Question about HP Garden
8.5 hp b&s troybilt powerwasher won't let water flow thru & no pressure how do I repair?
arealplumber
  • 33 Answers
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Posted on Dec 05, 2008
  • 109 Answers
SOURCE: I have a Husky pressure washer with a Honda
check the quick disconnect to the wand these are spring operated and can get stuck
Posted on Aug 23, 2009
  • 1388 Answers
SOURCE: pressure washer does not spray consistent flow of pressure
Pressure washers have a pressure regulator/unloader that bypasses the water back into the intake when you let go of the trigger with motor running. If you let the machine run for long preiods in bypass the system could be damaged due to heating of the water being bypassed. The water is in a closed loop. The as the unloader wears it will tend to want to bypass which is what is happening in your case. Dirt trapped at the tip will cause this also. Install clean tip to solve problem. If clean tip did not help then try lowering the pressure by turning pressure regulator counterclock wise. If problem is gone then parts are failing but keep using pump. Good luck.
Posted on Jul 11, 2010
  • 6277 Answers
SOURCE: Water won't stop flowing thru detergent drawer
This is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
If it is doing it with ALL power removed it needs replacing. If it is doing it with power on it needs a service call to confirm that it is not something else- like the control board not feeding the correct voltage to the valve ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 11, 2011
  • 159 Answers
SOURCE: No pressure...new pump
Gun could be the problem if you hear the engine pick up speed and you can feel the pressure on the hose.if engine speed doesn't increase than there is a governor issue with the engine.
Posted on Oct 03, 2014
Why doesnt my powerwasher pump out water
check for a blocked jet in the end of the wand ( squashed hoses or blocked hose to the wand)
the blocked jet has the same affect as not pulling the trigger and the pressure regulator bypasses the water back into the pump
Sep 08, 2015 | Annovi Reverberi RMV2.5G27D Pressure...
Hayward h300 pool heater won't start
"LO" is simply informing you that the Heater is not sensing proper water flow through it! A Flow Problem.
A special sensor, called a pressure switch is this source. But... That does not mean it is bad - No, it is in most cases just doing its job!
Most common reason - Dirty Filter.
A good cleaning of the cartridges, or maybe a breakdown and recharge of a DE Filter, or a good cleansing backwash of your sand filter, will remedy this situation.
Or... Check for any OTHER reason or situations water flow may be reduced through the heater:
  • enough water in pool or spa?
  • If you have a weir gate in skimmer, is it stuck in the UP position?
  • Are any valves closed?
  • Do you have a bypass valve at the heater?
    • If open, this will reduce the amount of water going thru heater, close it to the point, LO goes away.
  • Could be debris in front of Pressure Switch, in the copper tubing
    • Unscrew and remove pressure switch, turn pump on. But first, align end of tube so that when water squirts out it will shoot out from heater and not onto electronic heater components!
  • If all above is good, you may have failed pressure switch?
  • Etc
Good Luck - hope this helped.
Sep 17, 2012 | Hayward H-series Electronic Gas Pool...
Powerwasher honda 13.0 running fine until gets hot after 30 min. cuts out every 5 mins after that.
If this has the thick silver gas cap, I have had similar problems on a number of these engines because it is a vented fuel cap and it will slow or even stop the fuel flow if they stop venting Try loosening or better yet replacing it. If that doesnt solve it then you may want to drain the fuel and put in fresh fuel Pressure washers will get water in the tank. Also make sure you drain the carb bowl. There is a bolt on the side of the carb bowl for that purpose.
May 08, 2011 | Honda 8 HP Engine
Powerwasher isrunning water is on squeeze handle and spray surges
When spray surges, the unloader is activating. Make sure that tip is not clogged. Test with a different tip / nozzle that is correct size for your machine (gpm is marked on tip ). If changing the tip does not help, reduce the pressure at the regulator. As the unloader wears, it will not hold pressure to the point that it will need to be replaced or rebuilt (replace with new is best) .
Nov 12, 2010 | Honda 8 HP Engine
Just fired up my Coleman Powerwasher 1100. I have
Nozzle is plugged. Stick small diameter wire in nozzle.
Aug 30, 2009 | Coleman Garden
Troy-bilt 2200 psi pressure washer
I have a Troybilt Model 2200 PSI Pressure Washer in which I have used only 2 times in the past 2 1/2 years. Went to use it this past weekend and the pump in not working. Water shoots out of the side. I bought this brand and model as I thought Troybilt was suppose to be so good. Went back to where it was purchased and had no success but to say I could buy another pump or take it in to be repaired. I believe that this power washer should be replaced at no charge. 2 uses does not constitute a few hundreds of dollars.
Have you to heard anything concerning pump problems on this particular model? Thanks for any advice. .
Jul 09, 2009 | Garden
Pressure washer with no pressure
Are you priming the water lines before you switch on the power?
i.e. with power OFF, hook up hose and turn hose on (doesn't need to have much hose pressure), then take your spray gun or attachment and pull the trigger and allow water to flow through the system (at hose pressure obviously). You might need to gravity feed it if its not flowing through...
But you will generally only get pressure once all the air is removed from the lines and the pump is pushing water only... Once you have water flow and lines are primed, switch on pump and see if that solves it.
Mar 17, 2009 | Briggs & Stratton Pressure Washer...
Garden Logo
Top HP Garden Experts
Vernon Taylor
michael vanier
Are you a HP Garden Expert? Answer questions, earn points and help others
