Question about Brother XL-5130 Mechanical Sewing Machine
The whole sewing arm where you stick the needle in came off the shaft. I put it back on with the needle guide in place. Is that what holds this on the shaft? It will not stay on shaft when I begin sewing and there is nothing in the manual on this subject.
    Brigadier General:
  • 8,619 Answers
Hi
Please check the Bobbin Winder.If the Bobbin Winder shaft is moved to the right position (bobbin winding mode), the needle will not move.
Please return the Bobbin Winder shaft to the left position and press the Start-Stop Button or Foot Control to start the machine in the sewing mode.
Please revert for further assistance.
Thanks
Rylee
Posted on Jul 25, 2009
After replacing the needle in my singer 8280, the needle clamp is not holding the needle tight, the needle falls down even after tighening it..how do i make the needle get fixed?
It sounds like you have lost the tread guide. When you press the clamp as far up as it will go, there should be a slot in the post underneath the clamp visible. You may need to use a mirror to see it. The thread guide snaps into that slot and keeps the clamp from falling down. Take it to any repair shop. It will not be expensive to repair.
Nov 30, 2014 | Singer 8280 Mechanical Sewing Machine
My Brother XL5130 Needle Clamp Body felt out while I am sewing something. I do not know what is missing. I found 4 things in my hand Clamp Body, Pin,Clamp side screw & threads guide. some one plea
There is a hidden screw just that looks like a hole beside the screw that hold the needle... loosen it with # 8 allen key (pretty small) then you put the curved wire back in its hole, then you can put it back on the arm, then screw back the allen screw as tight as you can, this should do the trick worked for me ... I was tring for days to fix it back on but wouldnt go in...this invisible screw was to tight... Hope it helped !
Jul 19, 2012 | Brother XL-5130 Mechanical Sewing Machine
How to thread a singer hand held
Thread should flow from top right of bobbin or spool and the spring must be in place before installing the bobbin.
1. Thread the handy stitcher
2. Pass thread through hole on the thread guide which sticks out from the side of the needle arm.
3. Pass thread through top of the tension control between the plates, but don't wrap completely around the tension control.
4. Then pass the thread through the thread guide located on the bottom side of the needle arm directly behind the needle.
5. Use threader to pass thread through eye of the needle from back to front (opposite of a "real" electronic sewing machine.
Hope this helps.
Jimmy
Mar 29, 2012 | Sewing Machines
The needle of my sewing machine is not aligned..it is out of place and keeps hitting presser foot instead of going in the hole..any suggestions? it seems to get aligned and going in the hole if i pull...
This unit has a 2 year back to base warranty.
Try removing and replacing the needle.
Unfortunately machines with predominately plastic frames are prone to misalignment that even professionals will not bother repairing because it will re-occur quickly (I have been told).
Check that the arm is in place as it should be. and the needle is not bent.
The user guide may also provide more information, check here for replacement parts and further info.
http://www.brother.ie/prod/products/sewingembroidery/sewingmachines/xl2220.htm/s_detailType/downloads
May 02, 2011 | Sewing Machines
I have a Merritt Singer 3130. Very suddenly, in the middle of sewing, my machine started making a loud "clunking" noise every time the needle went down. Now the whole shaft holding the needle...
You should take it in because it sounds like it is a bent needle shaft and before you cause more damage. Find out how much the service will be, and weigh it against buying a whole new machine.
Apr 13, 2011 | Sewing Machines
How do i thread my needle with the singer handy stitch?
  1. Loosen needle screw & insert needle with shank's flat side facing front of machine. Push needle in all the way, then tighten screw to hold needle in place.
  2. Install a fully wound bobbin by loosening bobbin nut & placing bobbin on top. Re-attach bobbin nut & tighten. If standard thread spool will be used, then attach spool pin to bobbin shaft & place thread spool onto shaft. Attach white spool cap on end of thread spool, then tighten. Bobbin/spool should unwind facing forward toward needle.
  3. Bring end of thread through thread guides & over tension control. Pass end of thread through needle eye, from back to front, & pull it out about two inches.
  4. A spring pushes pressor foot onto fabric that is being sewn, so lift pressor foot & place fabric underneath.
  5. Turn large handwheel on side of machine (handwheel can be turned in either direction) to raise needle arm to its highest position.
  6. Holding the Handy Stitch in place with your right hand, press on power switch & begin sewing. Guide fabric (being sewn) with your left hand.
  7. To end this sewing session, turn off power. Turn handwheel to raise needle to its highest position. Carefully pull out about three inches of thread through needle & snip, then lift pressor foot to remove fabric. Turn fabric over & loop needle threader through last stitch. Place end of thread from underside through eye of needle threader, & pull to loop through. Pull to tighten and snip end of thread.
Nov 11, 2010 | As Seen On TV Handy Stitch Mechanical...
Similar problem
That would be the thread guide. You need a small allen wrench to put this whole thing back on. There is a hole in the right side,looks like a hole, it's blackish, but is for allen wrench. The curved metal piece slides up into a tiny hole from the bottom near where needle enters then slide whole thing back on machine and tighten with allen wrench.
Jun 29, 2009 | Brother XL-5340 Mechanical Sewing Machine
I have a Bernette 50 sewing machine....i was sewing velcro....the screw assembly on the post where the needle goes into fell off and the thread guide fell off it....i can't tell if it is broken or just...
That can be tricky. Some thread guides and needle clamps have to be assembled and then slid up into place with the needle screw holding it together. Some have a set screw to hold it.
Jun 27, 2009 | Bernina Bernette 75
I have a quantum cxl. It will sew normal stiches but it will not sew the decorative stiches
The needle shaft sticks to the curved arm and won't come down because a piece of plastic, about an eighth of an inch thick had broken from age. It prevented the shaft from staying up on the needle arm. Open the cover, try to stitch decorative stitch and see what I mean. Purchase a package of 4-10 by 1/2 nut and bolt pack. Screw the nut all the way onto the bolt. Using needle-nosed plyers, Carefully bend the curved arm slightly, and place bolt into the hole on the top of the needle shaft. Nut will keep it in place. Lowering the needle shaft using wheel, carefully bend arm back in place. Try decorative stitch. It should work. It does for me.
Aug 03, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Jun 20, 2008 | Sewing Machines
Brother XL-5130 Mechanical Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
