Why does my fan continue to run no matter the settings on Lennox L7742U thermostat
  • Heating & Co... Master
  • 1,871 Answers
Remove the screen section of the tstat, as to get to the wiring and batteries. If the fan stops then, then it's the tstat. Make sure your fan setting is on auto, not on.
Posted on May 11, 2017
    Master:
  • 923 Answers
If you turn the thermostat OFF, does the fan STILL run?
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
Lennox 10hpb
change run capacitor on fan. or bad fan motor
Jul 06, 2014 | GE Zoneline AZ38H12DAD Split System Air...
Lennox troubleshooting
Your control may a defected relay to the blower under heating mode. If that is the case you will need a new control board or replay.
Feb 05, 2014 | Heating & Cooling
Heater won't relight after shutting down, but fan continues to run
Roger, you either have a gas supply issue or a voltage problem.
Since I don't know your aptitude and abilities pertaining to LP gas troubleshooting/testing procedures, I don't know how detailed you want to go...basically, make sure your propane tank isn't empty; or that the pressure regulator didn't freeze up. Make sure that it is rated and set for 28" of water column output.
Check to make sure all the wire connections are secure to the flame control terminal block and to each of the hi-limit switches.
Isolate & perform continuity checks to each electrical component, including the gas valve.
You'll need a manometer to test and set the gas input & output water column levels.
When the unit is running,, what color is the flame?
Is there a roaring sound?
Is the flame small and weak?
Dec 25, 2013 | Mr. Heater MH170FAVT Open Flame Gas...
Lennox Fan will not come on when set to ''auto'' position.
Expensive is relative, service calls are never free. But if you have an idea what the problem is, you are armed against an unethical service company. Now to what you describe, could be a couple things, first let me explain the difference in fan speeds. Furnaces that both heat and cool have multi-speed blower motors. High speed is for cooling and lower speeds are for heating. The fan switch at the T-Stat turns on the high speed fan relay. The lower speed fan is turned on by either a temperature activated switch (silver box mounted on front on furnace above burners) or a time delay relay which is solid state. That being said, your problem could be a defective fan switch or one of your blower motor windings has gone bad. Most motors have 3 or 4 speeds and a technician could just change speeds and all would be good. A fan/limit switch is not so expensive that you would replace the unit. Bottom line, unless your really handy, a heating company is in your future. Good luck and please rate my answer if it was helpful to you.
Dec 31, 2009 | Superior Lennox Blower Thermal Sensor -...
Lennox Gas Frunace fires goes out, fires goes out, fires goes out
Check your thermostat anticipator setting. If you dont know how to do this don't try on your own or you may damage your thermostat.
Dec 12, 2008 | Honeywell Electronic Programmable...
Heater no longer works on auto fan, only manual fan
When you call for fan in auto ensure your getting 24 volts at pin on control board, if it is not energizing then there is a problem with the relay.. Before you change out the expensive control board, try the therm..
Dec 09, 2008 | Heating & Cooling
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
