My washer ran for 3 or 4 minutes then just stoped
My pressure washer ran fine for 2 years now it shuts down every 2 or 3 minutes with or without water pressure resistance consistently
check or replace the water pressure regulator . clean / replace the end jet on the hose.
May 04, 2015 | Garden
I was wahing a load of closes and th leater came up LE and the washing stoped , I took the blanked out and finished. what is the probably? It is new!
This is an LG washer? It was probably an unbalanced load. Heavy blankets can do that.
If the LE code is still there, try this:
Unplug the washer and leave unplugged for 15-20 minutes.
Reach inside and manually turn the drum 2-3 times around.
Plug back in and it should be reset.
Jan 24, 2011 | Washing Machines
After f02 code came up ran a test and get c00 andhttp://www.fixya
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Sep 27, 2009 | Kenmore Washing Machines
Washer will not reset
Depress "end of cycle" button for 3 seconds & wait for 2 minutes to try the door gently.
Mar 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cleaning cycle
bleach goes in the bleach area. no soap or clothes in the washer. close the lid and hit the power & clean washer buttons. should run for 60 minutes, but check it after an hour to make sure it is complete. mine ran (malfunctioned) for over 3 hours indicating 7 minutes left.
Jan 14, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Open Questions:
Samsung Washer WT1101cw will not drain. Originally had a OE error. Running "Spin" or "Rinse Spin" cycles but pump cycles on for less than 1 second and goes into spin with water in it. _Laundry loaded with a OE error and water not draining. _I manually drained the system, took apart the drain and did not find a clog or anything to prevent the motor from turning. _Pump motor reads continuity. _Ran multiple SPIN cycles and then a RINSE and SPIN cycle and actually had the pump run for a few seconds and even for a minute or so one time but could not repeat and hasn't since. _checked the Pressure Switch and see continuity between common and outside contact. Tried to increase pressure by blowing into the tube using a straw on the end of tube but saw no change. Not sure how the pressure is created inside the bowl. _There was no overfill condition originally and I have not tried to run a normal cycle because the washer is in an upstairs location and draining is difficult and messy. ___I believe that something is preventing the voltage from being sent to the pump motor but I have am not sure what logic conditions need to be satisfied for this to happen.I keep looking at the pressure switch because the drum will perform a load sense and then go into a spin cycle with water in it which sloshes around. Questions: --Shouldn't the drain pump normally be running prior to the spin? --what causes the change in the pressure switch? Does the switch only change at a "full" level? Please only answer if you have a clear understanding of the system. I am trying to avoid excessive expense in this repair and swapping parts unnecessarily. I am beginning to think that it is the control board and do not want to spend hundreds of dollars if it is not. Thanks.
Apr 23, 2018 | Samsung Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
