Question about Dryers
Harbor breeze lost the highest speed other 3 speeds work
worldvet
  • 859 Answers
SOURCE: Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
Regards,
Worldvet
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
Posted on May 27, 2008
SOURCE: Fan Speed Too Slow
You need to pull the fan chain until it is set to the fast setting, then you use the remote to set the fan at the speed you desire.
Posted on May 28, 2009
  • 7 Answers
SOURCE: 2004 mazda mpv- rear heater fan only works on high
My bet is that there's a relay at fault... but first: have you checked the fuses? the high blower speed draws a lot of power, so sometimes it's fused separately from the other speeds. This means that your fuse for the slow blower speeds could be blown. Also, because theblower draws so much power, you'd need a HUGE switch to switch it directly, so they use a low-power switch inside the car, and a relay (usually under the hood, but sometimes under a seat (check your owner's manual) to do the heavy work. These are often split the same way, with the high blower on one, and the slow on the other. These are the things that are easier to check, but it could just be that the switch is bad. Mid 90s Land rovers and Range Rovers have the same problem, where the only blower speed that works is HIGH, making the cabin sound like a wind tunnel... Just the switch. The switch can be a pain to replace if you do it yourself, but do check the fuses first, and see if you can find the relays. if the fuses are okay, and you find the relays, try to find the one that's for the fan and swap it out, it shouldn't be more than 3-4 dollars from an auto parts store, just bring in the old one to match it, or swap it for another relay that's nearby and has the same pins. If the swap works, just remember to get another relay, because the one you "borrow" from another circuit could be the door locks or the headlights or something else important....
Posted on Jun 22, 2009
SOURCE: Harbor breeze fan will only work on low speed
I'ts not a transformer, it's a capicator and could be bad. call Harbor breeze with model (on top of motor assy) and they can sell you the correct one.
Posted on Sep 25, 2009
adertouzos
SOURCE: I need wiring instructions to
Better late than never . . .
Posted on Dec 25, 2011
Hunter fan 2 yrs old-light won't work.fan discontinued was told need switch G234686000 but no longer stock it! fan not used long enough to replace bulb & now have to trash it. what to do?
Been There, there is a small remote box inside the case,, if you buy Harbor Breeze 3 speed fan switch with dimer light they come together,,, but Heck,,, it's $60.00 US !!!
Nov 07, 2017 | Hunter (25417) Ceiling Fan
I have a Harbor Breeze White 3-Speed Combination Fan and Light Control (Model #: WC-100L) that has stopped working. The red power light does not even light when I push the buttons. Any idea on...
First of all, you bought a cheap store brand fan! The red light is a battery indicator light, so check your battery. If that doesn't work, then you probably need a new transmitter or receiver or both.
Oct 17, 2013 | Dryers
I have a harbor breeze ceiling fan on a dimmer
You have 3 options. You can connect the fan blue and the fan black to the red ceiling wire. Then you will need to control the fan and light with the strings. The wall switch will turn off everything. Option 2 is make sure that there is a switch wired to the black ceiling wire. If there is a switch I would check to make sure the switch is working. Option 3 is to purchase a remote control unit for both and leave the wall switch to shutoff the whole unit. Hope this helps.
Oct 11, 2013 | Speed Ceiling Fan 3-speed Switch By...
Westinghouse 3speed fan switch 77288
It's the westinghouse switch. Many results on search. I just wasted 2 hours playing switching wires all combos. Others suggested the switch from Lowe's. Harbor breeze #0033905 . Plug wires back in as you listed Black L, Grey 1, Brown 2, Purple 3. Works perfectly for $3.98 plus tax.
Others said you can call Hampton Bay and get the replacement also.
Sep 24, 2013 | Hampton Bay Dryers
Harbor breeze fan remote
If the fan has a pull chain then push the Hi button and then pull the chain until it's on high. Then don't pull the chain! If that's not your problem then check the capacitor in the fan.
Jul 15, 2013 | Dryers
Apr 17, 2009 | Westwind Classic Hugger Polished Brass 52"...
Regards,
Worldvet
May 26, 2008 | Westwind Classic Hugger Polished Brass 52"...
Dryers Logo
Top Dryers Experts
