Question about Epson Office Equipment & Supplies
Epson dfx 5000 jamming
When I go to print the ticket starts to print and then it just jams and stops. The spool for the ribbon keeps moving along with the ribbon itself. I tried holding down the feed button while off then turned on and nothing. I did the same thing with the TEAR OFF button and when it came on it started to print ABCDEF...etc and #s. There was no jam it just kept printing with no problem. But when I try to print something real the jam happens. Can anyone help with this PLEASE?
SOURCE: paper wont feed then says paper jam
Got rid of my problem!
In an act of despair I started to poke around the inside of the printer with a wooden match. Especially I found a small black lever mentioned on a Dell web site (general paper jam help page) that could be pressed a little. It is placed just a little bit right of center behind the carriage and just above the roll that feeds the paper beneath the printer heads. I'm not sure if this was what finally did it, but now the paper jam problem has gone away.
Another thing I noticed is that my carriage is now moving to center when I open the top. When the paper jam error was present it always moved to the far left (so I could remove any jammed paper, I suspect)
Posted on Apr 12, 2008
s_4u_11
  • 535 Answers
SOURCE: hp deskjet 5150 paper jam
u have to need to do change the printer roller
Posted on Sep 01, 2008
yooperbud
  • 8637 Answers
SOURCE: Epson RX500, Paper Jam - printing couldn't start
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button, applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time. Worth a try. I have fixed a number of printers this way saving costly repairs. Bud
Posted on Jan 07, 2009
tigertail
  • 163 Answers
SOURCE: Epson R300
First of all turn the printer off & disconnect all of the cables. Turn it over and give it a shake, you'll be amazed at what gets inside the feed hopper. Next try a stiff piece of A4 card (the backing from an A4 notepad for instance), feed the card into the paper feed and push it through quite hard to overcome the spring resistence. Once it has started to go through open the lid and check if it has pushed anything through the rollers. Feed the card all the way through the mech and pull out of the front. Hopefully the card will have cleared the paper path of any objects and reseated the sensors.
Good luck.
Posted on Mar 12, 2009
  • 97 Answers
SOURCE: Canon MX310
Have you ever tried printing sticky labels in the thing? You have to be careful with those because sometimes a piece will come off and stick in the corner of your printer. If you don't have long surgical tweezers to pull it out, you could be looking at an expensive repair. Also check your manual. There are two places the paper can jam in. You might have checked only one. I have a different Canon model but on mine I also have to make sure the correct light is on. Is the light for feeding from the back on, or the light from feeding on the front? If you have the same light, press it again to change the place where it will feed from.
Make sure your paper isn't curled or that you're using paper that's too thick also.
Can't answer more because I don't know what program you are using to try to print.
Posted on Sep 25, 2009
Epson dfx- 9000 saying ribbon jam. What is the problem?
Usually caused by the ribbon feed unit. The gears strip out and stop working. Sorry about the pic, Fixya is pulling up the wrong picture.
EPSON 1410868 RF UNIT DFX9000 Refurbished
Nov 20, 2015 | Epson Office Equipment & Supplies
Ribbon jam
Try replacing with another ribbon
Mar 30, 2014 | Epson DFX-9000 Matrix Printer
My DFX 8000 Printer head is moving, but it is not printing, ribbon and head is OK. i change the head and ribbon but problem is same.
Thanks, I Try it. but it is still not printing, because printer head pins
are not coming to the paper. Head pins printing sound is coming.
thanks
Aug 13, 2013 | Epson DFX 8000 Matrix Printer
Epson printer dfx9000 problem ribbon jam errorr i change the ribbon cartridge and test in another printer my ribbon is correct but in this printer this error is shown yet what should i do?
Check for any foreign objects that could be affecting the ribbon cartridge assy ,clean and reset ,perform a maintenance check via the printer menu
Feb 03, 2011 | Epson DFX-9000 Matrix Printer
Error : paper jam Epson DFX-9000
I find problem printer epson dfx-9000 with mesage
error : 0E
turn off printer
help solution this problem ????
Sep 14, 2010 | Epson DFX-9000 Dot Matrix Printer
Reset Epson DFX-8500 Matrix Printer
Remove power cord for at least 10 seconds AND delete print job manually from Windows(?) Open Control Panel>Admin Tools> Services. Stop print spooler service. Delete contents of c:\windows\system32\spool\printers folder, restart print spooler service, plug printer back in.
Aug 14, 2009 | Epson DFX-8500 Matrix Printer
E4 Error It blinks all led flashing E 4 after making a jam noise, then turns off after a while
It seems your printer,s carriage is jam or carriage encorder is out of carriage sensor
Oct 15, 2008 | Epson DFX-8500 Matrix Printer
Ribbon jam
i get the error RIBBON JAM anytime i try to print,even though i have changed the ribbon.Dan
Sep 11, 2008 | Epson DFX-9000 Matrix Printer
Epson DFX 8500
the file maybe too big to process, try printing the file in different method, like separating the sequence, divide the prints into parts in this way spooling will be easier and it will be queued anyway and will print, just be mindful of pages and sequence
Aug 08, 2008 | Epson DFX-8500 Matrix Printer
46 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
