Question about The Office Equipment & Supplies
Trouble with Atria 3100. The leads on the paper are messed up with a lot of static and aVR is reversed, becoming negative. It also says that the leads are overloaded. Machine says noise left leg.Thank
  • 50 Answers
SOURCE: Shreeder Feeder jammed , appears cleared, makes a humming noise when attempting to feed paper and a similar noise when hitting the reverse button. Help please. Thank you.
It could be one of two problems and they are both usually caused by over feeding. Either the tooth rollers have junped out of their sockets or they are jammed tight with paper which would cause the first to happen also. There are safety switches but unplug the unit any way. Get on the output side of the shreeder and start pulling paper or remove the metal object that was dropped into its throat. Hopefully, you won't have to take it apart to put the rollers back into their sockets.
Posted on May 28, 2009
Geekman
  • 32281 Answers
SOURCE: SONY VGNFJ270 LAPTOP BECOMES HOT AND GIVES LOT OF NOISE
If the fan is noisy and the laptop is running hot, then most likely the fan is faulty and spinning slowly. Therefore the fan is not providing sufficent air flow to cool the laptop's CPU. The fan needs to be replaced and possibly the heatsink assembly needs cleaned to remove dust buildup.
Posted on Jun 25, 2009
  • 123 Answers
SOURCE: Denon avr-3200
http://userguides.50webs.com/denon_avr_3200_manual.htm
You can get the manujal for Denon 3200 from the link above.
Posted on Apr 25, 2010
FSAhead2
  • 214 Answers
SOURCE: HOW DO I REPLACE THE
here is the link to the pdf manual , scroll down to page 2-5 loading paper
http://www.cardiacscience.com/assets/003/5268.pdf
Posted on Sep 28, 2010
AJIN G
  • 6694 Answers
SOURCE: ekg machine states left leg fail, but none of the
hi,
ur machines patient cable have some problem in its left leg lead ,it may be broken inside. no ecg will come if any of the lead have problem. machine sences all the leads is it proper or not , then only it will process th ecg and give printout. u have to replace the patient cable of ur machine. or try to replace the left leg lead if it is repairable one type patient cable.
ok
Posted on Jan 11, 2011
My 2011 tahoe has terrible static. It is only the radio, I have no problems with clarity if I use a cd, ipod, phone or my xm satellite stations. It is the stock radio that cane in the truck.
Get an inline suppressor which will cut down the static interference from the trucks ht leads and wiring.i believe it fits onto the negative lead of the radio assuming your truck is negatives earth.available at small cost from most auto shops.
Feb 27, 2015 | Audio Players & Recorders
Eonon problems
VW A3 Viewer Request Reverse Light Switch Location A3
You can use the BACK UP SWITCH AS A POWER SOURCE. Locate the back up switch on the tranny. Tap into the wire that becomes "hot" when the tranny is in reverse. Use a multi tester Positive lead in the switch socket, negative lead to ground. The wire you want is the one that has voltage in it when tranny is in reverse, ignition switch has to be on, but DO NOT start car. Use a tap connector and run wire to camera power. Make a ground from camera to any point on the frame of the console. Put a fuse in line in the positive power wire to the camera power input. When you put the car in revese, the camera will come on.
May 19, 2014 | Car Audio & Video
My 1994 buick some time dosent start i have to mess with the battery cable for it to start alsothe light and radio come on it just dosent want to start
You're not really giving much to go on. However: Messing with the battery cable...Positive or Negative? It should be a side post battery. The battery terminal may be bad. They occasionally have a tendency to corrode inside leading to a poor connection. You may be able to just replace the terminal end for about $5. Check the terminal bolt to ensure it hasn't become loose or stripped due to over tightening or a faulty connection causing the battery itself (terminal receiver) to become faulty. Then you'll have replace the battery. Check the cable ends next to the battery to see if they appear to be soft. That would indicate corrosion inside of the cable and a new terminal will repair it. If you're messing with the cables that lead to the starter end, then the solenoid may have a bad connection on the starter. Even though the radio and accessories may work it takes a substantial more amount of current to start the vehicle. At a guess: I'd say it's the terminal end or the battery (terminal receiver in it). I really hope I've helped. If so, please rate my assistance and leave a comment. Thanks for using Fixya.
Jul 21, 2011 | 1994 Buick LeSabre
We use a Welch Allyn ECG machine at our office, and our numerous occassions lately it is saying the the limbs leads are reversed (avR is showing up positive and aVL is showing up negative). How do I fix...
hi,
You have wrongly connected the limb leads. Limb leads are those leads which we connect in the arms and legs.
In your case the leads in the arm have been interchanged. Thats why you get the message and prints inverted avR and avR.
check the leads and properly place it.
ok
Apr 06, 2011 | Welch Allyn Medical
There is no printing
hi,
may be ur machines thermal printer head have some problem. also check the paper u have inserted. it should be a wax paper or chemical paper.
ok
Dec 24, 2010 | RTO Quinton Cardiology Atria 6100 Ecg...
Artia 6100 machine showing err out of paper.
hi,
ur machines paper sensing sensor have some problem. did u used the paper with black mark on the side.
remove the paper cover . u can see a black square sensor near the side of thermal printer. clean the sensor with an ear bud. do not use any solutions. then check again.
remember use good quality paper. if the black mark on the side of the paper is not perfect this problem can occur (black mark on the paper is for page count and paper sensing)
ok
Dec 23, 2010 | RTO Quinton Cardiology Atria 6100 Ecg...
Denon avr-3200
Check a few things first to narrow this down a bit. Disable the surround processing. If this clears up that channel, then the problem is in the processing area. If the static remains, vary the volume. Does the static change volume too? If so, then the problem is in the beginning stages of the pre-amp section and is likely a transistor or two breaking down. The parts for this would be in the $5 range. This would probably be considered a "major' repair becaue of the time required to hunt down the defective part.
Dan
Mar 28, 2010 | Denon AVR-3200 Receiver
I have a buzz / static that appears for the first 15 minutes.
Hi...
I just opened up an AVR3300..It's trouble is that it goes into stndby
at once.
The BIG power supply caps are VERY swelled at the top.
That would be my informed view on why it's bad.
I suggest you look at that being your possible trouble too.
Scott in Vermont
Jun 22, 2009 | Denon AVR-3300 Receiver
Denon AVR-887 turns itself off in 5 secs, any one know why?
You might have the polarities on the speakers crossed, check all speaker connections to make sure the pos and neg are connected correctly. If they are crossed, this will cause the receiver to short out, thanks
Apr 05, 2009 | Denon AVR-887
26 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
