Question about Bosch Dishwashers
Our bosch dishwasher shows an error code H:21
    Problem Solver:
  • 5 Answers
There are many reasons why Bosch Dishwasher Error H21 happen, including having malware, spyware, or programs not installing properly. You can have all kinds of system conflicts, registry errors, and Active X errors. The registry on your computer will accumulate errors over time. It's just a fact of life in the computer world. This happens as programs are installed and modified, or even removed.
Posted on May 11, 2017
What is E22 error message on Bosch dishwasher
Hi Darlene, The link below is a bosh dishwasher error code AND how to fix, I hope this helped..........CHEERS..
Bosch Dishwasher Error Code E22
Fault Condition: Residual water in sump
Repair or Check: Check for a blocked pump, a dirty filter, or grease build up.
Parts Required: Pump or clean filter
Bosch Dishwasher Error Codes How To Clear What To Check
Apr 24, 2016 | Bosch Dishwashers
Bosch dishwasher doesn't work. water not coming
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS..
http://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve
Bosch Water Inlet Valve Assembly for Dishwasher
Apr 02, 2016 | Bosch Dishwashers
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
Bosch Dishwasher fault E 15 explain
Bosch Dishwasher Error Code E15
Fault Condition:No water in dishwasher or not sensing water.
Repair or Check: Tilt dishwasher back and the error code should disappear. While you tilt it press off button to clear. Stand it back to normal turn back on and dishwasher should run normally.
Parts Required:Tilting machine
Hi i found this answer on this link, scroll down the page and it's the 3rd error code (in red) Hope it helps...
https://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Mar 16, 2016 | Bosch Dishwashers
Bosch dishwasher won't start, error code h:05
Could have a timer problem or switch
Oct 03, 2015 | Bosch Dishwashers
How can I get the error codes for a Bosch dishwasher
Go back to the shop and ask them where you bought it from , or find the manufacure firm and ask for a manual or do a searc for them on the internet.as some have a website for information.
Jan 09, 2015 | Bosch Dishwashers
My bosch dishwasher she6af02uc is showing an E-24 error what is this
error code E24 = Drain hose blockage or pump impeller failure, suppose running it with filter unsecured would allow some goodies to get in there.
Changing the fine mesh filter should fix this.
Jun 29, 2012 | Bosch Dishwashers
Bosch dishwasher error code c1
Hi
Pump-out not accomplished in normal time.
Check the drainage and replace or reposition the drain hose,Clean it out by running the disposer.
Feb 27, 2012 | Bosch Dishwashers
Error code F 21
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
Apr 05, 2009 | Bosch Classixx WFO 2866 Front Load Washer
Dishwashers Logo
65 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
