Question about Vacuums
I turn on my Steam room. It sounds like working but steam not coming out. What can be wrong.
SOURCE: steam will not eject
Same issue with my model. Heated up but would not produce... I called it SED (Scunci Erectile Disfunction) My doctor prescribed him some lube, and it worked! Now days Im happy to say we share a heathy steamy relationship!
Say goodbye to SED forever with the help from lube! All you have to do is open up the unit, locate the circular brass colored button, apply a squirt of lube (wd-40), create a decent amount of pressure and play with the little button until you notice smooth in-out motions. Put the unit back together and BAM you two will be back to a hot and steamy relationship, just like you had when you first met! ;)
Posted on Sep 10, 2008
  • 4 Answers
SOURCE: Euro-Pro Shark hand held steam cleaner model #sc618hd
Your heater in the cleaner is either plugged or has quit working, make sure you are getting a good ground for the cleaner. you may want to check the ground pin on the cord and make sure it is not loose or broken.
Posted on Oct 18, 2008
SOURCE: No steam
I used the straw to prime the lines and 50/50 mix of vinager and water and it worked perfectly. I then mixed the water container with the same mix and ran it through the system. All works fine now.
Posted on Oct 29, 2008
SOURCE: My shark steam mop heats up but won't steam. help
Problem: mineral dleposits. Just fixed mine.... DO THIS OUTDOORS. Add 1/2 c CLR to the tank, let sit for an hour, turn on, allow to heat and pump. May have to refill with CLR and repeat. Be persistent, and eventually you'll blow out a wad of dissovled minerals followed, happily, by billows of steam. Again, do this outdoors and keep the mop pointed away from people, plants and things. (I aimed mine into a cardboard box.) Follow up with a couple of tanks of water and pump until empty to clean out any residual CLR and loosened deposits. (I continued to get some black precipitate through the first water cleaning.) I will add that I began this process first with white vinegar, then with Lime Away..no luck put perhaps I was not sufficiently persistent. Or perhaps it was the sequence of attempts. (Also, do not take off the mop head...the part to which you attach the pads...it's tough to get off, does not allow access to parts that need cleaning (thought it would, not not so), and practically impossible to get back on.)
Alternatively, call Shark...they'll offer to repair for $18 plus $10+/- shipping, or may offer you a new one at "preferred customer" rate of $39.95 plus shipping. Good luck, and please remember to try the CLR outside.
Posted on Feb 06, 2009
SOURCE: my steam mop turns on but it wont steam anymore
I just had this problem after owning the mop for about a year. I let it stand for a while in a bucket of vinegar, then tried it again and it worked. I think it had gotten clogged with hard water deposits and the vinegar dissolved them. I'm buying some distilled water to use in the future with it.
Posted on Oct 03, 2009
Shark steam mop not sending steam to attachment
It sounds like the head could be clogged up. Try running water in the head and see if that works
Jun 07, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
THE STEAM IS NOT COMING OUT, THE HEATER SEAMS TO BE WORKING, WHAT'S WRONG?
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
;jk
Aug 08, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam pocket mop little or no steam.
aHi,
heatman101
a
Jun 04, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steamer has stopped working, where to look
There is no fix...
heatman101
Jan 01, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I haven't had my shark steam mop for long and now it does not steam. The light comes on but it does not get hot. What is wrong. I paid too much money for this not to work
heatman101
a
Feb 18, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Prolectrix 3 tier steam
Is the unit spraying ok? If not then the heater may be plugged. Other than that, you should fill the tank with hot tap water, the the heater will only heat it alittle more, you won't really see steam.
Jan 19, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
