Question about Bosch Dishwashers
Are there replacement racks for the bosh SHE43M that are NOT "platinum" which are silicone coated (slippery) and the rack slants downward toward the sides so glasses and cups slide and bump into each othe chipping the rims. I HATE this dishwasher!
I dont have an answer... i simpkly have a similar problem. just bought and installed Bosch SHE45M06UC dishwasher - and nothing seems to fit in the racks. Can one get other bottom racks of a different design?
Posted on Nov 21, 2009
Looking for part # for replacement of upper dishrack assy which started getting very rusty. Thank you
Rack replacement have been pricey for me. I have used a Rerack Dishwasher repair rubber repair adhesive with lots of success. I wire brushed the affected area overlapping the current coating. I applied with several coats making sure to overlap the current coating
Where some of the vertical posts had broken off I resealed the rack. I Made sure the rack was good and dry before applying.
This rubber repair is available everywhere I found it at Ace.
It has been in place for over two years holding up very well.
Nov 16, 2015 | Dishwashers
Tip
How to Stop the dishwasher from breaking my glasses
This shelving costs $16 plus $20 for powder coating.
Very easy to assemble taking about 2 hours.
It will stabilize your dishwasher trays so glasses wont fall over. Therefore wont break.
Buy 2 large Baking racks with 1 cm holes from Myers for $8 each.
Use your Angle Grinder to cut to size, making sure the cross wires running from left to right are on top of the long runs. This is because your glasses would slip all the way to the front, if you mounted the racks up the wrong way.
Basically I cut off only one side of the rack, using the cutoff piece for the middle hole.
Next flatten those legs that wont let the rack sit flat down, by using your vice and hammer.
See the diagram below how wide the framing supports wires are apart, that is why nothing stands up on them.
You may have to discard other supplied movable racking.
But the inserted racks, with a hole cut in the middle rack to allow a raised support wire some space, are very stable.
Now after cutting hammering and bending the racks loose some coating and will rust with little rust marks appearing on the edges of all your crockery and cups.
Therefore you will need to powder coat them any colour for years of protection.
Just find a powder coater in the yellow pages and give him the cutout racks.
To save money I told him to coat my Black racks to any colour in his machine, which turned out white.
Note the glass which now stands up stable and straight.
on Feb 06, 2015 | Dishwashers
I need to put up a few coat racks in my new house but don't want to buy ones that are all the same. Where can i get cheap but fun coat racks?
You can get some really fun and funky coat racks these days and you don't have to spend a fortune on them.
Try looking at IKEA as they have some very traditional ones and also some more fun ones too.
http://www.ikea.com/us/en/catalog/categories/departments/bedroom/20617/
Jan 17, 2013 | Home
Do all coat racks have umbrella stands?
Not all coat racks have umbrella stand. They are an extra embellishment. Most coat racks are a few pegs screwed into awall or a stand with a few outposts, often called a coat tree. While umbrella stands are nice, they are notprerequisites to coat racks.
May 29, 2012 | Home
We have got the machine for approximately 2 years and the top dish rack has corroded so badly that I think it might collapse with a load on it. What could be the cause of it?
The causes are usually poorly coated rack combined with rough usage (coating pierced
by cutlery, broken stemware, etc., combined with hard (mineral-laden) water, which
corrodes the steel of the rack quickly.
Luckily, the upper rack is replaceable, so check:
http://www.buyspares.co.uk/dishwasher/ld12bw5/basket/catalogue.pl?shop=lg&path=111329&model_ref=49220&refine=basket
Jun 09, 2011 | LG 24 in. LD-12BW5 Free-standing...
One freezing rack not working! I hav efridge-freezer Bosh Classic Maxx and the top freezing rack does not working ? Everything else is o.k. but not that top rack.So can you help me ,please???? Thank you...
i dont really know this model, how many racks are in the top unit ?
if more than one rack , then i would say it sounds like incorrect coolant level in the freezer system , might have a small leak, and it would need the coolant level increasing .
Dec 18, 2009 | Refrigerators
Noise from top rack
THEN RUN THE RACKS AT REAR WHEN THERE IS NOTHING LOADED. THIS NOISE IS BUILT IN BY THE DESIGN, THERE IS NO "FIX"
Aug 27, 2009 | 2006 Toyota RAV4
Has become difficult to raise & lower blade
I have a similar saw and love it. I saturated the gear with silicon spray and worked it a bit. This seened to do the trick.
May 07, 2009 | Saws
My viking dishwasher does not rinse the soap scum off the dishes
Maybe . . . remove the lower rack and invert it. Look for cracked or missing plastic coating, exposed, rusted & possibly "swollen" inner steel rod/wire. If found, remove the upper rack and look for more of the same. What you think is "soap scum" is probably rust and other iron compounds leached by the dish soap out of the rusted steel onto the dishes and the dishwasher interior. The following worked for me . . .
To clean the interior (with both racks removed), set to "No Heat" dry, then "Pot & Pan" wash and allow to fill. Open door, dump in a bottle of "Lime A-Way", close & latch door and allow to complete cycle. This should remove most rust and iron-sulphate deposits from interior. If not, scrub them with Lime A-Way and a ScotchBrite pad, then cycle again.
Racks must be replaced (Viking are very expensive, Asko, Bosch, or other lower racks may fit: check your neighbors' racks for fit), upper rack must be Viking unless you can exact-match the Asko or Bosch equivalent.
Possible fix: remove the loose plastic coating and flaking rust with a knife, ruff plastic coating with ScotchBrite, clean with rubbing alcohol, then treat metal/rust with "rust converter" (hardware or home imp store), wash with soapy water, rinse, then clean with rubbing alcohol, dry fully, coat with "high temp" (orange or yellow) silicone sealant (auto part store), covering exposed metal and a half inch or so over the plastic coating. Let set for a day or two.
A trip through the dishwasher for all your stained stainless, glasses and non-metallic coated or non-metallic decorated dishes with Lime A-Way as above (on new or "rebuilt" racks) should get the metallic scum and rust off them.
Apr 18, 2009 | Viking 24 in. Professional Series VUD141...
Installation of rear facing car seat (not infant) in back seat of my toyota sequoia....the seat slants downward so the car seat sits to far upright even in the reclined position so when my son falls asleep...
Use "pool noodles" that you have pre- cut into lengths equal to the width of the base. Some experimenting will be needed; you may have to stack them like a pyramid, with more towards the back of the seat. Bath towels work as well but are more slippery on leather.
Jul 15, 2008 | 2006 Toyota Sequoia
Dishwashers Logo
280 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
