Question about Cell Phones
No longer have cell acces on my nexus 7 only wi-fi. Icon at top for cell signal is gone.
SOURCE: Where enable wi-fi acces on Averatec 6100 series?
right nest to the power button is the wifi antenna button insure that it is green indicating that it is turned on
Posted on Jan 09, 2009
  • 1768 Answers
SOURCE: Have a wi-fi signal, however when I attempt to con...
check what you are typing in a "word pad" or notepad to check if you have it in the right text.
make sure you don't have the "caps lock" on.
make sure you have the correct password.
Create a new if this profile is not allowing you to log in
Posted on May 22, 2010
  • 1267 Answers
SOURCE: I recently bought a Sylvania 7 inch netbook sold
Your OS should have an icon on the desk top that says WIFI Power, it is blue in color and this icon turns the WIFI on and off. When the button says off, the WiFi is on, the idea is that it is waiting for you to turn it off. If that is not on your desk top, turn the machine over and look for a small hole 1in diagonally right of the data plate. insert a tooth pick in that hole a depress gently to reset your machine.
It is looking for a password (WiFi Network Key) You have to double click on the little computer icon down in the right tool bar area, the one with the two side radiating arcs, and possibly has a small red X under it. The red X indicates that it is NOT connected. When you double click on that icon a window called RT28701 opens up, then you click on Wireless Information tab, then you cursor down to the name of your WiFi and high light it and click the connect box. Then another window opens up called Network Properties. Uncheck "The key is provided automatically" box. This will allow you to type in your "Network Key", the password that protects your network from outsiders. This "KEY" was set up when you installed the router on your server computer. If this does not work at first, turn the machine over on it's back and using a toothpick, insert it into the little hole about an inch diagonally from the right corner of the data plate, this will re-load a new copy of everything including the WiFi RT28701 driver.
sometimes this driver gets confused. See my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
Posted on Dec 28, 2010
  • 34 Answers
On the left side of the main screen, you will see an icon that says "WI-FI Power". That's the switch to turn it on. When you click it, a little box will appear that says "turn on" when it's off and "turn off" when it's on.
But you have to do more than that. Next, I suggest to Google "digitalgadgets.com". Find "Sylvania products", click on "7 inch netbook support" and follow directions.
For # 4 you will find your "hot spot" name". Click connect.
For # 5 you may have to call your "Internet Service Provider" (Charter, AT&T or whoever you pay for your internet-to get your "network keys", etc. Then click ok.
Next be sure you go to Start, Settings, Control Panel, Internet Options, General and then complete "User Agent (requires Browser Restart)" by selecting:
"Default" (same as Windows XP)" or
"Same As Pocket PC" or
"Windows CE"
I selected "Default" and was off and running.
-dka-
GeoffW1
  • 3961 Answers
SOURCE: unlock wi fi on nexus 7
From the app list, tap Settings, and you will see the wifi switch at the top. Turn it on there.
Posted on Aug 28, 2014
Zte tablet model k88 wont connect to wifi
Weak wifi signal or defective tablet or router.
Jun 27, 2017 | Tablets & eReaders
My zte lever won't hook up to my home Internet.. Please help
This tutorial will explain how to get connected to Wi-Fi on your ZTE Tania Connecting your phone to a Wi-Fi network means you can access the internet, download apps and perform other tasks without incurring data charges.
This guide will show you how to get connected on the ZTE Tania.
How to connect to a Wi-Fi network
  1. From the main menu either swipe right-to-left on the touchscreen or press the right arrow button on the top right of the interface.
  2. Scroll through the menu and find the 'Settings' icon, then tap it.
  3. Press the button marked 'Wi-Fi'.
  4. Tap the Wi-Fi networking On/Off switch to turn Wi-Fi on.You'll then see a list of available wireless networks.
  5. Select the network you want to connect to.
  • If you selected an open network, your phone will automatically connect to the network. Note that some Wi-Fi networks, such as ones you might find in coffee shops, restaurants, or hotels, may require you to enter a password in your web browser before you can connect.
  • If you selected a secured network a password box will pop up. Enter the required password and then press 'Done'.
When you're connected to a wireless network, the wedge-shaped Wi-Fi connected icon appears in the status bar and shows you the signal strength - indicated by the number of bands that light up.
Unless you have wiped your phone, you won't be required to re-enter Wi-Fi details again as your handset should remember them.
How to connect to hidden networksA Wi-Fi network might be hidden, which means the network name isn't broadcasted. In this case, it won't appear in the list of available networks on the Wi-Fi Settings screen and a notification won't appear when the network is in range.
To connect to a hidden Wi-Fi network when it's in range, you'll need to enter the network name and password. Remember that the network name and password are case sensitive.
  4. Ensure that Wi-Fi is switched on.
  5. Press the 'Advanced' button.
  6. Tap the plus (+) icon.
  7. Enter the network name.
  8. Press the 'Add' button.
  9. On the 'Sign In' screen, enter the password, then tap 'Done'.
How to disconnect from a Wi-Fi network
  4. Tap the Wi-Fi Networking On/Off switch to turn Wi-Fi off and disconnect from the wireless network.
Alternatively, you can also press and hold the network name and then tap 'Delete' to disconnect.
However, bear in mind this removes the security settings if it's a secured network, meaning you'll need to enter them again next time you reconnect to that Wi-Fi network.
http://www.knowyourmobile.com/products/15952/guide-how-connect-wi-fi-zte-tania
Apr 05, 2016 | ZTE Cell Phones
Undefined
When your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD is connected to a wireless network, you'll see a and-wififull.svg Wireless icon in the System icons at the top of the screen.
  1. Tap the and-home.svg Home icon at the bottom of the screen.
  2. Put your finger at the top of right of the screen and swipe down.
    The Settings shortcuts will appear.and-shade.svg
  3. Tap the and-settings.svg Settings icon.
  4. If required, tap the slider button beside Wi Fi at the top left of the screen. The button will turn blue and display On.
  5. Tap Wi-Fi. The list of available networks will appear.
  6. Tap the name of the network you wish to connect to.
  7. Tap Connect.
  8. If you see a lock icon beside the wireless connection, it means that the connection requires a password. You'll need to enter the password to connect.
Turning off Wi Fi on your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD You can turn off Wi Fi to keep your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD to keep from connecting to the Internet, which is also known as Airplane Mode.
Turning off Wi Fi extends your battery life, and also lets you use your Kobo tablet on an airplane or in a hospital.
  1. Pull and hold the power slider at the top of yourKobo Arc 7, Kobo Arc 7HD, orKobo Arc 10HD until the power off menu appars.
  2. Tap Airplane Mode.
Oct 27, 2014 | Tablets & eReaders
My new Nexus 7 wont go past the "Select Wi-Fi" screen although I have set the Wi-Fi up
I assume you're using a secure Wifi connection with a password and it seems like that authentication is not working. You could try using an open wifi access point to eliminate the possibility of this authentication issue.
Oct 04, 2014 | Google Nexus 7
Unlock wi fi on nexus 7
Aug 28, 2014 | Tablets & eReaders
Trying to set up on the nexus 7 , but having authenticating problems
not been silly but did it ask you for the router code thats on the box,it did this with my stepsons new tablet...he eventually did it through his phone (he had internet on his htc and synced it through that)
Dec 26, 2013 | Nexus Cell Phones
How to put in sim card
Assuming you mean the 2013 version but I'll try both,
so for the 2013 version
  1. Turn your tablet off and place it on a flat surface with the screen facing up.
  2. Tilt the right side slightly up to find the SIM card tray near the bottom right and the small hole in the tray door.
  3. Insert a paperclip into the hole in the tray door, and push firmly but gently, the tray should pop out.
  4. snp_8a30b60eaed5a3a37f46a8c715167552992e_3271601_en_v0Remove the tray and place the micro SIM card inside it, the angle corner fits with the angled indent
  5. Push the tray it gently back into the tablet.
  6. snp_8a30b60eaed5a3a37f46a8c715167552992e_3271604_en_v0
Activate SIM card
  1. Open the Settings app snp_2918920_en_v1 and turn off Wi-Fi after completing the set-up instructions. Once Wi-Fi is off, you'll see a notification at the top of your screen.
  2. Swipe down the notification shade and touch the notification.
  3. Follow the activation instructions provided by your carrier.
For the Nexus 7 (2012) 3G use the same process noting that the tray slot and pinhole is on the left side of the device when its facing up.
*Note* : Only the Nexus 7 (2013) LTE & Nexus 7 (2012) 3G can accept a SIM card. Wi-Fi versions of the tablet can't.
Dec 10, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
How do i get my sprint phone to work on wi-fi ?
sprint phone or samsung ?
Sprint offers high-speed WiFi service for existing Nextel customers, and provides an extensive network of hotspots in the United States at locations commonly frequented by business travelers, such as hotels, airports and conference centers.
Getting Sprint WiFi requires a Nextel customer account, connection-management software, a MyNextel user account and a computer that supports high-speed broadband.
Sprint WiFi plans include an unlimited WiFi hotspot and an unlimited PC access plan with a WiFi hotspot package.
Sign up for WiFi service through Nextel by calling 1-800-SPRINT1.
Download and install the Nextel Connection Manager software.
Nextel offers the WiFi version of the connection-management software at the Sprint Nextel website (see Resources).
Register your account via MyNextel on the Sprint Nextel website (see Below).
http://ortshop.sprint.com/en/solutions/dataaccess/connection_manager.shtml
Samsung Epic 4G Phone into a Wi-Fi Hotspot
The Samsung Epic 4G smart phone allows you to convert your phone into a Wi-Fi hotspot and connect up to five devices.
Such a set-up will keep you from running around searching for an area that offers free Wi-FI. If you're stuck in an airport or staying overnight at a hotel, you won't have to pay extra for Internet service.
You can connect your laptop or other media device to your phone's Wi-Fi network.
Press the "Home" button, which looks like the outline of a house, on the bottom of your Samsung Epic 4G phone.
Click the "Menu" button to the left of the "Home" button.
Click the "Settings" icon, which looks like a gray box with a spoke in the middle.
Scroll through the list and click "Wireless & Networks."
Press "4G" until a check mark appears, indicating the 4G network is enabled.
Click the "Home" button.
The 4G icon will appear to the left of your signal bars in the upper-right corner of your screen.
The separate sets of bars above the 4G logo indicate the strength of your 4G signal.
When the bars above the 4G logo are completely gray and the 4G logo is white, you have a weak signal.
When you are no longer receiving a 4G signal, your 4G logo will be gray and a 3G logo will appear, indicating that the 3G network is now enabled. If both of the logos disappear, you are not receiving any signal.
You must have either a 3G or a 4G signal to use your phone as a Wi-Fi hotspot.
Enable Sprint Hotspot
Press the "Applications" icon, a blue box with four whites squares in it, in the lower-right corner of your Samsung Epic 4G phone.
Press the "Sprint Hotspot" icon, which looks like a phone with two signal bars on the right side, until a check mark appears to the right of the icon, signaling the Spring hotspot function is enabled.
A pass-key allowing you to connect other devices to the phone's network will appear on the screen.
Write the pass-key down.
Enable Wi-Fi on your laptop or other device that you want to tether to your Samsung Epic 4G phone.
Search for the Wi-Fi network affiliated with your Samsung Epic 4G phone.
The name of the network will begin with "SPH-D700XXX."
To change the name of the Wi-Fi network affiliated with your Samsung Epic 4G phone, press the "Menu" button; the "Settings" icon; and "Device Name." Enter the new name for phone's Wi-Fi network.
Click the network affiliated with your Samsung Epic 4G phone on the device you want to tether to your phone'ss Wi-Fii network.
Enter the pass-key, and click "OK."
Your device will now be tethered to the Wi-Fi hotspot on your Samsung Epic 4G phone.
Aug 06, 2013 | Eforcity For Sprint Samsung Moment M900...
Wifi will not connect
The below info is from user manual ... downloadable version @ www.pantech.com
Connectivity
This chapter introduces useful tips on how to connect to the
network available that enables applications of the phone to
run.
Using a Wi-Fi network
Connecting to a Wi-Fi network
1. Tap Settings from the applications menu.
2. Tap Wireless & networks > Wi-Fi settings.
3. Tap Wi-Fi to activate the technology.
4. Select and tap a network. You should enter the password
if the network is secured. indicates a secured Wi-Fi
network.
5. Tap Connect. Once the network is remembered, the phone
will automatically connect to it when in range.
Activating Wi-FI Connecting to a Wi-Fi
network
Note The icon next to each network indicates the strength of the
signal. For example, indicates the signal is poor while indicates
the signal is strong.
Using the Easy Setting
1. Tap on the top of the home screen and drag it down, or
press n in idle mode and tap Notifications.
2. Tap in Easy Setting. The icon turns red when the
function is on.
About network notifications
You are informed by default when a Wi-Fi network is available
around you. The message in the status bar indicates a
network is available. Tap Network notification in the Wi-Fi
settings if you do not want to be informed the availability of the
network.
Setting Wi-Fi networks
4. Tap Network notification if you want to know an open
network available.
5. Tap Automatic connection if you want the phone to
connect to Wi-Fi network automatically.
6. Tap WPS button connection if you want to establish a
new wireless connection using the Wi-Fi Protected Setup
(WPS). You should press WPS button on your Wi-Fi access
point within two minutes.
Searching for Wi-Fi networks
Jan 17, 2013 | Pantech Pocket
Hoe can i connect my ipone to wiifi on my belkin router
Wi-Fi settings determine whether iPhone uses local Wi-Fi networks to connect to the Internet.
Turn Wi-Fi on: Choose Wi-Fi and turn Wi-Fi on.
Join a Wi-Fi network: Choose Wi-Fi, wait a moment as iPhone detects networks in range, then select a network. If necessary, enter a password and tap Join (networks that require a password appear with a lock icon).
Once you join a Wi-Fi network manually, iPhone automatically joins it whenever the network is in range. If more than one previously used network is in range, iPhone joins the one last used. When iPhone is joined to a Wi-Fi network, the Wi-Fi icon in the status bar at the top of the screen shows signal strength. The more bars you see, the stronger the signal. Set iPhone to ask if you want to join a new network: Choose Wi-Fi and turn "Ask to Join Networks" on or off. Join a closed Wi-Fi network: To join a Wi-Fi network that isn't shown in the list of scanned networks, choose Wi-Fi > Other, then enter the network name. If the network requires a password, tap Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. You can type it manually by login onto the Belkin's network page using the browser and by copying the static and dynamic IP address.
Feb 05, 2011 | Belkin (F5D7230-4) Router (587009)
Cell Phones Logo
41 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
