Question about Cameras
The zoom out feature does not work anymore with the zoom lever.
The zoom works both ways via the slider control on the screen but only with zoom-in with the lever. When the lever is employed for zoom-out, the camera focuses, but does not zoom out. I have tried all the settings that I can think would be related to this problem and have removed the battery and replaced but no success so far. I have also reset the camera to factory settings via the menu system. The fact that the zoom works fine with the slider control on the screen seems to point to a setting issue and not a mechanical problem. Any suggestions would be greatly appreciated.
The Marv
  • 72 Answers
SOURCE: stuck on either PScan or PAL; can i reset the whole darn player?
To reset Cyberhomes DVD players. Take the dvd out close the tray. then press and hold stop for five seconds.
Posted on Aug 05, 2006
hokuwho
  • 306 Answers
SOURCE: focus/zoom issue with Konica Minolta Dimage Z3 digital camera w/ 12x zoom
This is a symptom commonly listed for DiMAGE cameras listed on EBay for 'parts only'. Dropping the camera I had caused the same problem and carefully 'smacking' the camera once again did solve the problem but that may have been dumb luck. Sorry but it is a service task that may cost more than the camera.
Posted on Oct 15, 2008
  • 38 Answers
SOURCE: Canon Powershot A1000-IS stuck on zoom plus shutter problem.
hello. If there is a reset, it will show it here in the manual. go to this web address. http://gdlp01.c-wss.com/gds/0300001222/PSA1000IS_CUG_EN_02.pdf hope this helps. Ron
Posted on Sep 08, 2009
SOURCE: zoom/focus on hd camcorder
I had the same problem w/ the same camera. My wife fixed it by doing this: holding down the pictue snapshot button and the video record button simultaneously. Low and behold, the focus came back. I was amazed! Try it.
Posted on Dec 31, 2009
jsmes1027
  • 749 Answers
SOURCE: 2005 GMC Yukon Denali XL - Climate Control issue-
Are you aware of any codes that may stored in the body control module and do you hear a clicking or ticking noise in the rear?
Posted on Nov 02, 2010
OVERSIZED DISPLAY
You can use iTunes to enable or disable any accessibility feature, including Zoom:
  1. Connect your device to a computer and open iTunes.
  2. Locate and click on the device under Devices:
  3. In the Summary pane, click Configure Universal Access:
  4. Select Neither to disable Zoom:
  5. Click OK and then click Sync to save the changes to your device.
If you do not have access to a computer or iTunes, use the following steps to disable Zoom on the device.
  1. On the Home screen, double-tap with three fingers to exit zoom.
  2. Locate and tap on Settings > General > Accessibility:
  3. Tap Zoom and turn off using the slider:
Jan 29, 2011 | Apple iPhone 3G
My iphone icons are enlarged
If the icons on your Home screen appear too large, the zoom feature may be enabled on your device. use iTunes to enable or disable any accessibility feature, including Zoom:
dmooney_eire.png 4, Select Neither to disable Zoom: dmooney_eire_0.png
  1. Click OK and then click Sync to save the changes to your device.
Jan 14, 2011 | Apple iPhone Smartphone
My laptop screen is zoomed in which is making all my icons huge. It makes my Internet pages huge also. How can I zoom out so my screen is back to normal size?
use this if using windows vista/windows 7
Set the zoom level in Magnifier. This can display objects on the screen up to sixteen times larger than actual size. Follow these steps to choose the magnification level that you want.
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Magnifier.
  2. In the Scale Factor list, select a level. The zoom level in the Magnifier window will change right away. Adjust the level until it's right for you.
use this if in windows xp
  • 1 Click the "Start" button in Windows.
  • 2 Select "Control Panel."
  • 3 Select "Appearance and Themes."
  • 4 Select "Change the Screen Resolution."
  • 5 Look at the left side of the "Display Properties" dialog window. About half way down the screen you will see a box labeled "Screen resolution." There is an adjustable slider in this box.
  • 6 Move the slider left or right, by holding down the left mouse button, and moving the mouse in the appropriate direction. Release the button when the slider is pointing to the resolution you desire.
  • 7 Click the "Apply" button at the bottom right of the window. The screen will go black for an instant, and then will switch to the new resoulution. You will also see a message pop up asking you to confirm the setting. If you are unsatisfied with the appearance, then click "no," and try another resolution. Otherwise, click "yes."
  • or try the accessibility mode
    1) press start goto control panel be sure use are in classic view
    2) select accessibilty options and select display tab and uncheck the enlarged icons option and apply and click on ok. this will reset all programs to a smaller view.
    ROB
    Nov 25, 2010 | Computers & Internet
    Screen has zoomed in and will not return to normal resolution. Cannot even soft boot as the slider does not appear on the screen because of the zoom in
    Double tap the screen with 3 fingers to undo. Then to turn the feature off, go to settings then accessability and turn "zoom" feature to off.
    Regards
    Jim
    Oct 23, 2009 | Apple iPhone 3G
    How do I zoom out my screen
    either change the resolution via the display settings throught control panel to a bigger resolution or you could hold ctrl button and use the scroll wheel
    Oct 21, 2009 | Computers & Internet
    My trackball zoom on my camera is not working anymore?
    The same problem with me, i do a hard reset and it is fixed, simple isnt it?
    To do the hard reset, just remove the battery for 1-2 minutes and restart the phone. This will reset the camera firmware to its factory default.
    Aug 25, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
    NORMAL OPTION GONE
    the cable remote has a zoom feature in the settings. the zoom setting got turned on somehow. This feature overrides the picture size settings on the tv.
    so, not a tv problem at all, but easily missed.
    Dec 29, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
    Zoom will not retract
    Dear Grammie,
    You have either experienced a lens error or your zoom dial is broken (both usually caused by some sort of impact damage, but which can be spontaneously occuring).
    Look for an error message on your camera's LCD screen such as "E18," or "lens error restart camera." If you do not see a lens error but simply cannot retract your zom lens (go into wide angle mode) via the zoom lever then it simply maybe a broken command dial. Either way, however, you will need to have the camera serviced in all likelihood. Call tech support at 1-800-828-4040 M-F from 8 am to 12 midnight EST and Saturdays until 8 pm EST. Hope this helps.
    Sincerely,
    HeavyDLB
    May 22, 2008 | Canon PowerShot A540 Digital Camera
    TV in permanent zoom
    The left and right arrows on the RCA remote control are the picture format buttons.....
    Apr 12, 2008 | RCA P61939 61" Rear Projection Television
    Cameras Logo
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
