Question about Poulan Garden
How change blade drive belt poulan mower model #733-848
    Master:
  • 923 Answers
My poulan pro lawnmower blades are not cutting when running
Are your blades installed up side down?
Is the blade drive belt installed properly or are the blades turning backwards? Is the belt too loose and slipping?
Are the blades dull and need sharpening?.
Oct 04, 2014 | Garden
I have a poulan pro series pdgt26h48 and the blades arent engaging just put a new drive belt on
you must make sure the drive belt is tight. you could have a bad switch or electric clutch or a bad seat safety switch
Jul 08, 2012 | Poulan Garden
Not moving forward
the blades and the drive use different belts take a look at the drive belt
Apr 07, 2012 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I cannot get my Poulan riding lawn mower to go into gear. What am I doing wrong?
Check your drive belt underneath the engine (on a crankshaft pulley) and make sure it is connected to the drive pulley on the transaxle (this area is under and probably just behind the seat. Don't confuse this drive belt with the belt that runs the blade mandrells on top of the cutting deck.
Apr 13, 2011 | Poulan Garden
The mower blade drive belt on my Poulan Pro 16.5 HP, 42", model #310777 broke. The only manual I could find was for a model 60614 which was of very little value to me. The parts store sold me a Gates...
The only thing I can suggest to get you in the ballpark of what is wrong or if you can replace what you need replaced is to look on the Poulan website and get a customer service phone number. Chances are they will know exactly what you need. Hardware stores are too broad and it sounds like you need specilized attention.
Aug 07, 2010 | Poulan Garden
I need a diagram to assist in changing the drive
IF YOU WOULD POST A MODEL NUMBER FOR THE MACHINE THAT YOU WANT ADVICE FOR, IT WOULD SAVE A LOT OF TIME AND SOMEONE WOULD BE ABLE TO HELP YOU. IF WE HAVE NO IDEA WHAT YOU ARE WORKING ON, WE DON'T KNOW WHAT ADVICE/ASSISTANCE TO OFFER!!!
Sep 29, 2009 | Poulan Pro 22" Self Propelled High Wheel...
You have to hold the mower blade engagement lever, which engages the mower blades to turn.Poulan model PXT12530
sounds like the belt is stretched, check the belt or get a smaller belt, doesnt take but a quarter inch to effect engagement
Sep 25, 2009 | Poulan Garden
Poulan mower throwing the belt.
1) Remove the cover on the top of the belt and
remove the belt from the transmission pulley
2) Lean the mower back on its handle and secure it
with whatever you have that will keep it there while
you work on it, any heavy object will do
3) Remove the blade bolt, the blade, the blade
adapter and the plastic belt guard from the bottom
You should now be able to remove the belt
4) While you have the belt off, closely inspect the
pulley on the engine shaft, they sometimes get
grass built up in the groove and this will cause
the belt to run off and also wear prematurely.
Hope this helps you out
Chuck
Mar 15, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Drive and blade engagement shutsdown the engine.
Sounds like the seat safety switch.
Mar 05, 2009 | Poulan Garden
Garden Logo
44 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
