Question about AT&T Lands Phones
I have an AT&T Digital Answer System Model 1740. How do I turn off the Audible Message Alert
4 Suggested Answers
  • 39 Answers
SOURCE: Audible alert
Run Array Configuration utility from your SmartStart disc. If the array is degrades the system will show to you.
Posted on Dec 17, 2007
freetek
  • 5568 Answers
SOURCE: Audible Ready Alert
I see these posts are quite old but will respond anyhow.
The transducer that is making all the racket is probably a piezoeletric 'speaker' that uses a crystal to which voltage is applied.
These range in size from 1/2" to several inches in diameter but are almost always round (I've seen many and they were).
Look for a cylindrical part in that range of diameter with one (flat) side open.
It will have two wires attached and either one is OK to cut but you might want to use small, heatproof (ceramic) wire nuts to screw on the the clipped wires to avoid causing something else to fail because of the bare wire end.
Posted on Aug 15, 2008
  • 7 Answers
SOURCE: It has no sound without headphones for music or
Turn off the Blue Tooth and try it again
Posted on Mar 03, 2011
Is there a way to fix the the turn signal chime and other various chimes on a 2009 Chevrolet Cobalt LS, there is no sound from them as well as front speakers?
The audible warnings alert the driver of a system concern or a critical vehicle condition. The radio generates the audible warnings through the speaker. The radio receives audible warning requests via the serial data circuit. If the radio receives multiple audible warning requests, the warning with the highest priority sounds first. The following lists the audible warning priority and the pulse rate:
Fast rate chime (200 pulses per minute)
Medium rate chime (150 pulses per minute)
Slow rate chime (50 pulses per minute)
Single chime
May 13, 2016 | 2009 Chevrolet Cobalt
Where is my door chime located impala 2002
It comes through the radio an left front speaker .
The audible warnings alert the driver of a system concern or a critical vehicle condition. The radio generates the audible warnings through the left front speaker. The radio receives audible warning requests via the class 2 serial data line. If the radio receives multiple audible warning requests, the warning with the highest priority sounds first. The Multifunction Alarm generates the audible warnings on vehicles with RPO UL5 -- Radio Delete Option. The following lists the audible warning priority and the pulse rate:
The radio activates the door ajar audible warning as requested by the body control module (BCM). The BCM sends a class 2 message to the radio indicating the chime frequency of a medium rate and at a continuous duration. The door ajar warning sounds and the door ajar indicator illuminates when the following occurs:
  1. The body control module (BCM) determines that the driver's door is open and the signal circuit low. The IPC receives a message via class 2 from the BCM requesting illumination of the door ajar indicator.
  2. The vehicle is not in park. The BCM receives a class 2 message from the PCM indicating the gear position.
Class 2 Serial Data Link
The class 2 serial data link allows the following modules to communicate and share data with each other:
Auxiliary Power Drop Connector
Body Control Module (BCM)
Driver Information Center (DIC)
Electronic Brake Control Module (EBCM)
Instrument Panel Cluster (IPC)
Powertrain Control Module (PCM)
Radio
Remote Playback Device-CD Player (if equipped with UQ3)
Inflatable Restraint Sensing and Diagnostic Module (SDM)
Vehicle Interface Unit (VIU) (if equipped)
The class 2 serial data link allows a scan tool to communicate with the above modules for diagnostic and testing purposes.
Nov 16, 2015 | Cars & Trucks
First alert 9120b
Hi hislop_amand,
I know this is coming to you late yet I just seen your post and hope the following can still help you or others.
Kind Regards,
SD
FIRST ALERT Model: 9120 9120B
Normal Operation (AC Power)
Green LED ON; flashing Red LED once/ minute
No Audible Alarm
Normal Operation (DC Power - 9120B only)
Green LED OFF; Red LED flashes once/minute
No Audible Alarm
Mar 23, 2013 | First Alert SC9120B Smoke / CO Detector...
Led display shut down when the detector detect an alert
You have the unit in dark mode. Press the Dim/Dark button again to get the unit to full brightness. THe unit has 3 levels of DIM. First the unit is at its full brightness, pressing the dim/dark button will dim the display and the unit functions normally. Press the Dim/Dark button again will futher darken the display but when the unit alarms the display is turned off and remain off during the alert. After the alert is over the unit waits 20 seconds of no alert to turn the display back on.
Mar 09, 2011 | DE-1740 Radar Detector
Mobile phone - message tone alert?
I do not have the phone or the manual...however here are my recommendations from the phones i have owned.
In the phone settings there should be a sound tab. This allows you to select rigntones and alert tones and alarms. Also there are different profiles that you can select ie: Normal- will play ringtones and all audible alerts and alarms...Silent: Will vibrate only and not play any sound ( even though you have selected a certain sound to play)....hope this helps
May 05, 2009 | Cell Phones
Message alert volume
It seems to be a problem on all these Sony Ericsson phones.
You can make it louder by going to setting/profiles and select an outdoor profile.
Also choose a sound that is very audible, you'll have to download one. I recommend: Zedge, http://www.zedge.net/
and a bonus, http://www.ownskin.com/
Dec 19, 2007 | Sony Ericsson K800i Cellular Phone
Audible alert
Nov 07, 2007 | HP Compaq ProLiant DL380 G4 Server
Lands Phones Logo
49 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
