Question about Fujitsu Lands Phones
Fujitsu phone f10l-0760-s200#bk, how do I setup an auto dial button
2 Suggested Answers
SOURCE: Have an Emerson cordless phone EM6113-BK. We can
On that model you need to press and hold the FLASH button, after it beeps it will be in tone mode and not pulse.
Posted on Oct 19, 2010
Instruction Manual for Bitatone Mobile Phone 0760
cellphone.manualsonline.com
for Binatone phone 0760
May 13, 2014 | Binatone Lands Phones
Change the time on our NEC DT300 Series
What model of NEC phone system do you have? Go look in the phone or data room and look at the PBX. You might also be able to press Feature 3 to get some information which would be helpful to a tech. If it is an SV8100 try this:
To set the system Time:
1. Press
Speaker.
2. Dial
728.
3. Dial two digits for the hour (24 hour clock, 13 = 1:00 PM).
4. Dial two digits for the minutes (00~59).
5. Press
Speaker to hang up.
Oct 08, 2012 | NEC Lands Phones
How do I set my speed dial numbers?
Which ones? System speed is programmed from station 10 or 11 and goes in the 6xx's, depending on your version of software. The start is FEATURE 00 FEAT 6xx and dial the number You can continue programming more numbers by pressing FEAT 6xx or Feat 00 to exit.
Personal speed dial numbers are programmed similarly, except they are in locations 80-99 on each phone and can be programmed from the phone if it's a system phone.
Auto Dial buttons use blank buttons on your set. Feature 00 pressing the button and dialing the outside number store those. Again, Feature another button will let you program another button, or Feature 00 ends programming.
Carl
Jul 12, 2011 | Lucent PARTNER18 Corded Phone
How do I program the system for auto-dial? The manual is useless...I have followed those directions & have gotten no where.
The 7030 phone was first introduced in 1989 or so, and it is forward and backward compatible with about 18 different Panasonic systems. Since the "auto-dial" is part of the phone system, it isn't easy to answer your question.
As a minimum, you have buttons with lights and "F" buttons without. They program differently.
For example, if you want to autodial another extension, you pick a lighted button, put the phone in PROGRAM, press the button, and dial 1 + ext and STORE. How you program outside numbers depends on what happens when you dial "9" on the intercom. If you get a working line, then you program a button with lights by the 2 + 9 + the number, or "F" button by just dialing 9+.
System speed dials are programmed from the master phone in system location 01 or 001, depending on model.
Carl
Mar 02, 2011 | Panasonic KX-T7030 Corded Phone
With the Panasonic KX-T7633 - how do you change the time on the display?
Press Program button
Dial **1234
Dial 000
Press SP Phone Button Twice
Dial Hour (00-12)
Press FWD/DND button
Dial Minutes (00-59)
Press Auto Answer button to select AM or PM
Press Autodial/Store button
Press Hold button
Sep 28, 2010 | Panasonic KX-T7633 Corded Phone
Cant get the phone off pulse when dialing model#EM6113-BK
Tone/Pulse
You can switch the dial mode. In most situations the TONE option should be selected.
Press the "Menu OK" button. Select BASE using "
May 30, 2010 | Emerson EMSEM2646WH Phone
Apr 16, 2010 | Emerson Smartset Clock Radio
Just started job need to set up voice mail no manual for DTU-8D-2(BK) is available. Please help
dial 300 and that will take you into the voicemail setup and programming
Aug 24, 2009 | NEC DTU 8D-2 Corded Phone
I have a 5 year old Whirlpool Electric Dryer, Model #LER7648KT2. The Dryer won't start. I have checked the door switch, start button switch and visible thermo switches or thermostats with an ohm meter...
There are usually 2 thermal fuses in dryer circuits. One is on the heater housing and will blow in an overtemp condition around 310-350F.
The other is on the blower or exhaust housing and will blow around 200F
Make absolutely sure the 2nd one is continuous and not intermittently functional. This will definitely stop the motor from functioning
Below is a diagram for an older model (LER4634). Your dryer has some additional terminals probably because it has additional drying cycle options.
The diagram may be more readable when copied and pasted into a plain text editor such as Notepad or another editor with non-proportional fonts
Switch Terminals
|TM |TM |BK |BK |BK |
|WB |OR |BU |BU |R |
|-- |-- |V |-- |-- |
|O |X |O |X |X |Auto - High Heat
|O |X |X |X |X |Auto - Low Heat
|<> |<> |~ |X |O |Cool Down / Fluff
|O |X |O |O |O |End of Cycle
|X |O |O |X |X |Timed - High Heat
|X |O |X |X |X |Timed - Low Heat
Legend:
O = Open (Infinite Resistance)
X = Closed (Continuous)
<> = Either (But not Both)
~ = Doesn't Matter
NA = Not Applicable
Switch Terminals:
TM - Timer Motor (Different Models may use different colors)
WB - Black/White
OR - Orange
BK - Black
BU - Blue
V - Violet/Purple
R - Red
Example: For the Auto - High Heat Dry cycle, the following terminals are continuous:
Terminals
<TM - OR>
<BK - BU>
<BK - R>
(of course since BK-BU is continuous and BK-R is continuous, then BU-R is also continuous.
This should allow you to test at least some of the cycles your timer switch has
I have a general schematic in PDF for whirlpool for gas and electric, but did not see an option to add an attachment to this message.
Hope this helps or point you in the right direction.
Apr 21, 2009 | Dryers
Speed Dialing
Press PROG press a speed dial button (ie 13-24) dial 9 plus the number press STORE
Carl
Oct 08, 2008 | Panasonic KX-T7731 Corded Phone
Lands Phones Logo
Top Fujitsu Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Fujitsu Lands Phone Expert? Answer questions, earn points and help others
