Question about Toro Garden
My toro 8hp model 56145 riding mower starts and stalls after above 1 minute then will restart after 1 minute repeatedly fuel filter and seat switch both good, any ideas???
    New Friend:
  • 48 Answers
Try cracking gas cap lid first and see what it does
Posted on May 11, 2017
Not getting gas to carb. changed fuel pump, bypassed filter. hold gas line below tank and fuel comes out. but not being sucked through pump it appears. help
It has a pressure differential fuel pump, just put a little fuel in the carb. and it should start it may stall but do it 1 more time and then it will stay running as it uses the crank pressure to actuate the fuel pump
May 08, 2015 | Toro Garden
My model 917 riding mower stopped and will not restart; it won't even turn over. where do i start?
start slowly. battery and connection. safety switches seat clutch etc.
fuel and filters. engine oil level.
cheers
Sep 24, 2014 | Garden
Model 56145. How can I remove mower deck?
Look, lower deck as low as it will go, look above deck, under the tractor and pull any pins holding deck to the control arms etc., and remove belt sufficiently to slide deck out from below tractor, I advise you to take pictures to make assy. easy.
How to remove the mowing deck from lawn tractor
Craftsman Deck removal How to
Removing and attaching mower deck
How to Remove the Mowing Deck From Toro eHow
Jun 17, 2012 | Toro Garden
Toro wheel horse rider recycler 8hp-25inch cut model#56132 how to remove mower deck
Jump onto www.toro.com and download the free service manual for your machine. Note down all the details on the ID plate on the mower, you will need it to find the correct manual.
Apr 30, 2011 | Toro Garden
Toro mower quick running after 5 minutes - repair shop said cleaned carb jets, air filter, plug - same thing next time I ran it - repair shop then said it was probably the fuel cap vent. Just run it for...
Hi and welcome to FixYa. First off having worked in lawn mower shops personally you should take your mower back to the shop you had it repaired in. What you have is what we in the biz call a repeat disrepancy. Most likely there is a fuel supply problem if the jects have been cleaned. The problem can be:
1. Debris in the bottom of the fuel tank.
2. Clogged fuel filter
3. Float needle and seat is not opening fully or there is debris in the needle seat.
4. Clogged or pinched fuel supply line.
That is about it but I am telling you the repair shop owes you a free labor fix for this. You may have to purchase a needle and seat for around $5 - $6.00 and or the cost of a new fuel filter but, they certainly should eat the labor.
Thanks for choosing FixYa.
Kelly
Sep 18, 2010 | Toro Lawn Mower With Toro Power Tools
Simplicity Broadmoor only runs for a minute or two and then quits
Check both the air and fuel filters. Either being clogged would give this situation. It could also be dirt in the fuel line. Disconnect at both ends and blow them out. If none of the above helps, then the problem is likely in the fuel pump or carburetor and will take some disassembly.
Jul 07, 2010 | Garden
Lt 1045 runs 20-minutes then stalls and everthing
It could very well be something simple. There are Oil level sensors that are pretty fussy. What can happen is just the slightest drop in oil level can cause the oil level switch to kill the ignition. If there is a safety relay connected in the oil level switch it can prevent starter use also.
On of the tings I would start looking for is the condition of the battery cables. (both ends) Check for a loose ground or a loose starter connection.
ALSO
Seat safety switches have been known to cause the problem you describe. On newer model riding mowers there is a switch on the seat that there must be someone sitting onthe seat for there to be any power to anything on the mower.
Check the seat switch wiring and connectors. You could have a loose connection on your seat switch that is simulating no one in the seat even though there is an operator.
AThat is it for now.. give the above a shot and if the problem persists just respond here and we can continue troubleshooting.
Kelly
Apr 16, 2010 | Cub Cadet Street Sign- tractor lawn riding...
2002 craftsman 23 hp kohler pro series stalls and wont restart
try playing with the throttle adjustment or it could be a saftey feature malfunction, like the seat shutoff for example.
Feb 25, 2009 | Craftsman Garden
Garden Logo
60 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
