Question about Sewing Machines
Bobbin wind on Viking model 6690 - Sewing Machines
SOURCE: Bobbin won't wind
I have checked the gears underneath and see no missing teeth for the bobbin part. The bobbin "seat" does raise, but does not engage. Thanks
Posted on Dec 23, 2007
SOURCE: I have a Brother model
just wind the thread around the bobbin, don't put it through any holes, wind it around the center pole,
Posted on Aug 10, 2008
  • 111 Answers
SOURCE: I have a Viking 6690.
when you say "bobbin tension is loose" do you mean that the thread bunches up under the fabric? If yes, then your UPPER tension is wrong and it's probably not threaded correctly.
Posted on May 04, 2009
  • 208 Answers
SOURCE: Viking Husqvarna #1 + - A bobbin was stuck on the
The black plastic ring must be put back on with it oriented correctly. It can be a bit tricky, but experiment different ways.
Another small part may have come off too. If you can't get it, a Viking tech can do it for you without much trouble.
Posted on Jul 11, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
How do you wind a bobbin on a Viking 6570 sewing machine?
Unfortunately, I'm unable to locate a web site or video for this beautiful machine. You can get a user manual from Husqvarna/Viking here:
Husqvarna Viking sewing machine manuals
Service manual here:
Viking Husqvarna Sewing Machine Service Manuals
Not your model, but may be helpful:
Demonstration Video of Vintage Viking 6690 Sewing Machine
viking husqvarna 6440 sewing machine
Aug 03, 2017 | Sewing Machines
How to wind a bobbin for a 250 electronic Viking Husqvarna machine
Make sure that the presser foot is raised if you are winding a bobbin with the top thread threaded through the needle. Place the bobbin on the spool spindle with the mark (a stylized H) outwards. Bring the bobbin spindle down. Next pull the thread from the needle under the presser foot to the thread guide on the right. Bring the thread above the bobbin and wrap the thread around the bobbin several times. Cut off the excess thread on the thread knife and step on the foot control to wind the bobbin. When the bobbin winding is finished, remove the bobbin from the spindle. Cut the thread to separate the bobbin thread from the needle thread. Move the bobbin spindle up. has a link to the manual for the Husqvarna Viking 250 on the machine specific parts page (under Manuals), . The direct link to the manual is$FILE/Viking%20210,%20230,%20250%20%20x.PDF . The bobbin winding steps are on page 12. There is also a method for winding a bobbin with a different thread from the top thread. See the manual.
I hope this helps.
May 28, 2017 | Husqvarna Sewing Machines
I just inherited another Huqvarna (this is a model 630). It was working great until I wound a bobbin on it. After I removed the filled bobbin the machine won't move the needle up and down (but the bobbin...
I do not know the Husqvarna Viking 630. However, I have used the Viking 6690 and it has a similar on-the-side bobbin winding routine. I suspect that you failed to move the bobbin winding mechanism back into the sewing position. Look closely at the area around the bobbin winding spindle. It looks like there is a lever below the spindle. Does this need to be moved or rotated? Double check the steps in the manual and check that you did the opposite steps of preparing to wind the bobbin.
On the 6690, you pull out a knob after removing the bobbin. (You push this piece in and put the bobbin onto the now exposed spindle for winding.)
I hope this helps.
Dec 21, 2014 | Sewing Machines
Raise feed dog
I have a different model Viking with a feed dog button to the left of the power button. When it's pressed down, the feed dog stays in the "down" position. Press it again to bring the feed dog up.
May 19, 2010 | Husqvarna Viking 1
It isn't winding evenly. Is there somewhere it should go from the spool before the bobbin holder? this is a Viking model 90
I cannot find anything on this model.
Try this site for free threading and bobbin winding guides and may be one will be like the model you have -
Mar 15, 2010 | Husqvarna Viking 1
How Need to know how to thread the machine and how
They have many different models so threading and winding the bobbin can vary due to your model. I would recommend calling them at: 1-800-474-6437 and see if they can get you a photo copy of your original owners manual.
Oct 15, 2009 | Husqvarna Viking 1
I have a Viking 6690. The bobbin tension is loose. How can I fix it?
Apr 17, 2009 | Husqvarna Viking 1
I filled the Bobbin, now how do I get it to go back to sewing
Something didn't click back in place when you removed the bobbin from the winding mechanism. Try winding another bobbin. Make sure it stops, then remove it. If the problem continues, take it to an authorized Husqvarna Viking dealer. They should still be able to take a look at it. Check Husqvarna Viking website for dealer closest too you.
Dec 16, 2008 | Husqvarna Viking 1
Bobbin winder is only thing that works
What model are you talking about? For my older Husqvarna machine you had to pull the bobbin winding bit out to wind the bobbin, then push it back in when you were done.
Dec 02, 2007 | Husqvarna Viking 1
Sewing Machines Logo
35 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
