Question about Cameras
How do you open the battery compartment on Sakura shopper to get to batteries
  • Cameras Master
  • 5,412 Answers
I can find no reference to this particular make / model of camera - please could you supply further details
Posted on May 11, 2017
I need a manual for the amigo smart shopper cart
You will need a serial number, should be at the bottom of the steering shaft or in the battery compartment, call amigo at 1-800- myamigo for help when you have it
Jan 12, 2014 | Amigo Smart Shopper Scooter
Open battery compartment
Spray WD-40 around the compartment door and try to let it trickle inside the compartment. That should break the acid corrosion buildup that holds the door from opening.
Oct 19, 2013 | Nikon F601 35mm SLR Camera
I have a sakura electric bike and when I use the throttle the battery charge indicator drops to empty and it cuts out, however when I stop the charge indicator rises again. Any suggestions.
Sounds like your batteries are low in capacity and need replacing. The battery indicator is measuring voltage. As you draw power from the battery the voltage is dropping (sagging) because the batteries are weak/old. When you stop drawing power the voltage rises again.
Aug 12, 2012 | Electric Bicycle Motor, Bike,electric...
Where can i find a BAIGISH Sakura 10-70X50mm Night Vision Binoculars Scope user guide/manual online?
Dino Direct carries them and has a pretty good description for them but is not complete. If they opearte in the manner I think they do, hold down on the lever to power them- do not pump, just press and hold. Since there is no mention of a battery or cell, this is the usual alternate method to power them.
Otherwise the online information that is most complete is
Jan 12, 2012 | Optics
Cannot open battery compartment on Sony Cybershot rmt-dsc1 remote
@ Frans Bedford-Visser
On the right side of the battery compartment you can see some vertical plastic lines. Pull those towards the compartment. Simultaneously open the compartment as indicated by the arrow. It will open. Took me a while to figure it out but it works.
Jan 08, 2012 | RCA DIRECTV Satellite Remote Control
Have a sakura sh550a. pilot light only works intemittently. When it does the rest of the heating system fails to ignite consistently. What to do.
I have found that the 'D' cell battery holder is very tempermential. Some cell makes do not make continuity with the positive terminal. Energizer and Duracell are bad and I had to solder additional brass cap to ensure contact of the battery.
Aug 31, 2011 | Heating & Cooling
Opening battery compartment on Midland LXT80 2-way radios
First take the clip off by pulling the tab while sliding it down. Then once the clip is off, push in and down on the top of the battery compartment and it should come off.
Jul 07, 2010 | Midland LXT80 Two Way Radio
Electric bike cuts out while riding
Couple possibilites. If it is just a matter of your battery clips coming undone, tighten the with pair of pliers then reattach. If it cuts out, then reengages when you start pedaling, either your controler is shot, or you have a ground short on your wheel hub. How long does a charge hold, and how often does it cut out?
Jan 14, 2009 | Electric Bicycle Motor, Bike,electric...
Amigo smart shopper
Oct 19, 2008 | Amigo HD450 3 Wheel Scooter with 33AH...
Cameras Logo
48 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
