Question about Dryers
How can I start it? It does not have a switch to start
  • 1,830 Answers
What type of dryer is this? All dryers have a button to start them.
Posted on May 11, 2017
Thanks.. I have a onan 7500k living in from the storm. Will not start with remote inside switch. But you can shut it off with inside switch. Outside switch works great.
Need more info.
Inside does it have an 'on/start' switch and a separate 'off' switch ?
If it does -
1) the start switch is bad.
2) could be a broken/loose/corroded wire at the start switch 3) broken/cut wire to the Onan
4) broken/loose/corroded wire at the Onan where the inside start switch connects.
The fact that it starts at the Onan tells you it's OK.
Sep 17, 2017 | Electrical Supplies
Speed queen 30eg wont start. I have power through the switches all the way to the motor. I can hook the motor up direct and it runs fine, but i cant get it to start with the push button start
If you can jumper across the start switch you can eliminate the start switch as the problem. The switch acts as an open in the start control wiring. If the unit starts when you jumper across the switch, then replace the switch. If you are uncomfortable in jumpering out the switch you can unplug the dryer "disconnect power" just unplug the dryer then use a multimeter to read across the switch. Place the meter on continuity mode for an audible beep. If the meter doesn't beep when you press the switch to close the contacts, then replace the switch. Hope this helps!
Feb 16, 2017 | Speed Queen Dryers
How come I can't start my John Deere LA115 after
The Reverse Interrupt Override switch is supposed to let you keep the blades engaged while using reverse. Be sure PTO is off and brake pedal is depressed and try to start engine. If it wont start/ wont crank then a switch is stuck or failed or there is a broken wire. Switches that are involved with PTO operation are the seat switch, reverse switch, PTO switch, and RIO switch. The starting system requires neutral ( no reverse activated), brake switch and PTO switch off.
Sep 02, 2014 | Garden
Motorcycle will push start but not ignition switch start
Does it turn over when trying to start? If no then it could be the starter, switch, or battery. Sounds like the starter, especially if you tried another switch.
Apr 14, 2014 | 2008 kawasaki Ninja 250R
The dryer runs without the start switch being used.
Good day,
The dryer start switch, starts the motor by bypassing the centrifugal
switch built into the motor. Once the motor is running, releasing the switch doesn't matter because the motor gets it's power directly from the timer to the motor thru the centrifugal switch.
Either the switch on the consul has welded the contacts, or the centrifugal switch in the motor has done the same.
To test, unplug, and access the start switch. remove one of the wires from the switch, tape it to prevent shorting, and try the dryer. If it fails to start, then it is the switch.
If it still does the same thing as before, it is the centrifugal switch in the motor.
Dec 22, 2009 | GE Dryers
Probably either a bad interlock contact in the safety switch OR a mechanical problem in actuating the switch. Use a continuity tester on the switch to diagnose.
Oct 17, 2009 | Ultratec Miniprint 425 TTY Printer
G.E. electric dryer will not run, when you turn the switch to start it only hums. What could be the problem, it is only 3 years old. Thank you
First of all check your door switch, make sure it is operational.If the door switch checks good, the start switch could be faulty, in newer dryers the start switch is built into the timer in older dryers your start switch may be seperate, if you have to push on the timer dial to start the dryer, its built into the timer.
Check any other safteys that may be stuck open.Double check anyway. If it wont do anything, I would say its the door switch or the start switch.
Aug 27, 2009 | GE Dryers
Dryers Logo
Top Dryers Experts
