Good afternoon, my TV shows lines across the screen when I try to view any channel other than 101 prime time
    Top Expert:
  • Televison & ... Master
  • 74,887 Answers
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on May 12, 2017
HOW DO YOU GET PRIME TIME ANYTIME ON ALL TV'S
Hi, I would be happy to assist you with your question. Prime Time Any Time is a feature of the Hopper that allows your local channels to be viewed using one tuner. It also allows for the recording of all four major networks ABC, CBS, NBC, & FOX during prime time hours using one tuner. If one TV is set to a local channel than you can press the Red Hot Key on any DISH Remote and it will display the TV Viewing Screen and all the locals will be listed. You can scroll to and select any of the locals listed and it will play on that TV. If you are still having issues and need additional assistance, please feel free to PM DISH directly on facebook here: http://goo.gl/dgbNL Thank you!
Mary Catherine Brady
Team Lead- Social Media
DISH, L.L.C.
Sunday-Wednesday 2:45pm-11:15pm, Thursday 1:30pm-10:00pm (MST)
Feb 01, 2013 | DISH Network Hopper Whole-Home HD DVR
Photos@vizio.com/Casenumber/2540322
My tv has white lines across all on the screen
Jun 05, 2012 | Vizio 42 in. LCD TV
White flickering line across top of screen
Set the screen format using your TV's menu. Do not set the format of the screen using your provider's receiver. I had this prob with a few channels with a dish provider when I set the format with the remote from the dish provider. I picked up the TV's remote, went into the menu, set the format, problem fixed.
May 15, 2010 | Vizio GV42L 42 in. LCD Television
Multiple horizontal lines runnning across the
It sounds as though you have a poor signal issue. Firstly try rescanning all the channels. If no difference check the aerial/dish connections, then rescan. Lastly check the aerial/dish externally for misalignment and connectability.
Jan 03, 2018 | Samsung Televison & Video
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
26PFL5520D/50 DVT PROBLEM
If the lines across the screen are made up of coloured blocks, then the problem is likely to be a weak signal.
Digital channels are broadcast in groups called multiplexes. Sometimes one multiplex may have a weaker signal than others, and so you experience problems with up to 6 channels when all others are ok.
If it is only one or a few channels then just wait and see what happens, because it may be transmitter works.
If you have problems with all channels it could be a connection or antenna problem.
If the lines are just straight lines, then try resetting the TV as follows:
Switch on the TV
Press and hold the menu button on the side of the set. The settings menu will appear. Hold until the menu disappears again.
When you release the button, the TV will take up to about 90 seconds and then reset.
The TV will then show the original screen when the TV was new.
Press ok when shown.
Set language and country settings.
Move down the list and press ok to re-install all channels.
Feb 22, 2008 | Philips 26PF5521D 26 in. HD-Ready LCD...
Line across screen
I have the same problem with my 42 in. The line started to show up randomly about 1 month after i got my tv. The line isn't a line of dead pixels since when i change the aspect ratio or the tv the line moves up or down. I called sharp about the problem and they said it had something to do with my computer but i don't think that can explain why the problem shows up on all my tv inputs.
Dec 17, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Picture appears to be trying to scramble
Bad hyper board == No longer available
Bad electrolytic capacitors on board need changing-
Let me know if you need more info......T.
Nov 01, 2007 | Toshiba 51H84 51" Rear Projection...
Washed out colours and thin red lines across the screen
your problem is in red video circuit. please get it done with skilled tech.
Oct 05, 2007 | Panasonic CT-32SL15 32" TV
Lines across screen when using View On Demand channels
Could be a couple of things causing this.
1) Obvious, but I assume that you subscribe to these services, because otherwise it could be the encryption.
2) Make sure that you have the set-top box connected directly to the TV, and not through an external recorder (VCR, DVD etc)
This would be a problem if the services were copy protected in the same way DVDs are.
You could also check the settings on the set-topbox. Make sure the video output is set to RGB.
Aug 05, 2007 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Televison & Video Logo
Top Televison & Video Experts
