Question about Frigidaire Dishwashers
Frigidaire dishwasher error code .30 - Frigidaire Dishwashers
2 Suggested Answers
SOURCE: Frigidaire Dishw. Error code CL
this just happened to ours and it turned out to be the gasket that seals the door.
when you see the CL error and the door is indeed shut, pull gently back on the door. if you hear a click and the unit starts running again, it may be the gasket.
ours lost it's ability to keep the seal, allowing enough 'play' in the locking mechanism for it to think the door was not closed.
Posted on Sep 09, 2008
What does code Uo mean on the dishwaher
It is a Vent problem. The vent aids drying at the end of the cycle.
Frigidaire Diswasher ER UO Error code [FIXED] - Appliance Repair ...
forum.partsdr.com > Forum > Appliance Repair Help > Dishwasher Repair
May 25, 2012 - 20 posts - ‎3 authors
The ER UO error code means "Vent Open". On the top back right corner of the dishwasher tub, there is a vent and fan that opens to help dry the ...
Frigidaire Dishwasher Error Codes - What To Check - How To Reset ...
https://removeandreplace.com/.../frigidaire-dishwasher-error-codes-what-to-check-ho... Feb 18, 2016 - The error code will display where the usual numbers are on the display screen. .... Do you have an error code on your Frigidaire dishwasher and need ..... Can you tell me what do you mean by "knockout plug has been removed"? ... Frigidaire dishwasher manual says UO error code is vent assembly error.
Diagnose UO Error Code - Dishwasher - YouTube
? 3:15
https://www.youtube.com/watch?v=pvJTiTd35vI
Dec 22, 2016 - Uploaded by Byrd Appliance Specialists
Byrd Appliance Specialists 3825 Gilbert Dr., Ste. 342 Shreveport, LA 71104 www.byrdas.com 318-459-8745 ...
My Samsung washing machine is showing a UE code during a spin ...
www.samsung.com/uk/support/skp/faq/1025292 Jul 5, 2016 - Your appliance will display a UE code when it has detected an unbalanced load and has stopped the ... If the door remains locked and the machine is displaying UE error, please run a drain program. ... What does this mean?
LG Help Library: Error Codes - Dishwasher ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library May 10, 2017 - An error code on the display of the dishwasher can usually be resolved by performing a few simple troubleshooting steps.
LG Help Library: UE Error Code - Top Load Washer ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library Sep 1, 2017 - After 3 attempts to balance, the uE will change to UE, meaning the unit was unable to rebalance the load and requires assistance. To determine ... What does code UE mean on the dishwasher Google Search
Oct 31, 2017 | Dishwashers
UL error code on frigidaire dishwasher
Thank you for your inquiry, Elizabeth!
I see that your Frigidaire dishwasher is displaying an error code of "UL" and you would like to know what it means. A "UL" error code means that your dishwasher is in relay test mode. You should be able to clear out the error code by pressing cancel and holding down the hi-temp button. If that does not clear out your error code I would suggest performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for at least ten minutes. Hopefully this information is helpful. -Matt
Apr 24, 2015 | Frigidaire 24 in. FDB635RF Built-in...
How do i clear error code u0 on frigidaire dishwasher
pressing cancel twice should remove the error code. if not interrupt the power to the dishwasher for 30 seconds then apply power to the dishwasher. also verify proper voltage is applied to the dishwasher. all should be done by a trained appliance repair technician.
Aug 13, 2014 | Frigidaire Washing Machines
What does a co code on a frigidaire professional series dishwasher mean
Good Morning Friend,
I understand that you are receiving a CO code on your Frigidaire Professional Series dishwasher, model# PLD3465REC. C0 means that there is some type of communication error. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and run any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 25, 2014 | Frigidaire 24 in. PLD3465REC Stainless...
Error code 125
Hello Lou,
I see that your Frigidaire dishwasher will not start. I would recommend giving the appliance a hard reset. You will do this by switching the circuit breaker off that the dishwasher is attached to. When you do this you will want to leave it off for 20-30 minutes. Once the 20-30 minutes has elapsed, bring power back to the dishwasher and try to restart it. If you are still receiving a 125 error code and the dishwasher is not starting, I would suggest contacting your local authorized technician to diagnose and see why you keep receiving this error code.
-Best Regards-
Jan 22, 2014 | Frigidaire PLD4555RFC Dishwasher
Dw will not start
Hi Jana,
So I'm understanding that your Frigidaire dishwasher will not start, and that when the "ON" button is pressed it only stays lit green while your finger is on it. I would recommend giving the appliance a hard reset. You will do this by switching the circuit breaker off that the dishwasher is attached to. When you do this you will want to leave it off for 20-30 minutes. Once the 20-30 minutes has elapsed, bring power back to the dishwasher and try to restart it. If the dishwasher is not starting, I would suggest contacting your local authorized technician to diagnose and see why you keep receiving this error code.
-Best Regards-
Jan 21, 2014 | Frigidaire FFBD2409LB Dishwasher
Dishwasher code 30
Hello Paul, thank you for your inquiry. According from my research Frigidaire does not have an error 30 for dishwasher. Could the error code possibly be an E03? Let's try resetting the dishwasher by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes and then turn on the dishwasher. If the unit displays an E03, then it typically indicates that there is a failure with either the wash motor or motor hall sensor. I suggest checking for suds in the tub and siphoning. A further diagnoses is recommended to have a professional check the wiring between motor and main control board since either part could need replacing.
Aug 17, 2013 | Electrolux Dishwashers
Frigidaire dishwasher model FDB2320REC0 when I push the normal wash CL flashes
Hello linda_ross88 - Typically CL indicates that the main control board is not sensing that the door is properly closing. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, typically an expert would need to check the door switches, wiring, and test the main control board. Regrettably, this is not a simple DIY job. I would strongly recommend seeking a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
Mar 18, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
113 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
