Question about Power Computers & Internet
SOURCE: Need to know where to purchase SimpleTech 96300-40001-001 12V 2A AC Adaptor
My AC adapter is fried too and I have only used this maybe a dozen times in the last year.
Posted on Aug 19, 2008
  • 1111 Answers
SOURCE: GPS doesnt turn on with power cord adaptor or 12v lighter socket
if you can verify that the car charger is ok, try plugging it in to your computer using the usb cable. the 1412 should charge with the usb cable. if it still doesnt turn on, try and reset the unit,little pin hole on the side.
Posted on Jun 12, 2009
  • 977 Answers
SOURCE: Can a 12V 6A power adapter replace a 12V 1.5A power adapter?
I'm not an electrician, but I do know that as long as the voltage matches EXACTLY (don't take the chance, most devices don't have a good resistor, or don't have one at all!), the current doesn't matter. I'll explain myself:
A consumer device (your scanner in this case) uses all the current it needed, and it practically doesn't need more! It take just what's necessary!
Connecting adapter which provide LESS is not enough, but more - isn't harmful!
Hope I helped,
Posted on Mar 14, 2010
Testimonial: "Excellent information! Thanks."
  • 1810 Answers
SOURCE: I need an AC 12v-5v powr adapter for a PROSCAN TV.
USE a simple laptop adapter thats whhat i did just tell the guy at local comp store 12 volts and 5 amps they should have 1 or able to order it also try a used comp store they abound on craigs list and kijiji canada
Posted on Jul 15, 2010
Lost my adapter of below drive
While I don't have any specific information about the drive in question.. I CAN tell you this:
MOST hardware works at 5v... Some (most) have an internal regulator to drove 9v or 12v back down to 5v... MEANING:
If this has your lost family's pictures on it, and its uber important to recover-- but you don't have the finacnes to purchase another to get the adaptor, etc..
START with a 5v adaptor.. move up to 9v..the eventually 12v... of course polarity is a concern (to not blow it up)... a multi-meter can fix that.
Ok.. thats the technical side.
EASY SIDE: Go but another... use the adaptor to get your stuff off.... return it... and get a new device.
Oct 16, 2012 | Samsung Pleomax (UHD6GB) Hard Drive
Pinout Details for HP C7671B transparency adaptor mini din connector
Cut the mini din wire, you will see four wires inside the sleeves. The red wire is positive terminal, and black wire is negative terminal. Use any 12V DC adapter to connect. The adapter will light up. Good Luck.
May 12, 2012 | HP Office Equipment & Supplies
Ac adaptor on my 32 Protron inch LCD TV no longer work
What is the current output of the adaptor? If it is AC and you use only the 12v to 3v it is ok. But if the current output of the adaptor is DC and you use both 24v to 6v and 12v to 3v there is some danger if use the new one. Remember that DC current have polarity.
Aug 29, 2009 | Protron PLTV-32 Television
Can i use an Xbox 360 bought in USA in India - given the voltage conversion required? would there be any seperate adaptor available for 220 volt usage in India
You can purchase a volt adapter (rather common in travel stores/airports) but over time the device's power-supply will wear out because of the frequency difference.
North America runs at 60hz
India runs at 50hz
Jun 30, 2009 | Microsoft Xbox 360 Console
Hp laptop model which are compatible internationally
I'm going to assume you are talking about power, since compatibility will be just with yourself, since you are the user.
With this in mind, any laptop will work. You may need to purchase an inexpensive power adapter/converter when you get to India or UK whichever is where you are going.
The power cord that comes with the unit can handle any electrical supply, so long as it is 50 to 60 Hz.
So, buy whatever you want, when you get where you are going, purchase a small adaptor to fit the electrical plug.
good luck
Jun 08, 2009 | Computers & Internet
Modem power adaptor
On the bottom of the Modem, it usually lists the type of voltage/current ratio, for example, My modem is a 12VDC in, output is .75A Through the modem. Each modem has its own power requirements. Therefore if they dont match, you have the chance of either underpower (which means no use) or overpowering (and killing your modem permanently)
Best suggestion si the same as above by cnavarro, Buy the Right power supply for it, dont just try anything. get the matching one. Otherwise it will be Incident A or Incident B. Neither would work well, and you would end up buying a new modem all together.
Oct 30, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Defect in AC adaptor
It's seemd you need a new AC Adapter. You can get a new Universal AC Adapter for your LCD monitor. Check out this website @
Sep 07, 2008 | X2Gen MG19MY 19" LCD Monitor
Computers & Internet Logo
29 people viewed this question
Top Power Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
