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Hope it helps
Mar 06, 2012 | Televison & Video
My unit won't power up - power supply is good and not sure about the on switch any help would be appreciated -- motherboard is in an old HP Pavlion 700 case
Remove the little watch type battery from the mother board check the voltage with a meter should be about 3.5 volts. Then replace the battery on the mother board. This battery holds memory within the Bio chips on the mother board, if there was a problem that it sensed for turn on it will be in the Bio's memory, and maybe not allowing the computer to turn on, by removing the battery for a few minutes, the Bio's forget they had a problem, if you will. and the computer might turn on.
If you have all the voltages to the mother board from the power supply, it should turn on.
unless there is some reset circuit interfearing with it turning on. Or you might have a blown fuse on the mother board, I would check everything I could, and try everything I could, and if you still cannot get it to turn on take it to a computer shop and spend a few bucks for them to fix it.
Nov 11, 2010 | Mach Speed Matrix P4MSD-800 (P4MSD-800 D2)...
Mother board problem
Go to ebay,if it's not may be out of luck. Did you try gateway? I didn't look it up but they may still service that board.
Jul 15, 2009 | Gateway (4000274) Motherboard
I used the wrong adapter by mistake now my laptop wont come on, i'm sure i fried something , the only thing it does, is the power lightly faintly clicks very rapid. Nothing else.
Yes you are correct. Due to wrong adaptor the power supply known as SMPS gets fried and causes mother-board damage too. So you need to repair your laptop's mother-board components and power supply too.
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
Jun 30, 2009 | Computers & Internet
My television quit working after a storm, it wasn't even turned on during the storm. the power on the set and remote does nothing. but it makes a sound when plugged in like it is turning on then nothing...
Ok, this was a direct hit in this case and you will defiantly need to replace the power supply board in this unit. the first thing that will happen during a direct hit is, the surge will run threw the power cord and travel threw the entire power supply circuitry, frying all circuits. this includes the main mother board as well. I recommend replacing the mother board and power supply board as well. this will restore your set to its original operational value. The mother board is commonly called the main control board.
please rate and god bless:)
Apr 02, 2009 | JVC HD-52G886 52" Rear Projection HDTV
Mother boaed for my 41/2 year old computer is fried.
well if you interested pls call my company asia systems technologoes look for william our sale person.. + 65 65478990
Mar 11, 2009 | Computers & Internet
Dell optiplex g1
Sounds like your mother board is fried, when you change out a battery sometimes static electricity builds up on your finger tips and zap and in most cases you wont notice it, it only takes a little bit to fry a mother board.
Oct 15, 2007 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
Top Edge Computers & Internet Experts
Steven Conroy
Steven Conroy
Lee Durbin
Lee Durbin
Are you an Edge Computer and Internet Expert? Answer questions, earn points and help others
