Question about The Watches
How do I set the time o a OmegaChronometer, Constellation with a 1343 movement ?
Just a quick question On my Omega Double eagle, I went to mexico for the week left my watch at home and when I return I gave it a shake to start the movement being it is a chroncile watch and for some...
A mechanical watch will tend to stop in the same place if an internal gear is slightly unbalanced and/or there's a spot of grease/dirt that makes that particular point on a gear slightly more difficult to pass. I've often seen watches with day/date indicators stop just around midnight, as it takes more energy to advance those dials than just move the hour and minute hands.
Try winding your watch with the crown as opposed to shaking it to wind it via the automatic rotor. Actual winding will bring your mainspring up to full power much faster than a whole lot of winding via automatic rotor. See if this changes the behavior of the watch. If it doesn't, you probably need to have a watchmaker take a look at the watch. He or she will probably recommend cleaning the movement to clear any dirt that might be causing the problem.
May 08, 2011 | Omega Constellation Double Eagle Gold &...
How to set time
after screwing the crown out we have first, second and third positions . If the movement calibre is 1570 the second position is for setting the time and if the movement is 3035 the third position is for setting the time.
Jan 23, 2011 | Rolex Datejust SS
Omega constellation self winding watch stops
Omega claim that your watch will run for 40 or more hours, so stopping overnight should not happen. I doubt if you need to be particularly active to wind up the watch, otherwise this would make the problem quite common. My one experience of owning an automatic did not raise this sort of problem.
Discuss your problem with your supplier and describe your use. As you correctly say, having to hand wind i defeats the point of buying an autoamtic. (It could be that you have been sold two duff watches, however unlikely this may seem, it could happen).
Jun 06, 2010 | Omega Constellation 95 1262.15 Watch for...
Where is the + or - in the watch ?
99% the - is in the watche's movement and the + is facing outwards from the watch. Rate me, plz.
Apr 13, 2010 | Omega Constellation 1267.75 Wrist Watch
Reserve time on my omega constellation
The watch needs a warranty repair. It should run for 36 hours at least
Jun 18, 2009 | Omega Constallation 1502.40 Wrist Watch
I seem to be haveing a problem setting my fossil watch. The model tipe is jr-8748,every time I try to set the date and time all I get is different time zones in different countries.
Digital watches all work from a memory chip on the movement. The most common problem is the memory is filled or corrupted when you cannot seem to re-set them. In most styles, pressing and holding all the set buttons in at the same time for three or four seconds can fix this error. The dial will clear and the time and alarms must then be reset. If not you may need to have a watch technician use the AC button inside the case on the movement. He will need to use a metal tweezers and touch the + side of the battery to the AC contact point on the movement.
Dec 24, 2008 | Watches
Watches Logo
13 people viewed this question
Top The Watches Experts
John mullen
D. E. Hev
 Larry
Larry
Are you a The Watch Expert? Answer questions, earn points and help others
