Question about Samsung Refrigerators
I got a Samsung SR-606EV stopped cooling, There is a sound of the engine working at the back,a technician said I need to replace the compressor, but the compressor seems to work, he said gas is full
zeusfaber
  • 247 Answers
SOURCE: Samsung Fridge Freezer (Freezer on top)Model SR-52NXA wont cool
Depends a bit on whether the compressor really is running, or if it's just humming because it's got power on the run coil, but not on the start coil.
Have a careful listen to the compressor. If it's making the trilling or gurgling sounds that go with a working compressor, then your problem is probably one of lost gas. Fixing this is not a do-it-yourself job.
If the compressor sounds like it's stalled, the problem may lie with the starter. Replacements are usually cheap enough for it to be worth fitting a new one just to see if it works.
A.
Posted on Feb 28, 2008
sandy82
  • 10 Answers
SOURCE: samsung SR-S22FTCS
dear friend
The water filter doesn't affect the cooling perfomance of ref.ther may be problem of defrosting of ref.compartment.
regards
sandy
Posted on Jun 08, 2008
SOURCE: kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
Posted on Feb 01, 2009
motor1258
  • 6674 Answers
SOURCE: 1997 Honda Accord. The compressor clutch and the
Could be a little low on freon as well, causing it to cycle on, off too quick.
Posted on Jul 11, 2009
  • 1796 Answers
SOURCE: My Sanyo refrigerator (model SR-4431S)
Hi!
Before you can refill the system, you need to have the leak fixed. They have to evacuate the system, weld shut the leak, vacuum the system for 30 min. and refill refrigerant to proper level. This is a job that by Federal Law has to be performed by an HVAC Certified Technician. Take the unit to an appliance repair shop for repair, this way you'll save on the service call.
A HELPFUL - 4 THUMBS - Rating and a TESTIMONIAL would be greatly appreciated if you are satisfied with this FREE solution. Thank you for using FixYa.
Posted on Oct 22, 2010
Testimonial: "Thanks for the info and your time! I will follow your advice and take the unit to a repair shop. Much appreciated!"
RS267LBSH The refrigerator stopped working. The technician came and replaced the compressor. It works for 1 1/2 month and failed again. He came the second time and replaced the evaporator. A month
your getting ripped off try the defrost timer sounds like it is getting stuck, it operates on a 24 hour basis cycling between defrost, and turning compressor on and fan to cool the fridge
Sep 02, 2012 | Samsung Refrigerators
My Sanyo SR-4911m refrigerator does not cool. Compressor seems to turn on when termostat is turn from off position to on position. However, compressor gets really hot and gurgles, but does not cool the...
it shouldn't be gurgling, has it been laid on its side at some point? anyway,, sounds like it has air in the system,, unplug it and let it stand upright for 24 hours, if the problem still persists,, it may need to be charged, the compressor getting hot is normal , if its very very hot, its because its running constantly trying to cool the unit
Jul 04, 2011 | Sanyo SR-4911M Compact Refrigerator
Hi, SAMSUNG SR L39 stops to cool, even if everything seems ok, the fridge is on, the display lit, but food is not cold. Then turn off and turn on the fridge by the power button and everything seems to go...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 20, 2011 | Refrigerators
Samsung side by side fridge freezer sr-s2028css. having seeked advice from refridgeration engineer was told compressor was not working, had a new compressor fitted by another engineer but still existing...
Did they change the start relay as well as the compressor? On Samsung refers the start relays do not come with the compressor. If they didn't its possible that the start relay is clicking.
Oct 07, 2010 | Samsung Refrigerators
Sanyo sr-1013w not cooling
sounds like it has a refrigerant leak somewhere in the unit.
Feb 20, 2009 | Sanyo BC-1206 Commercial Beverage...
Samsung SR423NXB
hello andrea,
could you give more details ?...is the compressor running? what do you observe in your unit? are there error codes?. are there fans which are not running?
tnx 4 using fixya,
drcool
Sep 20, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
Blinking temperature control
hi
this refrigerator having problem related with defrost cycle.fridge is able to defrost after period.please check it as follows
there is timer box located behind the fridge near to compressor with white color knob.attach the clamp meter on one wire of main cord,check current drawn by fridge when comp.is running.turn the timer knob clockwise to hear big tick sound where the comp.will stop,check the current in meter which should be 0.6amp.if it is not showing then there is problem with bimetal or heater which is inside the frizer
May 01, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
A.
Feb 28, 2008 | Refrigerators
Refrigerators Logo
35 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
