WwWhere do colored plugs attach on back of older tv? Have several plugs
  • Televison & ... Master
  • 3,197 Answers
Hello Jessie,
New audio/visual equipment is daily
less compatible with "older" TVs"...
There ARE adapters available to achieve
certain levels of CONNECTIVITY but
Those adapters will seldom give you FULL
FUNCTIONALITY...
"Older" TVs if equipped with "RCA" (PHONO TYPE) jacks
are fairly obvious by the color of the audio...
(usually red & white)
and the video (used to be a single "yellow"
I'm going to keep this short...
Evoltuionary TV connections is a really BIG subject...
You need to disclose more than "OLDER"
But my best advice is to cave in and buy (or borrow)
yourself a MODERN TV that will accept the
"several plugs" you have.
Carnac
Carnac the Magnificent
Posted on May 11, 2017
How do I set up my secura cam SW214-SCC
Step1: At the end of your SecurityCam cable you will find three colored plugs: Yellow(Video RCA), white(Audio RCA),Black/Orange(DC Power) or identify
OR
Identify the cables at the end of the SecurityCam cable as color for video ,audio and power may vary.
Step2: Plug Video RCA plug(1) into the "Video In" input(3)(Usually located at the back of your TV or VCR)
Step3: Plug the audio RCA plug(2) into the "Audio In" input(4)(Usually located at the back of your TV or VCR)
Step4: Connect DC power plug(5) at the end of your Security Cam into the end of the power adaptor(6)
Step5: Plug the power adaptor(7) into the main power point in your wall
Step:6 If you have AV/TV with RCA sockets you will need to switch the TV to the AV change to view the camera.
Pictures is attached. Please have a look at it.
Jul 17, 2016 | Office Equipment & Supplies
How to connect to tv
There are several ways to connect a game console to a TV. The question is, what system are you trying to connect? Some features may be available for the newer generations, that are not on older models. I'm assuming, since you have posted with a picture of a Sony Playstation 3, (PS3) that is the system you are trying to connect. The easiest way to install is to use the supplied (RCA) connection cords that comes with every PS3 system. One side connects to the corresponding port in the back of the system, and the other end has (3) multicolor plugs. They will match the colors on most TV's. Some of the older TV's do not have the RCA ports and will require an adapter to connect this way. These colors are; YELLOW (video out) RED (audio out right channel) and WHITE (audio out left channel or MONO) The PS3 also has and HDMI port, and is much simpler to connect the TV and game console together. As I stated before, not all TV's are equipped with HDMI. HDMI cables carry both the video and the sound through 1 cable. To install this way, simply turn on your TV to the correct aux port, in this case HDMI, then connect the the HDMI cable from the PS3 to an available port on the TV. After you have connected the cords, turn the system on and it will tell you that it has "Detected an HDMI connection. Would you like to use this connection?" Select yes. The rest is automatic.
Also, if you didn't know and are needing a new rca cord to connect to the TV, search for a cord from one of the older systems in the SONY family and they will save you some cash, as they are all exactly the same. PS1, PS2, and PS3 all use the same connection. I hope this helps. Good luck!
Aug 25, 2015 | Video Game Consoles & Games
Picture freezes
a freezing picture is normaly due to bad input signal have your imp input signal checked
Oct 17, 2010 | Televison & Video
I am trying to hook up my Philips 19PR19 (made in 1998) tv to the dish network receiver, it has 3 prongs diff. colors attached and the cable cord is already to go in the wall...I don't see anywhere on the...
Because your TV is an older one, it might not have, what they call RCA inputs (the 3 colored cable) Red-audio right, White-audio left, Yellow-video. If I understand you.
You do have the option of using the 75-ohm coaxial cable inputs. Signal comes in from outside to the 722k, Output of the 722k to the 75ohm coax input on the back of the TV. Tune your TV to ch. 3 or 4. Make sure the switch on the back of the 722k is set to the same.
If you really want to use the RCA colored cables, then you need to buy an RF modulator, which integrates older tv's to newer products. But usually dvd players, not necessarily cable boxes, but it would work if hooked up correctly.
You plug the RCA red, white and yellow from the 722k, into the rf modulator, choose channel 3 or 4 on the modulator
Connect 75ohm coax cable from rf modulator to TV 75ohm coax cable input. Choose channel 3 or 4 on the TV.
Hope this helps.
Apr 07, 2010 | Philips 19PR19 19" TV
PS2 won't play color on HD TV set
Did You Make Sure You Put the Plugs In The Right Places In the Back Of The TV
Jul 17, 2009 | Sony PlayStation 2 (PS2) Console
Have a Konka TV but ps2 doesnt play through it.
It may be the T.V. And make sure that the connections are with the right colors, take a light back there and check to make sure. You said the T.V. plays through black and white, maybe the T.V. is old and can only play black and white but those cables will not make a T.V. go to color.
Jan 29, 2009 | Sony PlayStation 2 (PS2) Console
Rf input dislodged
replace its tuner. It will be the best. If you wish to get some details; visit the site linked here. Pull up older posts.
Apr 21, 2017 | Toshiba 19A24 19" TV
Hook up
On the back, there are three ports that are color-coded and match the cables. Take the yellow cable and plug it into the yellow port. Do the same with the red and white. Take the other end of the cables and plug them into your TV or VCR. Most TVs and VCRs have ports for the cables on either the back or front, and are also color-coded. Plug the yellow cable into the yellow plug on your TV/VCR, and repeat for the red and white cables.
Oct 24, 2008 | Philips Magnavox MWD7006 DVD Player
Screen colors not constant
You probablly have bad solder joints on your Video driver transistors, which arre located on each Picture Tube. You can only get to those by going through the front, grille cover
Apr 10, 2008 | Pioneer SD-P62A5-K TV
Televison & Video Logo
Top Televison & Video Experts
