Question about Sewing Machines
Needle is jammed in needle clamp. Screw is loose and even with pliers can't remove. Help Singer Quantum 9960
  • Sewing Machines Master
  • 12,515 Answers
SOURCE: needle clamp won't attach to needle bar
There is a set screw above the needle pin screw which tightens with an allen wrench--try that.
Posted on Feb 21, 2009
  • 139 Answers
SOURCE: Singer 6038 needle clamp
You can order parts through the Singer parts centers listed on this page:
http://www.singerco.com/support/replacement_parts_ssc_list.html
Posted on Apr 08, 2010
  • 1788 Answers
SOURCE: Can't loosen screw holding needle in sewing machine
Use a penny or a nickel in the screw head. Works like a charm
Posted on Jul 26, 2010
Testimonial: "Thanks!"
SOURCE: i need to replace the needle clamp screw
if the screw has stripped out then you need a new one
try these sites
ebay
sewingpartsonline.com
premiersewing.com
sewusa.com
Posted on Apr 03, 2012
llsilvermerm
SOURCE: Just purchased the Singer Quantum Stylist 9960,
When you pull the needle threader down it seems like it is pulled all the way down but it isn't. Pull it a little harder and it will turn and go down all the way to match up with the needle eye. I was a little scared to apply the extra "force", thinking I could break my new machine. Just be easy with it and it will work just like the manual says.
Good luck....
Posted on Oct 05, 2012
Sewing machine jammed with needle down and material can not be removed. Help I can break the needle, I really just want the fabric out.
loosen the needle clamp screw then you can pull the needle out with pliers not damaging any of the machine or bobbin area .
Oct 30, 2015 | Singer Sewing Machines
On a Singer Quantum 9940, the upper thread will not 'catch' the bobbin thread. What should I try to do?
Make sure that your needle is all the way up. With many needle clamps, loosening it enough to remove a needle is not enough to insert one -- you have to loosen it a little bit more. You can determine that by looking right above the clamp on the shaft -- there is what looks like a grey bar and the end of the needle should be right under it. If your needle is too low, it will not catch the thread.
May 24, 2014 | Singer Quantum 9940 Computerized Sewing...
New 9960 Singer sewing machine keeps jamming
try a new needle-- one for the fabric your sewing
make sure the top thread doesn't come off the thread take up lever
make sure the bobbin is inserted correctly
if the suggestions don't help
take the machine back and tell them what it's doing and ask for another one
Mar 05, 2014 | Singer 9960 Quantum Stylist Sewing Machine
New 9960 sewing machine keeps jamming
try a new needle--the correct one for the fabric and thread
make sure the top thread has not come off the thread take up lever
rethread the machine top and bobbin-- using every thread guide
make sure the bobbin is turned the right way in the bobbin case
if these suggestions don't help, then taking the machine to be checked would be a good idea.
How to remove the screws holding needle plate on singer 9960
Hi Mary Lou.
Just wanting to confirm the machine you are talking about is the Singer 9960 as shown in the link below.
http://singer9960.org/
Jun 19, 2013 | Singer Sewing Machines
I have a Singer Quantum XL-100 Sewing/Embroidery machine that repeatedly and frequently breaks needles. In one 10-minute sewing session, it broke six needles. The tension at the top of the machine i
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Feb 01, 2013 | Sewing Machines
Needle **** screw is jammed
Perhaps your clamp screw is too tight. Remember, "lefty-loosy, righty-tighty". Take your pliers and turn left or take it to a repair-person.
Jul 02, 2012 | Singer Sewing Machines
How do I remove the needle clamp from the needle bar on a Singer Futura Quartet sewing machine?
try undoing the lock screw fully and gently move the clamp in the opposite direction the the lock screw, it should drop off.
May 30, 2012 | Singer Sewing Machines
It is a singer quantum futura ce 200 sewing and embroidery machine .the machine sews but incomplete,skipping and missing stiches. does not always bring up bottom thread . grrrrr---help, i want to sew
Sewing machine skips stitches
1.needle inserted incorrectly--flat side of the needle faces the shaft
round needle--groove of needle faces away from the shaft
2.Correct needle insertion is mandatory for proper use.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the needle. Place the new needle in the clamp with the flat side of the needle facing the back of the machine.
If round needle--the groove in the needle faces away from the shaft
Push needle all the way up to the stop or as far as it will go.
3.possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
4.blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
5.needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
6.incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
7.wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem--some can't--
8.size of needle & thread not compatible--
Using the wrong type needle can cause problems,,
A needle to fine for heavy fabric can bend or break when it hit's the fabric
And a too large needle can make puncture holes in the fabric and pull unevenly while stitching
Sep 14, 2011 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
