Question about Garden
Where to get a kohler k141 internal coil for a rotivator
    New Friend:
  • 48 Answers
You can try stens.com and see if they have a listing for an aftermarket part
Posted on May 11, 2017
25hp kohler hot start problem. Replaced fuel filter, plugs and cleaned air filter - same problem. it won'd restart when hot.
3 possibles come to mind
fuel vaporization in the line to the carby or in the carby bowl (check float level adjustment)
valves are being held open when hot--- valve stem lengths increase reducing tappet clearance___adjust valves when hot
check coil/ ignition module for failure when hot as they can open circuit ./ short circuit when internal components fail from heat
Sep 27, 2016 | Kohler Command V-Twin Horizontal Engine...
How to set up the governor on a Kohler K141 petrol engine on Howard rotovator
if it is a petrol engine then the governor arm will hold the carby open when stopped
as the engine starts the governor moves the arm to close the carby off to idle. the speed setting is by a spring attached to the throttle level and a point on the governor lever
Feb 13, 2015 | Cars & Trucks
Atco manual
http://www.allotment-garden.org/rotovator/manuals/Wolseley-Merry-Tiller-Manual.pdf
In the UK the Merry Tiller was produced by the Wolseley company until the 1980s when a change of company policy led to the manufacturing side of the business being sold off to Atco. Over the years the design had changed, making it more expensive to produce. This, coupled with changes of Atco's ownership and increased competition, led to the end of production in the UK.
Jul 09, 2014 | Garden
Are there a difference in the coils on a 26 hp kohler?
Yes and the numbers should match up on both old coils. The new coils will have a different part number because they have updated them.
Jul 03, 2014 | Craftsman Kohler Courage 26 hp 54" Garden...
Can u sustitute a car ignition coil for stock coil on a kohler engine?
Should be OK as long as this Kohler has a 12v system(like my early 70's Cub Cadet).
May 04, 2012 | Desa International Garden
How can i open my AKG k141 studio headphone to repair it ?
I had a problem with my AKG K141 Studio headset. The right side stopped working. Hard to believe but one of the leads to the ear speaker was disconneted from the solder lug. To disassemble, pry the gold AKG emblem using a jeweler's screw driver. You can pry it without damage by locating a small notch on the black plastic rim at the 6 o'clock position. Then unscrew ththe tiny phillips screw and remove black disc. You will see two leads (red and white) feeding through a hole. Disassemble removing a larger screw. This will give you accesss to the solder lugs.
Nov 30, 2010 | AKG K 240 Studio Professional Headphones
Hello, I need to know how to adjust engine timing for Kohler Command, 22hp engine, manufactered in 2007 on a Cub Cadet 2544 Heavy Duty tractor. Thanx, Rick
If you have what i think you have. The only timing adjustment as such would be in the coil to magnet air gas. Which is usually around .125 thou.
The other timing is done internally, when you line up the marks on the cam gear with the marks on the crank gear. good luck and be careful
Sep 21, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Engine Dies and will not start when PTO is off, brake depressed.
Try this guys web site he can help you http://www.jimsrepairjimstractors.com/allequipment.htm
I don't know if it's a diesel or gas rig and if it has electronic ingtion or not so this guy has the parts and know how.
May 30, 2009 | Garden
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
