Question about Garden
I have a husqvarna 232r. I can not start it. I am not getting a spark from the new plug. What can I do
    Master:
  • 923 Answers
What is a strimmer? I need the definition please! Never heard of that term! Who makes it?
Posted on May 11, 2017
Husqvarna Problems
When it won't start have you removed the spark plug after cranking it over like you were attempting to start it cold with the choke on and then inspecting the spark if it's wet then you know it is in fact getting fuel enough to start and you can proceed with the next test which is putting the spark plug back on the plug wire and grounding the spark plugs base against the motor so it can ground and crank the motor over like you again were trying to start it and seeing if your getting a good blue colored spark that is blinking fast and doesn't stop blinking/arching at the plugs electrode. ( shut the choke and throttle positions off and when you ground the spark plug do so away from the plug hole) This test is easier if you have someone turn the key for you so you can watch what the spark plug is doing while cranking it over for about 5 to 10 seconds. If erratic or no spark and assuming you've changed the spark plug or plugs then something is grounding the shut off side of the coil or coils or you have a coil problem.
Nov 20, 2013 | Husqvarna Zero Turn Mower Z5426
My husqvarna 288 wont start, has extreme high compresion and cant pull cord with the spark plug in it. easy to pull with spark plug removed
http://www.ebay.com/itm/HUSQVARNA-288-CARB-REBUILD-KIT-COMPLETE-TILLOTSON-NEW-/140290773535 Your carb.may need rebuilt,remove and inspect,did you leave gas in it while it was stored,if so then carb is suspect.About 80.00 for a shop to repair,14.00 for you to do it.
Oct 10, 2012 | Husqvarna Garden
Almost new husqvarna chain saw will not start
Back to basics, clean fuel in the tank? is there a spark at the plug? does the plug get wet after pulling machine over?
May 28, 2012 | Husqvarna Garden
Have a husqvarna 125b have spark and fuel wont start done every thing i know new plug rebuilt carb gaped coil im tired of pull on it any answers please help it
the rule of thumb is spark, fuel, compression. I found I gad a plugged air filter. It would not start until I removed it and tried to start.
May 07, 2012 | Husqvarna 28cc Hand Held Blower HVH 125B
Husqvarna model 125b Hand held blower (Gas) No
If you have tried a new spark plug and you still have no spark, then your Ignition Coil, (Module) has gone bad. They aren't cheap if you buy it new. Try to find a used one if you can for around $10.
Good Luck!
Jim
Aug 02, 2011 | Husqvarna Hand Held Blower 125 B Grass...
Husqvarna 14" chainsaw wont start. put new plug
Try a new spark plug.If still does not fire you have a bad ignition coil.
Nov 26, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My Husqvarna 232R brushcutter pull cord will not start
There should be several 'dogs' exposed after removing the starter assembly. These 'dogs' should rotate into the flywheel nut when the cord is pulled causing the engine to turn. Check with a Husky servicing dealer for parts. Good luck!
May 24, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Can't start my Chain Saw Husqvarna 350.
The fuel may have been replaced, but is the fuel filter clean or is the fuel line cracked? Even though you cleaned the spark plug, did you check to see if it has a spark? If not, maybe a new spark plug or check the wire to make sure there is nothing blocking where the wire and spark plug connect. Is the air filter clean? Just a few more things to check out...
May 14, 2010 | Husqvarna Chain Saw 20" Bar
Brand new 359 chainsaw won't start
As this is a brand new chainsaw, DO NOT start taking it apart and tinkering with it, for the simple reason that it is covered by the Husqvarna warranty and you should be able to have it either repaired or replaced without cost to you!
Here's the web link for Husqvarna customer support. You can also contact the place you purchased it from, as they should be an authorized dealer in order to sell the Husqvarna chainsaw products.
http://www.husqvarna.com/us/homeowner/support/customer-support/
IF, you bought this from a friend, etc., it would still be covered if it's new and unused when you purchased it.
That is the best recommendation you can get for resolving your issue and to keep your warranty valid.
Since without more detailed information, (gas is flowing into carb, spark plug getting spark, good compression, plug not fouled, on/off switch not malfunctioning, kick back/chain bfreak working, etc., etc.), no one can possibly provide an answer to resolve the issue.
Hope you find this Very Helpful and best regards!
Aug 13, 2009 | Husqvarna Garden
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
