Question about RIM BlackBerry Bold 9000 Smartphone
Keyboard on BOLD 9000 not working. "A" button hits uo, trackball enter not working. Green Call button displays jk and Red button displays "nm". Pls help
I have the exact same problem. :/
Have you by any chance found a solution yourself yet?
Dennis.
Posted on Aug 25, 2010
Blackberry Bold trackball rolls perfectly but click doesnt work.
Your trackball is faulty and should be replaced, please contact a certified blackberry support personnel for repairs.
Regards
Mar 01, 2010 | RIM BlackBerry Bold 9000 Smartphone
Bold keyboard issues
I had the same problem and have looked all over the internet for a solution, so I know how desperate you can get when your Blackberry isn't working properly anymore. In my case I have found the solution. The cause of the problem might be dirt or moisture underneath your trackball and keyboard.
Solution:
you have to disassemble your Blackberry completely. So remove the 6 screws on the back with a Torx 6, lift of the bezel, lift out your motherboard and then lift up the trackball cover so you can remove the trackball (see the videos on youtube). Now you can clean the area underneath the trackball, mine was really dirty. In fact, there was dust everywhere inside my Blackberry. I cleaned all contacts and the trackball with a cuetip with some alcohol and used a cotton swab to make them dry again. When I put everything back together, it worked like a charm!!
It's really not that hard to do this, so don't be scared and just give it a try! Follow the instructions on youtube (for disassembling and cleaning) accurately and don't force anything!
I hope this will help.
Carlo
Aug 23, 2009 | RIM BlackBerry Bold 9000 Smartphone
Keyboard not working :@
are u change the writing language into ABC mode from DICTIONARY mode(in message setting).If answer is NO then first change it & see the results.
And if it is already in ABC mode then i suggest u to show it in wellknown mob. shopee for repairing.
Dont take a risk,give it in safe hands.
Aug 13, 2009 | RIM BlackBerry Bold 9000 Smartphone
Blackberry types wrong two letters on answer, trackpad, a etc.
Try Software. Most likely software problem, water damage would mess it up worse. Try googleing it, and useing blackberry support forums. On my old Windows Mobile phone, the ROM has many of those glitches. Your best bet would be a backup > Soft Reset > Hard Reset > Then check it. If problem persists, Do what i said above about the support forums, they will help you with software to reset keyboard
:) God Bless
Jul 13, 2009 | RIM BlackBerry Bold 9000 Smartphone
Answer, hang up, trackpad and a yield two letter combinations
Sounds like your keyboard may have gotten wet. Somebody needs to open your Blackberry and clean it from any corrosion and residue of the liquid. If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is an Blackberry 8520 Repair Guide that shows how to repair a Blackberry.
Keyboard not workin
this is hardware problem .for the same please contact service center
Jul 04, 2009 | RIM BlackBerry Bold 9000 Smartphone
Unable to save to contacts folder and unable to copy from sim to contacts folder, pls help my contacts folder is empty and i can't save nor copy to it. using bold 9000.
To add your SIM contacts to your BlackBerry Address Book.
1. Press the 'Menu' key.
2. Highlight 'Contacts' and select (press the trackball).
3. Press the 'Menu' key.
4. Highlight 'SIM Phone Book' and select (press the trackball).
5. Press the 'Menu' key.
6. Highlight 'Copy All to Contacts' and select (press the trackball).
To add your Black Berry Address Book contacts to your SIM.
3. Highlight the contact you wish to move and press the trackball.
4. Highlight the number and then press the trackball.
6. Highlight 'Copy to SIM Phone B...' and press the trackball.
7. Press the trackball and highlight save and press the trackball again.
hopes it helps better.
Jun 12, 2009 | RIM BlackBerry Bold Smartphone
Codes to unlock blackberry bold 9000
It's a clear and fully detailed guide on how to unlock a BlackBerry Bold 9000 :
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (if your BlackBerry have touchscreen)
7. Type MEPD ( you will not be able to see what you are typing )
8. Type MEP2 or MEP4 ( you will not be able to see what you are typing )
9. Now the phone will prompt you to enter the mep code
10. if you not already have the code, then i suggest BlackBerryMEP.COM to get it from .
11. Enter the mep code ( you should see "code accepted" )
12. Restart your BlackBerry .
All done.
SOURCE :
BLACKBERRYMEP.COM
Mar 12, 2009 | RIM BlackBerry Bold 9000 Smartphone
RIM BlackBerry Bold 9000 Smartphone Logo
2,239 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
